I have created 3d domain in gmsh and imported it to fenics with help of @dokken. Now, the problem is when I verified mesh file paraview, only one subdomain is imported . But domain contains 4 subdomains.
I am attaching .geo file and fenics code.
// Gmsh project created by Jørgen S. Dokken 2020
SetFactory("OpenCASCADE");
Box(1) = {0, 0, 0, 1, 1, .285};
Box(2) = {0.4, 0.4, 0.285, .2, .2, .03};
Box(3) = {0., 0, 0.315, 1, 1, .01};
Box(4) = {0.0, 0.0, 0.325, 1, 1, 1};
v() = BooleanFragments{ Volume{1}; Delete;}{ Volume{2,3,4}; Delete; };
Physical Volume("air", 1) ={#v()};
Physical Volume("hBN", 2) ={#v()-1};
Physical Volume("cavity", 3) ={#v()-2};
Physical Volume("substrate", 4) ={#v()-3};
Physical Surface("backgate", 5) = {29};
Physical Surface("patterned_gate", 6) = {18, 23};
#msh = meshio.read("revised_3d_model_22.msh")
msh = meshio.read("bokada.msh")
if key == "triangle":
elif key == "tetra":
tetra_data = msh.cell_data_dict["gmsh:physical"][key]
for cell in msh.cells:
if cell.type == "tetra":
tetra_cells = cell.data
elif cell.type == "triangle":
triangle_cells = cell.data
tetra_mesh = meshio.Mesh(points=msh.points, cells={"tetra": tetra_cells},
cell_data={"name_to_read":[tetra_data]})
triangle_mesh =meshio.Mesh(points=msh.points,
meshio.write("plate.xdmf", tetra_mesh)
set_log_level(LogLevel.ERROR)
mesh = Mesh()
with XDMFFile("plate.xdmf") as infile:
infile.read(mesh)
mvc2 = MeshValueCollection("size_t", mesh, 3)
infile.read(mvc2, "name_to_read")
cf = cpp.mesh.MeshFunctionSizet(mesh, mvc2)
