Pygmsh Tutorial?
Hi all,
Is there a tutorial on how to use pygmsh with FEniCS? For example, I have something like:
import pygmsh
-snip-
def generate_box(geom, h1, h2, w):
    lcar = 0.001
    poly = geom.add_polygon(
        [[0.0, 0.0, h1],
         [w, 0.0, h1],
         [w, w, h1],
         [0.0, w, h1]],
        lcar)
    top, volume, lat = geom.extrude(poly.surface, [0, 0, h2-h1])
    bottom = poly.surface
    return [volume,top,bottom]
geom = pygmsh.built_in.Geometry()
-snip-
vol_0,_,_ = generate_box(geom, 0.0, h0, w0)
geom.add_physical(vol_0, label=0)
vol_1,_,_ = generate_box(geom, h0, h1, w0)
geom.add_physical(vol_1, label=1)
-snip-
msh = pygmsh.generate_mesh(geom)
This creates 3D box:es (which I can view in Paraview if I use meshio to write a vtk-file to disk, for example).
How do I make FEniCS understand the mesh with domain/subdomains and how do I set the subdomain properties?
See this post Transitioning from mesh.xml to mesh.xdmf, from dolfin-convert to meshio for many examples. If you downloading the latest version of meshio, see: Transitioning from mesh.xml to mesh.xdmf, from dolfin-convert to meshio (second to last post in this thread)
Thanks for the info! I have looked these links before and tried, for example,
-snip-
meshio.write("mesh.xdmf", meshio.Mesh(points=msh.points, cells={"tetra": msh.cells["tetra"]}))
meshio.write("mf.xdmf", meshio.Mesh(points=msh.points, cells={"triangle": msh.cells["triangle"]},
                                    cell_data={"triangle": {"name_to_read": msh.cell_data["triangle"]["gmsh:physical"]}}))
But I only get errors, like
-snip-
Info    : Done optimizing 3D mesh (0.019183 s)
Info    : 657 vertices 4009 elements
Info    : Writing '/tmp/tmp_l_a2ud8.msh'...
Info    : Done writing '/tmp/tmp_l_a2ud8.msh'
Info    : Stopped on Mon Feb 24 10:58:33 2020
  File "run_single_element.py", line 190, in <module>
TypeError: list indices must be integers or slices, not str
Also, is it possible to convert the “msh” data structure to a FEniCS compatible format directly or do one need to write it to disk and use external tools to convert it?
FEniCS does not support direct import from msh, so you have to rewrite the mesh data. As I pointed out in the last post, if you are using the latest version of meshio, you need to use the following syntax:
msh = meshio.read("mesh.msh")
for cell in msh.cells:
    if cell.type == "triangle":
        triangle_cells = cell.data
    elif  cell.type == "tetra":
        tetra_cells = cell.data
    if key == "triangle":
    elif key == "tetra":
        tetra_data = msh.cell_data_dict["gmsh:physical"][key]
triangle_mesh =meshio.Mesh(points=msh.points,
as meshio changed its user interface recently.
Thank you! Now I can write the two xdmf-files. I still struggle with reading the data back, though. By looking at the link above one should do something like (?):
mesh_file = XDMFFile(self.comm, "mesh.xdmf")
mesh = Mesh()
mesh_file.read(mesh);
mf_file = XDMFFile(self.comm, "mf.xdmf")
mf_file.read(mvc, "name_to_read")
to read the data back which then could be used as if I had used mshr, that is,
  -snip-
  dx = Measure('dx', domain=mesh, subdomain_data=mf)
 boundary_parts = FacetFunction("size_t", mesh)
 boundary_parts.set_all(0)
 -snip-
However, I get an error:
RuntimeError:
*** Error:   Unable to find entity in map.
*** Reason:  Error reading MeshValueCollection.
*** Where:   This error was encountered inside HDF5File.cpp.
*** Process: 0
*** DOLFIN version: 2019.1.0
*** Git changeset:  86617f912d4035520fa988d6af07a19d6069d5ee
To clarify, I don’t generate or read any msh-files directly, I run the pygmsh command:
which returns an “msh” object. I don’t know if that is the same thing as reading an msh-file generated by gmsh (pygmsh generates temporary .geo->.msh files, in /tmp, but the user never see them).
I tried to analyze the contents of the msh, tetra_mesh, and, triangle_mesh objects using the python debugger where I got:
(Pdb) p msh
<meshio mesh object>
  Number of points: 657
  Number of cells:
    triangle: 68
    tetra: 916
    tetra: 204
    tetra: 214
    tetra: 207
    tetra: 213
    tetra: 205
    tetra: 480
  Cell data: gmsh:physical
(Pdb) p triangle_mesh
  Number of cells:
    triangle: 68
  Cell data: name_to_read
(Pdb) p tetra_mesh
  Number of cells:
    tetra: 480
and it looks like only the last Box (corresponding to tetra: 480) can be found in tetra_mesh (I also verified this by opening the mesh.xdmf file in Paraview). I’m also not really sure that this is the way to implement subdomains when using pygmsh.
That is because you are not making your mesh properly in pygmsh. You need to use boolean fragments in 3D (using opencascade and not built_in). Additionaly, some handling of these unions are required when reading in the mesh.
For generating a simple geometry consisting of a box inside another, with unique markers for each box:
import pygmsh
geom = pygmsh.opencascade.Geometry()
box0 =  geom.add_box([0.0, 0, 0], [1, 1, 1], char_length=0.05)
box1 =  geom.add_box([0.25, 0.25, 0.25], [0.4, 0.3, 0.2], char_length=0.05)
frags = geom.boolean_fragments([box0],[box1])
geom.add_raw_code("Physical Volume(1) = {13};")
geom.add_raw_code("Physical Volume(2) = {14};")
msh = pygmsh.generate_mesh(geom, geo_filename = "mesh.msh")
tetra_cells = None
        # Collect the individual meshes
        if tetra_cells is None:
            tetra_cells = np.vstack((tetra_cells, cell.data))
tetra_data = None
    if key == "tetra":
# Create tetra mesh with cell data attached
tetra_mesh = meshio.Mesh(points=msh.points, cells={"tetra": tetra_cells},
                           cell_data={"name_to_read":[tetra_data]})
To load the mesh and corresponding cell_data into dolfin, you can do the following:
from dolfin import MPI, MeshValueCollection, cpp, Mesh, XDMFFile
mesh_file = XDMFFile(MPI.comm_world, "mesh.xdmf")
mesh = Mesh()
mvc = MeshValueCollection("size_t", mesh, 3)
mesh_file.read(mvc, "name_to_read")
Thanks again for the info! I’m starting to have something that runs now and I will try to sum this up when I understand this better here. Just a few more questions:
  1. Why do I need the geom.boolean_fragments([box0],[box1]) call? Is there documentation somewhere where I can get more info on how this really works?
  2. Why do I need the low level
gmsh calls? Doesn’t
geom.add_physical(vol_2, label=2)
do the same thing?
  1. For 2D meshing do I simply replace “tetra” with “triangle” when I loop over the cells and cell_data_dict:s?
  1. So, you need the boolean fragments to make a mesh that respects the boundaries of each of the domains that you are trying to make a union of. See the gmsh-tutorials or Transitioning from mesh.xml to mesh.xdmf, from dolfin-convert to meshio for more info on this subject.
  2. Since you have to use opencascade to be able to make unions of 3D geometries, a lot of the interfacing in pygmsh does not really work. For 3D geometries, I usually use a combination of the Gmsh GUI and pygmsh to script physical labels.
For 2D meshing you can simply replace “tetra” with “triangle”.
