I am absolutely new to FEniCS (and python) - running via Anaconda on a mac.
In an attempt to practice what I’ve learned form the FEniCS tutorial, I am trying to solve the following pair of PDEs in 2D (one is non-linear the other is linear)
du/dt = D∆u + u(1-u)(u-a) -v
dv/dt = ∆v + bu - v
(0<a<1, b>0 are parameters)
using the variational form. I wrote to code by emulating the code from the FEniCS tutorial
( ft09_reaction_system.py)
but I keep on getting the trivial solution for both u and v
I think the problem is with the ICs (or their interpolation). I want to choose ICs that are equal along the y (x[1]) axis of the mess, because I know the solution in 1D is a pair of traveling waves (it’s a simple problem, the equation for u generates the wave, and v is a linear filter on u)
but because I am really new it may be something else.
Would love it if someone could help me figure out where I went wrong?
here’s the code:
# %load AIRDpde.py
# I am trying to solve the following pair of PDEs (one is non-linear the other is linear)
# du/dt = D*∆u + u*(1-u)*(u-a) -v
# dv/dt = ∆v + b*u - v
# (0<a<1, b>0 are parameters)
# using the variational form, but I keep on getting the trivial solution for both u and v
# I think the problem is with the ICs
# parameters
T = 5.0 # final time
num_steps = 50 # number of time steps
D = 0.016 # U diffusion coefficient
a = 0.25 # model param - x axis
b = 0.14 # model param - y axis
# Create mesh
nx = ny = 30
mesh = RectangleMesh(Point(-3, -3), Point(3, 3), nx, ny)
# define function spaces
P1 = FiniteElement('P', triangle, 1)
element = MixedElement([P1, P1])
# Define boundary condition
# none - Neumann bcs
# Define initial value
u_0 = Expression(('0.6*(1+tanh(beta*(x[0])))', '0.1*(1+tanh(x[0]))'),
degree=1,beta=2)
u_n = interpolate(u_0, V)
u = Function(V) # current step
u_n = Function(V) # previous step
u_1, u_2 = split(u)
u_n1, u_n2 = split(u_n)
v_1, v_2 = TestFunctions(V)
F = ((u_1 - u_n1)/dt)*v_1*dx + D*dot(grad(u_1), grad(v_1))*dx + u_2*v_1*dx - u_1*(1.0-u_1)*(u_1-a)*v_1*dx \
+ ((u_2 - u_n2)/dt)*v_2*dx + dot(grad(u_2), grad(v_2))*dx + u_2*v_2*dx - b*u_1*v_2*dx
# create vtk files
vtkfile_u_1 = File('AIRD/u_1.pvd')
vtkfile_u_2 = File('AIRD/u_2.pvd')
# Time-stepping
t=0
for n in range(num_steps):
# Update current time
# Solve variational problem for time step
solve(F == 0, u)
# Save solution to file (VTK)
_u_1, _u_2 = u.split()
vtkfile_u_1 << (_u_1, t)
vtkfile_u_2 << (_u_2, t)
# Update previous solution
u_n.assign(u)
