Dear FEniCS community,
I would like to solve the following partial differential equation (PDE)
v_0 \cos(\theta-\phi) \frac{\partial}{\partial r} T(r, \phi, \theta)+ v_0 \sin(\theta-\phi)\frac{1}{r}\frac{\partial}{\partial \phi} T(r, \phi, \theta) \\\quad+ \gamma v_0 \sin(\theta-\phi)\frac{1}{r}\frac{\partial}{\partial \theta}T(r, \phi, \theta)+ \frac{g}{2} \frac{\partial^2}{\partial \theta^2} T(r,\phi, \theta) = -1
with domain D_{r_0}\times [0, 2\pi], where D_{r_0} is disk with radius r_0.
r and \phi are the polar coordinate of the disk. \theta\in [0,2\pi].
The boundary conditions are Dirichlet boundary conidtion on the disk edge T(r,\phi,\theta)|_{r=r_0} = 0 and periodic boundary conditions with respect to
\phi and \theta, T(r, \phi+2\pi, \theta) = T(r,\phi, \theta+2\pi) = T(r, \phi, \theta).
Below is the code.
import dolfin as df
from math import pi
v0 = 1.
gamma = 7.
g = 10.**3
r0 = 1.0
angle_period = 2*pi
class PeriodicBoundary(df.SubDomain):
return bool((df.near(x[1], 0) or df.near(x[2], angle_period)) and
(not ((df.near(x[1], 0) and df.near(x[2], angle_period)) or
(df.near(x[1], angle_period) and df.near(x[2], 0)))) and
on_boundary)
def map(self, x, y):
if df.near(x[1], angle_period) and df.near(x[2], angle_period):
y[0] = x[0]
y[1] = x[1] - angle_period
y[2] = x[2] - angle_period
elif df.near(x[1], angle_period):
y[0] = x[0]
y[2] = x[2]
else: # near(x[2], 1)
y[0] = x[0]
y[1] = x[1]
# set mesh
nn = 10
nx = nn
ny = nn
nz = nn
# Create mesh and define function spaces
mesh = df.BoxMesh(
df.Point(0., 0., 0.), df.Point(r0, angle_period, angle_period),
nx, ny, nz)
pbc = PeriodicBoundary()
V = df.FunctionSpace(mesh, 'P', 2, constrained_domain=pbc)
# Define boundaries
def outer_boundary(x, on_boundary):
tol = 1.E-14
return df.near(x[0], r0, tol) and on_boundary
bc = df.DirichletBC(V, df.Constant(0), outer_boundary)
u = df.TrialFunction(V)
v = df.TestFunction(V)
xs = df.SpatialCoordinate(mesh)
F = v0*ufl.cos(xs[2]-xs[1])*u.dx(0)*v*xs[0]*df.dx \
+ v0*ufl.sin(xs[2]-xs[1])*u.dx(1)*v*df.dx \
+ v0*gamma*ufl.sin(xs[2]-xs[1])*u.dx(2)*v*df.dx \
- g/2*u.dx(2)*v.dx(2)*xs[0]*df.dx \
+ 1.*v*xs[0]*df.dx
a, L = df.lhs(F), df.rhs(F)
u = df.Function(V)
df.solve(a == L, u, bc)
# verify u is indeed the solution of the pde
w = df.project(
+ v0/xs[0]*ufl.sin(xs[2]-xs[1])*u.dx(1)
+ v0*gamma/xs[0]*ufl.sin(xs[2]-xs[1])*u.dx(2)
+ g/2*u.dx(2).dx(2) + 1.,
V
# expecting w should be near 0.
# however the command below gives the value of w
# [93.26907903 363.77849385 297.36876578 ... -168.24578545 -420.92284536 -1026.43193945]
print(w.compute_vertex_values())
The problem is that FEniCS seems to give incorrect solution to the PDE.
When I substitute the solution back into the PDE, it does not give zero as expected.
How can I solve this problem?
Thank you for your time and consideration.
I am using FEniCS 2019.1.0 installed via conda-forge on Manjaro Linux.
