2D Axisymmetric Navier Stokes
I am trying to create a 2d axisymmetric solver for the navier stokes. My formulation is written in cylindrical polar coordinates. I am using the r,z, theta components to forumale the navier stokes. I have the formulation down and written below. I’m having trouble defining the trial and test functions for this problem. I’m hoping to solve for the velocity components of the z-direction(x-axis) and r-direction(yaxis) in separate variational forms. Once solved, I would like it to assembled to one u vector consisting of the z,r (x,y) components. It seems that I will need 3 test functions (ux,uy,p). and 2 trial functions w,q. Any guidance with this will be very helpful. Thank you.
This is what I have so far with the solver.
Define function space for velocity (ux,uy) and pressure (p)
W = VectorFunctionSpace(mesh, ‘P’, 2)
Define function space for system of velocities
P1 = FiniteElement(‘P’, triangle, 1)
element = MixedElement([P1, P1])
Q = FunctionSpace(mesh, ‘P’, 1)
Define boundaries
inflow = ‘near(x[0], 0)’
outflow = ‘near(x[0], 2.2)’
walls = ‘near(x[1], 0) || near(x[1], 0.41)’
cylinder = ‘on_boundary && x[0]>0.1 && x[0]<0.3 && x[1]>0.1 && x[1]<0.3’
Define inflow profile
inflow_profile = (‘400.01.5x[1]*(0.41 - x[1]) / pow(0.41, 2)’, ‘0’)
Define boundary conditions
bcu_inflow = DirichletBC(V, Expression(inflow_profile, degree=2), inflow)
bcu_walls = DirichletBC(V, Constant((0, 0)), walls)
bcu_cylinder = DirichletBC(V, Constant((0, 0)), cylinder)
bcp_outflow = DirichletBC(Q, Constant(0), outflow)
bcu = [bcu_inflow, bcu_walls, bcu_cylinder]
bcp = [bcp_outflow]
Define trial and test functions
w0, w1 = TestFunctions(V)
w = Function(W)
ux, uy = split(u)
p = TrialFunction(Q)
q = TestFunction(Q)
Define functions for solutions at previous and current time steps
u_n = Function(V)
u_ = Function(V)
p_n = Function(Q)
p_ = Function(Q)
ux_n, uy_n = split(u_n)
ux_, uy_ = split(u_)
Define expressions used in variational forms
U = 0.5*(u_n + u)
f = Constant((0, 0))
k = Constant(dt)
mu = Constant(mu)
rho = Constant(rho)
x,y = SpatialCoordinate(mesh)
uy_x = uy.dx(0)
uy_y = uy.dx(1)
ux_x = ux.dx(0)
ux_y = ux.dx(1)
Define symmetric gradient
def epsilon(v):
return sym(as_tensor([[v[0].dx(0), 0, v[0].dx(1)],
[0, v[0]/x[0], 0],
[v[1].dx(0), 0, v[1].dx(1)]]))
Define stress tensor
def sigma(u, p):
return 2muepsilon(u) - p*Identity(3)
F1 = rho*((ux - ux_n) / k)w0dx + rhodot(dot(u_n, nabla_grad(u_n)), w)dx + inner(sigma(U, p_n), epsilon(w))dx + dot(p_nn, w)ds
- dot(mu
nabla_grad(U)n, w)ds - muw0(1/y)ux_ydx
+ rho
((uy - uy_n) / k)w1dx - mu
w1*(1/y)uy_ydx + muw1uy*(1/(y*y))*dx
a1 = lhs(F1)
L1 = rhs(F1)]
Please format your code appropriately, by encapsulating it with ```.
Additionally you should follow the guidelines: Read before posting: How do I get my question answered?
and please also be more specific about what issues you are having. Which part of the variational form
is the source of your trouble?
Finally, please remove the duplicate of this question.
@dokken Sorry about that. I’m new to this forum. I made the changes you requested and will keep those in mind for future post.
Please further specify what your particular issue is.
Where did you obtain this weak formulation from? What is the particular issue with implementation when you compare it to the mathematical formulation?
I created the weak formulation based on the theory of pulsatile flow in a tube.
w = Function(W)
ux, uy = split(u)
q = TestFunction(Q)
I’m don’t know how to define the function space and trial and test functions correctly to solve for the x and y components of velocity separately.
Note that these equations can only be separated if you use a splitting scheme, where p is the pressure from the previous time step. See for instance: https://reader.elsevier.com/reader/sd/pii/S0010465514003786?token=4E5A707EBD45AB8F645727ED5F013CA5DF4F477BA963F410257DB7ED6B4EB08DAEC027F92C17CC69B9706055D271C6FD
