2D buoyancy-driven flow (Boussinesq) through inlet patch at the top wall with circular obstacle in the room
Parameters
rho = 1.0 # density
mu = 0.01 # viscosity
kappa = 0.01 # thermal diffusivity
beta = 0.01 # thermal expansion
g = Constant((0.0, -9.81)) # gravity
T_in = 290.0
T_hot = 310.0
dt = 0.01
t_end = 0.5
Mesh
nx, ny = 40, 40
mesh = UnitSquareMesh(nx, ny)
Function spaces
V = VectorElement(“P”, mesh.ufl_cell(), 2) # velocity
Q = FiniteElement(“P”, mesh.ufl_cell(), 1) # pressure
S = FiniteElement(“P”, mesh.ufl_cell(), 1) # temperature
W = FunctionSpace(mesh, MixedElement([V, Q, S]))
w = Function(W) # current solution
w_n = Function(W) # previous solution
(u, p, T) = split(w)
(u_n, p_n, T_n) = split(w_n)
(v, q, s) = TestFunctions(W)
Boundary conditions
inlet = “near(x[0], 0.0)”
outlet = “near(x[0], 1.0)”
walls = “near(x[1], 0.0) || near(x[1], 1.0)”
bcu_inlet = DirichletBC(W.sub(0), Constant((1.0, 0.0)), inlet)
bcu_walls = DirichletBC(W.sub(0), Constant((0.0, 0.0)), walls)
bcp_outlet = DirichletBC(W.sub(1), Constant(0.0), outlet)
bcT_inlet = DirichletBC(W.sub(2), Constant(T_in), inlet)
bcT_hotwall = DirichletBC(W.sub(2), Constant(T_hot), “near(x[1], 0.0)”)
bcs = [bcu_inlet, bcu_walls, bcp_outlet, bcT_inlet, bcT_hotwall]
Weak forms
Time discretization
u_mid = 0.5*(u + u_n)
T_mid = 0.5*(T + T_n)
Momentum
F_m = rhodot((u - u_n)/dt, v)dx
+ rho
dot(dot(u_mid, nabla_grad(u_mid)), v)dx
+ 2
mu
inner(sym(grad(u_mid)), sym(grad(v)))dx
- div(v)pdx
- q
div(u)dx
- rho
beta*(T_mid - T_in)*dot(g, v)*dx
Energy
F_T = (T - T_n)/dtsdx
+ dot(u_mid, grad(T_mid))sdx
+ kappa*dot(grad(T_mid), grad(s))*dx
F = F_m + F_T
Stabilization (SUPG/PSPG)
h = CellDiameter(mesh)
u_mag = sqrt(dot(u_mid, u_mid) + 1e-10)
tau_m = h/(2.0u_mag) # momentum stabilization
tau_c = h
h/(2.0*kappa) # thermal stabilization
r_m = rho*((u - u_n)/dt + dot(u_mid, nabla_grad(u_mid)))
- div(2musym(grad(u_mid))) + grad(p)
- rhobeta(T_mid - T_in)g
r_T = (T - T_n)/dt + dot(u_mid, grad(T_mid)) - kappa
div(grad(T_mid))
F += tau_m*dot(r_m, dot(u_mid, grad(v)))*dx \
  • tau_cr_Tdot(u_mid, grad(s))*dx
Solve nonlinear system
J = derivative(F, w)
problem = NonlinearVariationalProblem(F, w, bcs, J)
prm = solver.parameters
prm[“nonlinear_solver”] = “newton”
prm[“newton_solver”][“absolute_tolerance”] = 1e-8
prm[“newton_solver”][“relative_tolerance”] = 1e-7
prm[“newton_solver”][“maximum_iterations”] = 25
prm[“newton_solver”][“linear_solver”] = “mumps”
Time stepping
t = 0.0
vtkfile_u = File(“velocity.pvd”)
vtkfile_T = File(“temperature.pvd”)
while t < t_end:
print(f"Time = {t:.3f}")
solver.solve()
(u_sol, p_sol, T_sol) = w.split()
vtkfile_u << (u_sol, t)
vtkfile_T << (T_sol, t)
w_n.assign(w)
My solver keeps getting diverging
Please format you code appropriately with
```python
# Add code here
and also add the output of your program as
```bash
$ Add output here
Python
import os
# Simulation parameters
rho = 1.0
mu = 0.01
U_in = 0.01
dt = 0.001
T = 0.5
num_steps = int(T/dt)
ramp_time = 0.2
# Obstacle
obstacle_center = (0.5, 0.5)
obstacle_radius = 0.1
# Mesh refinement
base_res = 64
refine_radius = 0.15
# Arc inlet parameters
theta_start = 295    # degrees
theta_end = 360  # degrees
inlet_thickness = 0.01
# Create geometry with mshr
domain = Rectangle(Point(0.0, 0.0), Point(1.0, 1.0)) - Circle(Point(*obstacle_center), obstacle_radius, 64)
mesh = generate_mesh(domain, base_res)
# Refine mesh near obstacle
cell_markers = MeshFunction("bool", mesh, mesh.topology().dim())
cell_markers.set_all(False)
for cell in cells(mesh):
    x, y = cell.midpoint().x(), cell.midpoint().y()
    if (x - obstacle_center[0])**2 + (y - obstacle_center[1])**2 < refine_radius**2:
        cell_markers[cell] = True
mesh = refine(mesh, cell_markers)
# Mixed function space
V_elem = VectorElement("P", mesh.ufl_cell(), 2)
Q_elem = FiniteElement("P", mesh.ufl_cell(), 1)
W_elem = MixedElement([V_elem, Q_elem])
W = FunctionSpace(mesh, W_elem)
V_space = W.sub(0).collapse()
Q_space = W.sub(1).collapse()
# ParaView output
os.makedirs("cavity_flow", exist_ok=True)
vtkfile_u = File("cavity_flow/velocity.pvd")
vtkfile_p = File("cavity_flow/pressure.pvd")
# Boundary definitions
tol = 1E-14
