Why is it slower to produce a pyvista GIF in .py than in .ipynb?
Dear community,
This example from Jørgen Dokken’s fenicsx tutorial explains how to create a gif directly from a time-dependent problem (in this case the heat equation) using pyvista.
When running the file as a jupyter notebook, I get an output in a few seconds, when I take the exact same code and run it in a .py file, it takes almost a minute. I use the same conda-environment in both cases on a ubuntu machine. All libraries are up to date, as far as I can tell.
Why is that?
(here is the code)
import pyvista
from dolfinx import fem, mesh, io, plot
from dolfinx.fem.petsc import assemble_vector, assemble_matrix, create_vector, apply_lifting, set_bc
# Define temporal parameters
t = 0  # Start time
T = 1.0  # Final time
num_steps = 50
dt = T / num_steps  # time step size
# Define mesh
nx, ny = 50, 50
domain = mesh.create_rectangle(MPI.COMM_WORLD, [np.array([-2, -2]), np.array([2, 2])],
                               [nx, ny], mesh.CellType.triangle)
V = fem.FunctionSpace(domain, ("Lagrange", 1))
# Create initial condition
def initial_condition(x, a=5):
    return np.exp(-a * (x[0]**2 + x[1]**2))
u_n = fem.Function(V)
u_n.name = "u_n"
u_n.interpolate(initial_condition)
# Create boundary condition
boundary_facets = mesh.locate_entities_boundary(
    domain, fdim, lambda x: np.full(x.shape[1], True, dtype=bool))
bc = fem.dirichletbc(PETSc.ScalarType(0), fem.locate_dofs_topological(V, fdim, boundary_facets), V)
# xdmf = io.XDMFFile(domain.comm, "diffusion.xdmf", "w")
# xdmf.write_mesh(domain)
# Define solution variable, and interpolate initial solution for visualization in Paraview
uh = fem.Function(V)
uh.name = "uh"
uh.interpolate(initial_condition)
# xdmf.write_function(uh, t)
f = fem.Constant(domain, PETSc.ScalarType(0))
a = u * v * ufl.dx + dt * ufl.dot(ufl.grad(u), ufl.grad(v)) * ufl.dx
L = (u_n + dt * f) * v * ufl.dx
bilinear_form = fem.form(a)
linear_form = fem.form(L)
A = assemble_matrix(bilinear_form, bcs=[bc])
b = create_vector(linear_form)
solver.setOperators(A)
import matplotlib as mpl
pyvista.start_xvfb()
grid = pyvista.UnstructuredGrid(*plot.vtk_mesh(V))
plotter = pyvista.Plotter()
plotter.open_gif("u_time.gif", fps=10)
grid.point_data["uh"] = uh.x.array
warped = grid.warp_by_scalar("uh", factor=1)
viridis = mpl.colormaps.get_cmap("viridis").resampled(25)
sargs = dict(title_font_size=25, label_font_size=20, fmt="%.2e", color="black",
             position_x=0.1, position_y=0.8, width=0.8, height=0.1)
renderer = plotter.add_mesh(warped, show_edges=True, lighting=False,
                            cmap=viridis, scalar_bar_args=sargs,
                            clim=[0, max(uh.x.array)])
for i in range(num_steps):
    with b.localForm() as loc_b:
        loc_b.set(0)
    assemble_vector(b, linear_form)
    apply_lifting(b, [bilinear_form], [[bc]])
    set_bc(b, [bc])
    # Solve linear problem
    solver.solve(b, uh.vector)
    uh.x.scatter_forward()
    u_n.x.array[:] = uh.x.array
    # Write solution to file
    # Update plot
    plotter.update_coordinates(warped.points.copy(), render=False)
    plotter.update_scalars(uh.x.array, render=False)
    plotter.write_frame()
    print(i)
plotter.close()
# xdmf.close()
