Wrong cell area computed in parallel
I need area of every cell in the mesh (1st and 2nd order) for the mesh quality calcultion. A DG0 function is used to store area information for every cell in the mesh. However, neither fem.form nor numpy formation works properly in the halo region of each partition in parallel run. Wrong result is shown in the attached figure.
MWE:
# cell_surface.py
# Tested on DOLFINX 0.9.0
# $ mpirun -n 3 python cell_surface.py
from dolfinx import fem, io, mesh
def compute_cell_surface_form(_mesh):
    V_dg = fem.functionspace(_mesh, ("DG", 0))
    v_dg = ufl.TestFunction(V_dg)
    peri_form = fem.form(
        1.0 * v_dg * ufl.ds +
        1.0 * v_dg('+') * ufl.dS +
        1.0 * v_dg('-') * ufl.dS
    peri_vec = fem.assemble_vector(peri_form)
    peri_f = fem.Function(V_dg, name="Cell_Surface_Area")
    peri_f.x.array[:] = peri_vec.array
    peri_f.x.scatter_forward()
    return peri_f
def compute_cell_surface_numpy(_mesh):
    tdim = _mesh.topology.dim
    V_dg0 = fem.functionspace(_mesh, ("DG", 0))
    result_func = fem.Function(V_dg0, name="Cell_Surface_Area")
    num_cells_local = _mesh.topology.index_map(tdim).size_local
    cell_to_vertex = _mesh.topology.connectivity(tdim, 0)
    geometry_coords = _mesh.geometry.x
    local_values = np.zeros(num_cells_local)
    for i in range(num_cells_local):
        v_idx = cell_to_vertex.links(i)
        pts = geometry_coords[v_idx]
        total_measure = 0.0
        if tdim == 3:
            # 3D: Tetrahedron with 4 triangular faces
            faces = [(1,2,3), (0,2,3), (0,1,3), (0,1,2)]
            for f in faces:
                p1, p2, p3 = pts[f[0]], pts[f[1]], pts[f[2]]
                area = 0.5 * np.linalg.norm(np.cross(p2 - p1, p3 - p1))
                total_measure += area
        elif tdim == 2:
            # 2D: Triangle with 3 edges
            edges = [(0,1), (1,2), (2,0)]
            for e in edges:
                p1, p2 = pts[e[0]], pts[e[1]]
                length = np.linalg.norm(p2 - p1)
                total_measure += length
        local_values[i] = total_measure
    result_func.x.array[:num_cells_local] = local_values
    result_func.x.scatter_forward()
    return result_func
if __name__ == "__main__":
    _mesh = mesh.create_unit_square(MPI.COMM_WORLD, 20, 20)
    f1 = compute_cell_surface_form(_mesh)
    f2 = compute_cell_surface_numpy(_mesh)
    with io.XDMFFile(_mesh.comm, "cell_surface_form.xdmf", "w") as xdmf:
        xdmf.write_mesh(_mesh)
        xdmf.write_function(f1)
    with io.XDMFFile(_mesh.comm, "cell_surface_numpy.xdmf", "w") as xdmf:
        xdmf.write_function(f2)
The mistake lies in the fact that the vertices and geometry nodes do not map 1-1.
This can be fixed with the following minimal changes:
    cell_to_vertex = mesh.entities_to_geometry(_mesh, tdim, np.arange(num_cells_local))
        v_idx = cell_to_vertex[i]
        total_measure = 0.0
        if tdim == 3:
            for f in faces:
        elif tdim == 2:
            for e in edges:
    return result_func
Furhtermore, your other function
is missing a scatter_reverse after assembling local contributions. Thus you should do:
    peri_vec.scatter_reverse(la.InsertMode.add)
    return peri_f
This fixes both problems.
Oh, that’s it. I have still being mixing up the concept between topology and geometry since beginning.
Indeed, it outputs values lower than the expected ones in the ghost region as the contribution of remote partition is not made. Unlike the common use of scatter_forward, how and when should we use scatter_reverse?
Scatter reverse is used to accumulate data from local assembly.
I.e. when one has called assemble_vector (and apply_lifting, these operations do no MPI communication. The results for each degree of freedom has to be gathered in the relevant process after these are called).
Oh, one thing to confirm: for the assembly of Ax=bproblem, we always have the callb.ghostUpdate(addv=PETSc.InsertMode.ADD, mode=PETSc.ScatterMode.REVERSE). Is peri_vec.scatter_reverse(la.InsertMode.add) equivalent as we normally do in ghost update of b?
Yes, one is using PETSc’s implementation of ghost updating while the other uses the dolfinx native implementation.
