Hi, I’m new to Fenics and dG implementation but trying to construct a 1D dG advection/diffusion code using a Robin bc at the inlet and Neumann at the outlet. We are assuming that there is a given velocity prescribed at the inlet and propagated to the outlet (from right to left). I keep getting the error “UFLException: Discontinuous type Argument must be restricted.” and do not understand what this means or what line it is pertaining to. I know it occurs when I try to use solve() but do not know where the issue lies within this command. I have included the code and error output below. Thanks in advance.
import copy
import datetime
import importlib
import json
import networkx as nx
import scipy
import vtk
from graphnics import *
from matplotlib.gridspec import GridSpec
from mpl_toolkits.mplot3d import Axes3D
from scipy.spatial import cKDTree
from vtk.util.numpy_support import vtk_to_numpy
from xii import *
# Mesh
mesh = UnitIntervalMesh(50)
# Function spaces
V_dg = FunctionSpace(mesh,"DG",1)
# Veclocity: set as constant for now
u_constant = Constant(1.0)
u = u_constant
cn = Constant(1.0)
cinlet = Constant(1.0)
# Trial and test functions
c1 = TrialFunction(V_dg)
w = TestFunction(V_dg)
# Diffusion coefficient
gamma = Constant(1.0)
# Time step
dt = Constant(0.01)
# Source term
c = cn/dt
g = Constant(1.0)
# Penalty term
alpha = Constant(1.0)
# Mesh-related functions
h = CellDiameter(mesh)
# Upwind
uv = as_vector((u,))
un = (dot(uv,n) + abs(dot(uv,n)) )/2.0
# Define boundary subdomains
class Left(SubDomain):
class Right(SubDomain):
return on_boundary and near(x[0], 1)
left = Left()
right = Right()
# Mark boundaries
boundaries = MeshFunction('size_t', mesh,mesh.topology().dim()-1)
boundaries.set_all(0)
left.mark(boundaries,0)
right.mark(boundaries,1)
dxLambda = Measure('dx', domain = mesh)
dsLambda = Measure('ds', domain = mesh, subdomain_data = boundaries)
# Bilinear form
a_vol = dot(w,c1/dt)*dxLambda + dot(grad(w),grad(c1)-uv*c1)*dxLambda
a_fac = - dot(avg(grad(w)), jump(c1, n))*dS \
- dot(jump(w, n), avg(grad(c1)))*dS \
+ (alpha('+')/h('+'))*dot(jump(w, n), jump(c1, n))*dS \
+ gamma('+')*dot(grad(w),grad(c1('+')))*dS
a_vel = dot(jump(w), un('+')*c1('+') - un('-')*c1('-'))*dS \
+dot(w,un('-')*c1('-'))*dsLambda(1)
a = a_vol + a_fac + a_vel
# Linear form
L = dot(w,c)*dxLambda + u*cinlet*w*dsLambda(0) + dot(g,w)*dxLambda
# Solution function
ch = Function(V_dg)
solve(a==L, ch)
Error message:
Coefficient(FunctionSpace(None, FiniteElement('Real', None, 0)), 98)
Level 25:FFC: Calling FFC just-in-time (JIT) compiler, this may take some time.
INFO:FFC: Compiling form ffc_form_8d578a6120e21c5936ce97e31284171d8c8980e6
INFO:FFC: Compiler stage 1: Analyzing form(s)
INFO:FFC: -----------------------------------
DEBUG:FFC: Preprocessing form using 'uflacs' representation family.
ERROR:UFL_LEGACY:Discontinuous type Argument must be restricted.
UFLException Traceback (most recent call last)
<ipython-input-7-706dc4a8007f> in <cell line: 125>()
123 #solve(a == L, ch, bc, solver_parameters={"linear_solver": "mumps"})
124 #solver = LUSolver(a==L, "mumps")
--> 125 solve(a==L, ch)
126
27 frames
/usr/local/lib/python3.10/dist-packages/ufl_legacy/log.py in error(self, *message)
156 "Write error message and raise an exception."
157 self._log.error(*message)
--> 158 raise self._exception_type(self._format_raw(*message))
159
160 def begin(self, *message):
