Hi everyone, I’m new from FEniCS.
I’ve already run a 3D a stationary Navier-Stokes simulation. Now, calling x the direction of propagation of the flow and y and z the transversal one, I would like to obtain the flow Q integrating the velocity on a section of my channel defined as:
Q=\int^{h}_{0}\int^{L}_{0} v(x,y,z)dydz
I’m trying to define a 2d surface and integrating with the following code:
class Plane(SubDomain):
return near(x[1], 1162)
facets = MeshFunction("size_t", mesh, mesh.topology().dim()-1)
Plane().mark(facets, 1)
dS = dS(subdomain_data = facets)
n = Constant((0.0,1.0,0.0))
print(dot(u, n))
flux = assemble(dot(u, n)*dS(1))`
where u is the velocity previously obtained. Unfortunately I obtain unreasonable results, can someone help me with the code?
