Hi all,
I am solving a two field problem (one vector field, one scalar field) in 3D in parallel. The geometry has two materials in it as shown in the attached picture (PDMS and glass).
Now what I want to do at the output stage is, only write the field data from the PDMS region, to be read in paraview so that glass region appear as holes. I am trying to do this in the following way:
mesh=Mesh("mesh.xml") #mesh defined over the complete geometry: PDMS+glass
Y = FunctionSpace(mesh, "CG", 1)
z = Function(Y) #this is the actual field I solve for
mesh_PDMS=Mesh("mesh_0.xml") #mesh defined only over PDMS region
YR = FunctionSpace(mesh_PDMS, "CG", 1)
zR=Function(YR)
**Solve for z defined in Y**
z.set_allow_extrapolation(True)
assign(zR, project(z,YR, solver_type='cg', preconditioner_type='jacobi'))
file_results = XDMFFile( "result.xdmf" )
file_results.write(zR,step)
So in short, I am using the projection function (i have tried interpolation function too) to extract the values of the field z only in the region containing PDMS. But this process is not working properly. I am not getting the correct values. What is it that I might be doing wrong? And is there a better way to do this?
Thanks,
Aditya
