Hi, I am running a NS problem in a cuboid pipe, essentially using the methods given in the documentation and tutorials, and whenever I open an file in .xdmf Paraview crashes in the Xdmf3ReaderS and Xdmf3ReaderT readers. It opens in the XDMF Reader, but as soon as I try to visualise the results, an error occurs saying it failed to read the data. The error is shown below:
And the following two images show the code which I used to create the .xdmf file:
I have tried Paraview 5.11 and 5.10.0. The same things happens in each release.
Can someone please provide any help with this problem? I have tried only writing into the file the pressure and velocity separately to see if one of the outputs was the problem, but the error occurs whichever is outputted. Thank you.
