Hello everyone,
I want to use dolfin_dg to solve the Euler equations. I have been working through the demos to check the convergence rate of the dg method in two dimensions which is done here. My problem is that I am trying to check the convergence with some other manufactured solutions and when using a different solution the solver does not obtain a satisfactory solution or does not converge. For example, when running the code with constant velocities and energy along the domain, the newton method arrives at a NaN for the residue in the first iteration. I attach a MWE and the output (where I erased all the iterations after the first NaN.)
Thanks in advance
from dolfin_dg import *
parameters["ghost_mode"] = "shared_facet"
parameters['form_compiler']['representation'] = 'uflacs'
parameters['form_compiler']["quadrature_degree"] = 8
ele_n = 32
p = 1
# Mesh and function space.
mesh = RectangleMesh(Point(0, 0), Point(.5*pi, .5*pi), ele_n, ele_n, 'right')
V = VectorFunctionSpace(mesh, 'DG', p, dim=4)
# Set up Dirichlet BC
gD = Expression(('sin(x[0])*sin(x[1]) + 2',
'sin(x[0])*sin(x[1]) + 2'),
element=V.ufl_element())
f = Expression(('sin(x[0])*cos(x[1]) + sin(x[1])*cos(x[0])',
'sin(x[0])*cos(x[1]) + sin(x[1])*cos(x[0])'),
u, v = interpolate(gD, V), TestFunction(V)
bo = CompressibleEulerOperator(mesh, V, DGDirichletBC(ds, gD))
residual = bo.generate_fem_formulation(u, v) - inner(f, v)*dx
solve(residual == 0, u)
errorl2 = errornorm(gD, u, norm_type='l2', degree_rise=3)
print(errorl2)
The terminal returns:
No Jacobian form specified for nonlinear variational problem.
Differentiating residual form F to obtain Jacobian J = F’.
Newton iteration 0: r (abs) = 3.445e-04 (tol = 1.000e-10) r (rel) = 1.000e+00 (tol = 1.000e-09)
Newton iteration 1: r (abs) = -nan (tol = 1.000e-10) r (rel) = -nan (tol = 1.000e-09)
File “manufactured_sol_original.py”, line 36, in
File “/usr/lib/petsc/lib/python3/dist-packages/dolfin/fem/solving.py”, line 233, in solve
File “/usr/lib/petsc/lib/python3/dist-packages/dolfin/fem/solving.py”, line 314, in _solve_varproblem
solver.solve()
RuntimeError:
*** Error: Unable to solve nonlinear system with NewtonSolver.
*** Reason: Newton solver did not converge because maximum number of iterations reached.
*** Where: This error was encountered inside NewtonSolver.cpp.
*** Process: 0
*** Git changeset: unknown
