I have been trying to solve the following, two-dimenional nonlinear PDE with Fenics:
2 grad(u).Hessian(u).grad(u) + (grad(u).grad(u)) * laplacian(u) == -f [in \Omega]
u = u_D [at the boundary of Omega]
where u is a function of two variables and Hessian(u) its Hessian. If I construct the problem by hand in such a way that u = 1 + x^2 + 2y^2 is a solution, then I have f = -8 * (5 * x^2 + 28 * y^2), u_D = u at the boundary of Omega. I gave this problem to fenics with the following code
mesh = UnitSquareMesh(8, 8)
# Define boundary condition
u_D = Expression('1 + x[0]*x[0] + 2*x[1]*x[1]', degree=2)
def boundary(x, on_boundary):
return on_boundary
f = Expression('-8*(5*x[0]*x[0]+28*x[1]*x[1])', degree = 2)
# Compute solution
dF = dot(grad(u), grad(u))*dot(grad(u), grad(v))*dx - f*v*dx
solve(dF == 0, u, bc)
# Save solution to file in VTK format
vtkfile = File('poisson/solution.pvd')
vtkfile << u
# Compute error in L2 norm
error_L2 = errornorm(u_D, u, 'L2')
# Compute maximum error at vertices
vertex_values_u_D = u_D.compute_vertex_values(mesh)
error_max = np.max(np.abs(vertex_values_u_D - vertex_values_u))
# Print errors
print('error_L2 =', error_L2)
print('error_max =', error_max)
But when I run it I get some nans
$ python3 ft01_poisson.py
No Jacobian form specified for nonlinear variational problem.
Differentiating residual form F to obtain Jacobian J = F'.
Newton iteration 0: r (abs) = 4.057e+01 (tol = 1.000e-10) r (rel) = 1.000e+00 (tol = 1.000e-09)
Newton iteration 1: r (abs) = nan (tol = 1.000e-10) r (rel) = nan (tol = 1.000e-09)
Newton iteration 2: r (abs) = nan (tol = 1.000e-10) r (rel) = nan (tol = 1.000e-09)
Newton iteration 3: r (abs) = nan (tol = 1.000e-10) r (rel) = nan (tol = 1.000e-09)
Newton iteration 4: r (abs) = nan (tol = 1.000e-10) r (rel) = nan (tol = 1.000e-09)
Newton iteration 5: r (abs) = nan (tol = 1.000e-10) r (rel) = nan (tol = 1.000e-09)
Newton iteration 6: r (abs) = nan (tol = 1.000e-10) r (rel) = nan (tol = 1.000e-09)
Newton iteration 7: r (abs) = nan (tol = 1.000e-10) r (rel) = nan (tol = 1.000e-09)
Newton iteration 8: r (abs) = nan (tol = 1.000e-10) r (rel) = nan (tol = 1.000e-09)
Newton iteration 9: r (abs) = nan (tol = 1.000e-10) r (rel) = nan (tol = 1.000e-09)
Newton iteration 10: r (abs) = nan (tol = 1.000e-10) r (rel) = nan (tol = 1.000e-09)
Newton iteration 11: r (abs) = nan (tol = 1.000e-10) r (rel) = nan (tol = 1.000e-09)
Newton iteration 12: r (abs) = nan (tol = 1.000e-10) r (rel) = nan (tol = 1.000e-09)
Newton iteration 13: r (abs) = nan (tol = 1.000e-10) r (rel) = nan (tol = 1.000e-09)
Newton iteration 14: r (abs) = nan (tol = 1.000e-10) r (rel) = nan (tol = 1.000e-09)
Newton iteration 15: r (abs) = nan (tol = 1.000e-10) r (rel) = nan (tol = 1.000e-09)
Newton iteration 16: r (abs) = nan (tol = 1.000e-10) r (rel) = nan (tol = 1.000e-09)
Newton iteration 17: r (abs) = nan (tol = 1.000e-10) r (rel) = nan (tol = 1.000e-09)
Newton iteration 18: r (abs) = nan (tol = 1.000e-10) r (rel) = nan (tol = 1.000e-09)
Newton iteration 19: r (abs) = nan (tol = 1.000e-10) r (rel) = nan (tol = 1.000e-09)
Newton iteration 20: r (abs) = nan (tol = 1.000e-10) r (rel) = nan (tol = 1.000e-09)
