I am trying to convert my code to parallel programming(was working perfectly on single processor). I am not getting corrected value of mass=Function(W). After calculating mass.x.array, I am using scatter_reverse(la.InsertMode.add) to add all the value at shared nodes but it seems they are not adding up correctly.
Terminal command: mpirun -np 2 python3 test.py
Fenicsx version: 0.9
from dolfinx import mesh, fem, la
from dolfinx.io import XDMFFile, gmshio
import gmsh_api.gmsh as gmsh
def create_cube():
# Gmsh initialization
gmsh.model.add("GradedCube")
gdim = 3
fdim = 2
# mesh refinement
a = 1.0 # for bottom refinement
b = 1.0 # for top refinement
# points
gmsh.model.geo.addPoint(0, 0, 0, lc / a, 1)
gmsh.model.geo.addPoint(1, 0, 0, lc / a, 2)
gmsh.model.geo.addPoint(1, 1, 0, lc / b, 3)
gmsh.model.geo.addPoint(0, 1, 0, lc / b, 4)
gmsh.model.geo.addPoint(0, 0, 1, lc / a, 5)
gmsh.model.geo.addPoint(1, 0, 1, lc / a, 6)
gmsh.model.geo.addPoint(1, 1, 1, lc / b, 7)
gmsh.model.geo.addPoint(0, 1, 1, lc / b, 8)
# lines
gmsh.model.geo.addLine(1, 2, 1)
gmsh.model.geo.addLine(2, 3, 2)
gmsh.model.geo.addLine(3, 4, 3)
gmsh.model.geo.addLine(4, 1, 4)
gmsh.model.geo.addLine(1, 5, 5)
gmsh.model.geo.addLine(5, 6, 6)
gmsh.model.geo.addLine(6, 7, 7)
gmsh.model.geo.addLine(7, 8, 8)
gmsh.model.geo.addLine(8, 5, 9)
gmsh.model.geo.addLine(4, 8, 10)
gmsh.model.geo.addLine(3, 7, 11)
gmsh.model.geo.addLine(2, 6, 12)
# curve loop
gmsh.model.geo.addCurveLoop([1, 12, -6, -5], 1)
gmsh.model.geo.addCurveLoop([12, 7, -11, -2], 2)
gmsh.model.geo.addCurveLoop([11, 8, -10, -3], 3)
gmsh.model.geo.addCurveLoop([10, 9, -5, -4], 4)
gmsh.model.geo.addCurveLoop([8, 9, 6, 7], 5)
gmsh.model.geo.addCurveLoop([3, 4, 1, 2], 6)
# surface
gmsh.model.geo.addPlaneSurface([1], 1)
gmsh.model.geo.addPlaneSurface([2], 2)
gmsh.model.geo.addPlaneSurface([3], 3)
gmsh.model.geo.addPlaneSurface([4], 4)
gmsh.model.geo.addPlaneSurface([5], 5)
gmsh.model.geo.addPlaneSurface([6], 6)
# surface loop
gmsh.model.geo.addSurfaceLoop([5, 3, 2, 1, 6, 4], 1)
# volume
gmsh.model.geo.addVolume([1], 1)
# synchronize
gmsh.model.geo.synchronize()
gmsh.model.addPhysicalGroup(gdim, [1], 1)
gmsh.model.addPhysicalGroup(fdim, [1], 1)
gmsh.model.addPhysicalGroup(fdim, [2], 2)
gmsh.model.addPhysicalGroup(fdim, [3], 3)
gmsh.model.addPhysicalGroup(fdim, [4], 4)
gmsh.model.addPhysicalGroup(fdim, [5], 5)
gmsh.model.addPhysicalGroup(fdim, [6], 6)
# generate a 3D mesh
gmsh.model.mesh.generate(3)
# Convert to Dolfinx
msh, cll_tgs, facet_tgs = gmshio.model_to_mesh(gmsh.model, MPI.COMM_WORLD, 0, gdim) # , partitioner=mesh.GhostMode.shared_facet)
gmsh.finalize()
return msh
def main():
comm = MPI.COMM_WORLD
rank = comm.Get_rank()
size = comm.Get_size()
# create mesh
domain = create_cube()
# Dimension of mesh/domain
dim = domain.topology.dim
# Ensure mesh topology is initialized
domain.topology.create_connectivity(dim, dim - 1)
domain.topology.create_connectivity(dim, 0)
domain.topology.create_connectivity(0, dim)
# Get connectivity matrix
cells_to_vertices = domain.topology.connectivity(dim, 0)
# Number of cells
num_cells = domain.topology.index_map(dim)
# definition of function space
degree = 1
W = fem.functionspace(domain, ("P", degree))
DG = fem.functionspace(domain, ("DG", 0))
mass = fem.Function(W)
# Volume of each cell
cell_volume_form = fem.form(ufl.TestFunction(DG) * ufl.dx)
volumes = fem.assemble_vector(cell_volume_form)
for cell_index in range(num_cells.size_local):
cell_vertices = cells_to_vertices.links(cell_index)
volume = volumes.array[cell_index]
# Calculating mass vector
mass_per_vertex = rho * volume / len(cell_vertices)
mass.x.array[cell_vertices] += mass_per_vertex
mass.x.scatter_reverse(la.InsertMode.add)
mass.x.scatter_forward()
if rank == 0:
fl.write(f"Number of processors: {size}\n")
fl.write(f"Rank {rank}: Mass vector: \n {mass.x.array[:]}\n")
mass_form = fem.form(ufl.TestFunction(W) * rho * ufl.dx)
mass_vector = fem.assemble_vector(mass_form)
mass_vector.scatter_forward()
fl.write(f"Rank {rank}: Mass vector: \n {mass_vector.array[:]} \n")
if __name__ == "__main__":
# Material properties (All in SI units)
rho = 2.0 # Density (g/mm3)
lc = 0.5 # mesh size
# Post-processing .txt file
filepath = "results_new/"
filename = "test"
fl = open(filepath + filename + '.txt', 'a')
main()
I would really appreciate some help to obtain an array that correctly represent the mass vector.
Thank you in advance !
