Hi everyone,
I have previously implemented a nonlinear solver for my flow + temperature coupled problem that works using solve(F, bcs, function). However, now that I am trying to implement AdaptiveNonLinearVariational solver, I need to rewrite the problem in a specific way, and now my previously working things struggle. Particularly when I change coordinate system from Cartesian to Cylindrical. I don’t understand why it doesn’t work when my original implementation works. To illustrate this, I provide a MWE:
Isothermal case - Stokes flow (using Linear solver).
domain = Polygon([Point(0.2, 0), Point(0.2, 1), Point(0.1, 1), Point(0, 1), Point(0, 0)])
mesh = generate_mesh(domain, 60)
# Define Taylor--Hood function space W
V = VectorElement("CG", triangle, 2)
Q = FiniteElement("CG", triangle, 1)
W = FunctionSpace(mesh, MixedElement([V, Q]))
# Define Function and TestFunction(s)
w = TrialFunction(W)
(u, p) = split(w)
(v, q) = split(TestFunction(W))
# Define the viscosity and bcs
mu = Constant(1.0)
# Cartesian velocity that gives mass balance
u_in = Constant(-2.0)
# Cylindric velocity that gives mass balance
u_incyl = Constant(-4.0)
# Wall velocity
u_c = Constant(-1.0)
inflow = 'near(x[1], 1.0) && x[0]<=0.1'
wall = 'near(x[0], 0.2)'
centre = 'near(x[0], 0.0)'
outflow = 'near(x[1], 0.0)'
bcu_inflow = DirichletBC(W.sub(0), (0.0, u_in), inflow)
bcu_inflow_cyl = DirichletBC(W.sub(0), (0.0, u_incyl), inflow)
bcu_wall = DirichletBC(W.sub(0), (0.0, u_c), wall)
bcu_outflow = DirichletBC(W.sub(0), (0.0, u_c), outflow)
bcu_symmetry = DirichletBC(W.sub(0).sub(0), Constant(0.0), centre)
bcs = [bcu_inflow, bcu_wall, bcu_outflow, bcu_symmetry]
bcs_cyl = [bcu_inflow_cyl, bcu_wall, bcu_outflow, bcu_symmetry]
x = SpatialCoordinate(mesh)
def epsilon(v):
return sym(as_tensor([[v[0].dx(0), v[0].dx(1), 0],
[v[1].dx(0), v[1].dx(1), 0],
[0, 0, 0]]))
# symmetric cylindric gradient
def epsilon_cyl(v):
return sym(as_tensor([[v[0].dx(0), 0, v[0].dx(1)],
[0, v[0] / x[0], 0],
[v[1].dx(0), 0, v[1].dx(1)]]))
# stress tensor
def sigma(v, p):
return 2*mu*epsilon(v)-Id(p)
def Id(p):
return as_tensor([[p, 0, 0],
[0, p, 0],
[0, 0, p]])
def cond(v):
return sym(as_tensor([[v[0].dx(0), v[0].dx(1)],
[v[1].dx(0), v[1].dx(1)]]))
def sigmabc(v, p):
return 2*mu*cond(v) - p*Identity(2)
def div_cyl(v):
return (1/x[0])*(x[0]*v[0]).dx(0) + v[1].dx(1)
f = Constant((0, -1))
facet_f = MeshFunction("size_t", mesh, mesh.topology().dim() - 1) # FACET function
CompiledSubDomain('near(x[1], 1.0) && x[0]<=0.1').mark(facet_f, 0)
CompiledSubDomain('near(x[1], 1.0) && x[0]>=0.1').mark(facet_f, 1)
CompiledSubDomain('near(x[0], 0.2)').mark(facet_f, 2) # wall
CompiledSubDomain('near(x[1], 0.0)').mark(facet_f, 3) # outflow
CompiledSubDomain('near(x[0], 0.0)').mark(facet_f, 4)
CompiledSubDomain('near(x[1], 1.0) && x[0]>0.1 && x[0]<0.2').mark(facet_f, 5)
# Create the measure
ds = Measure("ds", domain=mesh, subdomain_data=facet_f)
# Cartesian construction
a = (inner(sigma(u, p), epsilon(v)) - div(u) * q) * dx()
L = (- dot(f, v)) * dx()
# Cylindric construction (multiplied by r )
a_cyl = (inner(sigma(u, p), epsilon_cyl(v)) - div_cyl(u)*q) * x[0] * dx()
L_cyl = (- dot(f, v)) * x[0] * dx()
# Define function for the solution
w = Function(W)
# Solve equation a = L with respect to u and the given boundary conditions
problem = LinearVariationalProblem(a, L, w, bcs)
problem_cyl = LinearVariationalProblem(a_cyl, L_cyl, w, bcs_cyl)
# CHANGE BETWEEN CYL AND CARTESIAN
#solver = LinearVariationalSolver(problem_cyl)
solver = LinearVariationalSolver(problem)
solver.parameters["linear_solver"] = "umfpack"
solver.solve()
(u, p) = w.split()
c = plot(u, title="Velocity")
plt.colorbar(c)
As you can see, I have written it such that if you uncomment the ‘solver’ line as required, you can check that for the Cartesian case it converges, whereas for the Cylindrical case it diverges. I didn’t know how to get the solver to print the Newton iterations, but the plotted velocity is empty in the cylindrical case and non-empty in the Cartesian. (I did check this properly, I just don’t know how to print the iterations to show that Cylindrical goes to nan immediately).
Multiplying by x[0] does work in my other implementation so I don’t think it’s an issue with me changing coordinates. I think I don’t understand ‘LinearVariationalProblem’ and/or ‘LinearVariationalSolver’, and how is it different to just calling solve(), that chooses the solver automatically.
