How tom import 3d domain to fenics
I have created the .geo file and a .msh file. How can I import the .msh file to fenics?
// Gmsh project created on Mon Nov  1 20:43:38 2021
SetFactory("OpenCASCADE");
Cylinder(1) = {0, 0, 0, 0, 0, 0.08, 0.03, 2*Pi};
Cylinder(2) = {0, 0, 0.01, 0, 0, 0.07, 0.000895, 2*Pi};
BooleanDifference{ Volume{1}; Delete; }{ Volume{2}; Delete; }
Cylinder(3) = {0, 0, 0.011, 0, 0, 0.069, 0.000595, 2*Pi};
BooleanDifference{ Volume{2}; Delete; }{ Volume{3}; Delete; }
Cone(3) = {0, 0, 0.01, 0, 0, -0.002, 0.000895, 0.0, 2*Pi};
Cylinder(4) = {0, 0, 0.016, 0, 0, 0.001, 0.000595, 2*Pi};
Cylinder(5) = {0, 0, 0.016, 0, 0, 0.001, 0.000470, 2*Pi};
BooleanDifference{ Volume{4}; Delete; }{ Volume{5}; Delete; }
Cylinder(5) = {0, 0, 0.0115, 0, 0, 0.0685, 0.000470, 2*Pi};
Cylinder(6) = {0, 0, 0.011, 0, 0, 0.069, 0.000135, 2*Pi};
BooleanDifference{ Volume{5}; Delete; }{ Volume{6}; Delete; }
Physical Volume(1) = {1};
Physical Volume(2) = {3, 2};
Physical Volume(3) = {4};
Physical Volume(4) = {5};
Physical Surface(5) = {7, 9, 8, 17};
Physical Surface(6) = {29};
Physical Surface(7) = {13, 15, 30, 28, 31, 27, 25, 24, 26};
Physical Curve(8) = {34, 31, 13};
Characteristic Length {6, 5} = 0.3;
Characteristic Length {13, 14, 4, 10, 22, 24, 20, 18, 19, 17, 3, 9, 21, 23} = 0.003;
Characteristic Length {6, 5} = 0.03;
Characteristic Length {13, 4, 14, 10, 22, 24, 18, 20, 17, 19, 23, 21, 9, 3} = 0.003;
See for instance: Unable to read .msh mesh file which contains only rectangular elements - #8 by dokken
Tell me, how can I apply 3d conductor boundary condition to surface 7
Please read the guidelines for posting questions: Read before posting: How do I get my question answered?
and make sure you have made a minimal code example illustrating what you want to achieve and what error message you obtain.
Please also have a look through previously posted questions, as there might already be similar questions that have been answered.
Dear sir,
I have imported 3d .msh file to fenics, but I am not sure whether it is correct or wrong. Please verify my code and mention mistakes if any. Here I am attaching the .geo file and a bit of fenics code.
Please help me
Characteristic Length {13, 4, 14, 10, 3, 9} = 0.003;
Characteristic Length {23, 21, 17, 19, 18, 20, 24, 22} = 0.0003;
Characteristic Length {13, 14, 4, 10, 22, 24, 20, 18, 19, 17, 23, 21, 9, 3} = 0.0003;
and fenics code
    out_mesh = meshio.Mesh(points=mesh.points, cells={cell_type: cells}, cell_data={"name_to_read":[cell_data]})
    if prune_z:
        out_mesh.prune_z_0()
    return out_mesh
#msh = meshio.read("3d_mwamodel.msh")
msh = meshio.read("3d_mwa_geometry_new_4.msh")
#print(msh.cell_data_dict)
triangle_mesh = create_mesh(msh, "triangle", True)
tetra_mesh = create_mesh(msh, "tetra", True)
parameters["allow_extrapolation"] = True
mesh=Mesh()
mvc = MeshValueCollection("size_t", mesh,3)
   infile.read(mesh)
ds = Measure("ds", domain=mesh, subdomain_data=mf)
There is no reason to set the last argument in create_mesh to True as you are working on a 3D geometry.
Please note that you can verify the correctness of the files by opening them in for instance Paraview and visually inspect them.
