Why i plot displacement arrow graph rather than cloud graph?
hi, everyone.
I want to get the displacement solution and plotting it like Abaqus show. but i got arrow graph when plotting.
set_log_active(False)
L = 1.; H = 1.
Nx = 10; Ny = 10
mesh = RectangleMesh(Point(0., 0.), Point(L, H), Nx, Ny)
nodal_coordinates = mesh.coordinates()
Vm = FunctionSpace(mesh,'DG',1)
W = VectorFunctionSpace(mesh,'P',1)
F = TensorFunctionSpace(mesh, "Lagrange", 2)
u , v = TrialFunction(W), TestFunction(W)
E = 10e3
nu = 0.3
# plane problem type
model = "plane_stress"
# lame's parameters for plane strain
mu = E/2/(1+nu)
lmbda = E*nu/(1+nu)/(1-2*nu)
# lame's parameters for plane stress
if model == "plane_stress":
    lmbda = 2*mu*lmbda/(lmbda+2*mu)
# displacement boundary condition
bottom = CompiledSubDomain("near(x[1], 0) && on_boundary")
left = CompiledSubDomain("near(x[0], 0) && on_boundary")
bc_u = [DirichletBC(W.sub(1), Constant(0.0), bottom),
        DirichletBC(W.sub(0), Constant(0.0), left),]
# traction boundary condition
top = CompiledSubDomain("near(x[1], 1) && on_boundary")
load = Constant((0, 1e-3))
# index boundary no.
boundaries.set_all(0)
top.mark(boundaries,1)
    return 0.5*(nabla_grad(u)+nabla_grad(u).T)
def sigma(u):
    return 2.0*mu*epsilon(u)+lmbda*tr(epsilon(u))*Identity(len(u))
LHS = inner(sigma(u), epsilon(v))*dx
RHS = dot(load, v)*ds(1)
u = Function(W, name="Displacement")
K = assemble(LHS)
f = assemble(RHS)
[bc.apply(K, f) for bc in bc_u]
solve(K,u.vector(),f)
plot(u)
You need to plot the norm since u is a vector field. \| u\| = \sqrt{\sum_{i}u_i^2}
Use
norm_u = sqrt(inner(u,u))
plot(norm_u)
That should give you the result to compare with Abaqus.
thanks, it works but there is no scale bar (showing which colour represent which range data). how ti fix it?
surf = plot(norm_u)
plt.colorbar(surf)
should add the scalar bar.
In general, you can save your solution as a pvd or xdmf-file for post processing with for instance Paraview (this is especially recommended in cases of 3D geometries).
yes, paraview is referable for 3D cases, here, I just want to look around what happen when running code.
hi, I want to change the colour of map like Abaqus. for doing this, i write:
plot(norm_u)
surf = plot(norm_u)
plt.colorbar(surf,cmap='jet')
but i can not get the correct colour.
You need to pass the cmap into the plotting instruction, as in this MWE:
mesh = UnitSquareMesh(10,10)
v = Function(V)
v.vector()[0] = 1
surf = plot(v, cmap=plt.cm.jet)
plt.colorbar(surf)
plt.savefig("u.png")
This is also easy to achieve in Paraview, which offers a large variety of colormaps.
thanks dokken. it works