Newton iteration 21: r (abs) = nan (tol = 1.000e-10) r (rel) = nan (tol = 1.000e-09)
Newton iteration 22: r (abs) = nan (tol = 1.000e-10) r (rel) = nan (tol = 1.000e-09)
Newton iteration 23: r (abs) = nan (tol = 1.000e-10) r (rel) = nan (tol = 1.000e-09)
Newton iteration 24: r (abs) = nan (tol = 1.000e-10) r (rel) = nan (tol = 1.000e-09)
Newton iteration 25: r (abs) = nan (tol = 1.000e-10) r (rel) = nan (tol = 1.000e-09)
Newton iteration 26: r (abs) = nan (tol = 1.000e-10) r (rel) = nan (tol = 1.000e-09)
Newton iteration 27: r (abs) = nan (tol = 1.000e-10) r (rel) = nan (tol = 1.000e-09)
Newton iteration 28: r (abs) = nan (tol = 1.000e-10) r (rel) = nan (tol = 1.000e-09)
Newton iteration 29: r (abs) = nan (tol = 1.000e-10) r (rel) = nan (tol = 1.000e-09)
Newton iteration 30: r (abs) = nan (tol = 1.000e-10) r (rel) = nan (tol = 1.000e-09)
Newton iteration 31: r (abs) = nan (tol = 1.000e-10) r (rel) = nan (tol = 1.000e-09)
Newton iteration 32: r (abs) = nan (tol = 1.000e-10) r (rel) = nan (tol = 1.000e-09)
Newton iteration 33: r (abs) = nan (tol = 1.000e-10) r (rel) = nan (tol = 1.000e-09)
Newton iteration 34: r (abs) = nan (tol = 1.000e-10) r (rel) = nan (tol = 1.000e-09)
Newton iteration 35: r (abs) = nan (tol = 1.000e-10) r (rel) = nan (tol = 1.000e-09)
Newton iteration 36: r (abs) = nan (tol = 1.000e-10) r (rel) = nan (tol = 1.000e-09)
Newton iteration 37: r (abs) = nan (tol = 1.000e-10) r (rel) = nan (tol = 1.000e-09)
Newton iteration 38: r (abs) = nan (tol = 1.000e-10) r (rel) = nan (tol = 1.000e-09)
Newton iteration 39: r (abs) = nan (tol = 1.000e-10) r (rel) = nan (tol = 1.000e-09)
Newton iteration 40: r (abs) = nan (tol = 1.000e-10) r (rel) = nan (tol = 1.000e-09)
Newton iteration 41: r (abs) = nan (tol = 1.000e-10) r (rel) = nan (tol = 1.000e-09)
Newton iteration 42: r (abs) = nan (tol = 1.000e-10) r (rel) = nan (tol = 1.000e-09)
Newton iteration 43: r (abs) = nan (tol = 1.000e-10) r (rel) = nan (tol = 1.000e-09)
Newton iteration 44: r (abs) = nan (tol = 1.000e-10) r (rel) = nan (tol = 1.000e-09)
Newton iteration 45: r (abs) = nan (tol = 1.000e-10) r (rel) = nan (tol = 1.000e-09)
Newton iteration 46: r (abs) = nan (tol = 1.000e-10) r (rel) = nan (tol = 1.000e-09)
Newton iteration 47: r (abs) = nan (tol = 1.000e-10) r (rel) = nan (tol = 1.000e-09)
Newton iteration 48: r (abs) = nan (tol = 1.000e-10) r (rel) = nan (tol = 1.000e-09)
Newton iteration 49: r (abs) = nan (tol = 1.000e-10) r (rel) = nan (tol = 1.000e-09)
Newton iteration 50: r (abs) = nan (tol = 1.000e-10) r (rel) = nan (tol = 1.000e-09)
File "ft01_poisson.py", line 35, in <module>
File "/usr/local/lib/python3.6/dist-packages/dolfin/fem/solving.py", line 220, in solve
File "/usr/local/lib/python3.6/dist-packages/dolfin/fem/solving.py", line 266, in _solve_varproblem
solver.solve()
RuntimeError:
*** Error: Unable to solve nonlinear system with NewtonSolver.
*** Reason: Newton solver did not converge because maximum number of iterations reached.
*** Where: This error was encountered inside NewtonSolver.cpp.
*** Process: 0
*** DOLFIN version: 2019.1.0
*** Git changeset: 74d7efe1e84d65e9433fd96c50f1d278fa3e3f3f
What am I doing wrong ?
Thank you for your help