class BottomWall(SubDomain):
        return on_boundary and near(x[1],0.0, tol)
class LeftWall(SubDomain):
        return on_boundary and near(x[0],0.0, tol)
class RightWall(SubDomain):
        return on_boundary and near(x[0],1.0, tol)
bottom_wall = BottomWall()
left_wall = LeftWall()
right_wall = RightWall()
# Arc-shaped radial inlet
class RadialArcInlet(UserExpression):
    def __init__(self, center, r_in, theta_start, theta_end, U_in, **kwargs):
        super().__init__(**kwargs)
        self.xc, self.yc = center
        self.r_in = r_in
        self.theta_start = np.deg2rad(theta_start)
        self.theta_end = np.deg2rad(theta_end)
        self.U_in = U_in
    def eval(self, values, x):
        dx = x[0] - self.xc
        dy = x[1] - self.yc
        r = np.sqrt(dx**2 + dy**2)
        if r == 0.0:
            values[0] = values[1] = 0.0
            return
        theta = np.arctan2(dy, dx)
        # Normalize theta to 0-2pi
        if theta < 0.0:
            theta += 2*np.pi
        if self.theta_start <= theta <= self.theta_end and abs(r - self.r_in) <= inlet_thickness:
            values[0] = self.U_in * dx / r
            values[1] = self.U_in * dy / r
            values[0] = 0.0
            values[1] = 0.0
    def value_shape(self):
        return (2,)
# Create inlet expression
inlet_expr = RadialArcInlet(obstacle_center, obstacle_radius, theta_start, theta_end, U_in, degree=2)
# Boundary conditions
bcu_inlet = DirichletBC(W.sub(0), inlet_expr, 'on_boundary')  # Apply to entire boundary; velocity = 0 elsewhere automatically
bcu_bottom = DirichletBC(W.sub(0), Constant((0,0)), bottom_wall)
bcu_left = DirichletBC(W.sub(0).sub(0), Constant(0.0), left_wall)
bcu_right = DirichletBC(W.sub(0).sub(0), Constant(0.0), right_wall)
bcs = [bcu_inlet, bcu_bottom, bcu_left, bcu_right]
# Functions
w = Function(W)
w_n = Function(W)
(u, p) = split(w)
(u_n, p_n) = split(w_n)
(v, q) = TestFunctions(W)
# Initialize velocity + zero pressure
u_init = interpolate(inlet_expr, V_space)
p_init = interpolate(Constant(0.0), Q_space)
assign(w_n, [u_init, p_init])
# Variational form (BDF1)
F = (rho*dot((u - u_n)/dt, v)*dx
     + rho*dot(dot(u_n, nabla_grad(u)), v)*dx
     + mu*inner(grad(u), grad(v))*dx
     - div(v)*p*dx
     + q*div(u)*dx)
# Time-stepping
t = 0.0
for n in range(num_steps):
    ramp_factor = min(1.0, t/ramp_time)
    inlet_expr.U_in = U_in * ramp_factor
    # First step linearization for stability
    if n == 0:
        F_linear = (rho*dot((u - u_n)/dt, v)*dx
                    - div(v)*p*dx
                    + q*div(u)*dx)
        problem = NonlinearVariationalProblem(F_linear, w, bcs, J=derivative(F_linear, w))
        problem = NonlinearVariationalProblem(F, w, bcs, J=derivative(F, w))
    solver.parameters['newton_solver']['absolute_tolerance'] = 1E-8
    solver.parameters['newton_solver']['relative_tolerance'] = 1E-6
    solver.parameters['newton_solver']['maximum_iterations'] = 50
    solver.parameters['newton_solver']['report'] = True
    solver.parameters['newton_solver']['linear_solver'] = 'mumps'
    solver.solve()
    (u_sol, p_sol) = w.split()
    vtkfile_p << (p_sol, t)
    w_n.assign(w)
print("Simulation completed.")
Newton iteration 49: r (abs) = 5.000e-03 (tol = 1.000e-08) r (rel) = 3.768e+00 (tol = 1.000e-06)
Newton iteration 50: r (abs) = 5.129e-03 (tol = 1.000e-08) r (rel) = 3.864e+00 (tol = 1.000e-06)
File “CavityFlow5.py”, line 186, in
solver.solve()
RuntimeError:
*** Error: Unable to solve nonlinear system with NewtonSolver.
*** Reason: Newton solver did not converge because maximum number of iterations reached.
*** Where: This error was encountered inside NewtonSolver.cpp.
*** Process: 0
*** DOLFIN version: 2019.1.0
*** Git changeset: 828b3965c3ebcd128da494c596c78b17c0a303da
A problem here is that you use mshr, which is not available on most systems any more.
Have you considered switching to DOLFINx? As legacy FEniCS has not been maintained for over 5 years now.
Secondly, as your problem runs for a while, have you looked at the solution and seen if you can spot an instability building up in the proximity of the circular object?
