I have this geometry which is a patient specific artery with one inlet and two outlets.
I’m trying to run 3D steady Navier stocks to get velocity, I tried to thing one of them is the following nonlinear forum, and also tried the IPC method.
But none of them are converging, the nonlinear method kind of stuck at
and the error almost flattened,
Newton iteration 24: r (abs) = 7.332e-05 (tol = 1.000e-05) r (rel) = 3.905e-06 (tol = 1.000e-08)
this is my script for this one:
import os
import time
# FEniCS SETTINGS
parameters["ghost_mode"] = "shared_facet"
parameters["form_compiler"]["quadrature_degree"] = 2
set_log_level(LogLevel.PROGRESS)
comm = MPI.comm_world
rank = MPI.rank(comm)
def log(msg):
if rank == 0:
print(msg, flush=True)
# USER PARAMETERS
MU = 0.04
RHO = 1.06
NU = MU / RHO
INLET_ID = 1
OUTLET_IDS = [2, 3]
WALL_ID = 4
INLET_U_TARGET = 57.0
NUM_STEPS = 500
MESH_FILE = "Mesh/mesh.xdmf"
FACET_FILE = "Mesh/facet_tags.xdmf"
OUTPUT_FILE = "results/velocity_steady.xdmf"
os.makedirs("results", exist_ok=True)
# HELPER FUNCTIONS
def compute_inlet_normal(coords, domain_center):
log("[NORMAL] Computing inlet normal via PCA")
inlet_center = coords.mean(axis=0)
X = coords - inlet_center
C = np.dot(X.T, X) / float(X.shape[0])
eigvals, eigvecs = np.linalg.eigh(C)
n = eigvecs[:, np.argmin(eigvals)]
n /= np.linalg.norm(n)
if np.dot(n, domain_center - inlet_center) < 0:
n = -n
log("[NORMAL] Flipped normal to point INTO domain")
log(f"[NORMAL] Normal vector = {n}")
return n, inlet_center
class ParabolicInlet(UserExpression):
def __init__(self, center, radius, normal, Umax, **kwargs):
self.c = np.array(center, dtype=float)
self.R = float(radius)
self.n = np.array(normal, dtype=float)
self.Umax = float(Umax)
super().__init__(**kwargs)
def value_shape(self):
return (3,)
def eval(self, values, x):
d = np.array(x) - self.c
rvec = d - np.dot(d, self.n) * self.n
r = np.linalg.norm(rvec)
u_mag = 0.0
if r <= self.R:
u_mag = self.Umax * (1.0 - (r / self.R) ** 2)
values[:] = u_mag * self.n
# LOAD MESH
log("====================================================")
log("[STEP] Loading mesh")
mesh = Mesh()
with XDMFFile(MESH_FILE) as f:
f.read(mesh)
log(f"[MESH] Number of cells : {mesh.num_cells()}")
log(f"[MESH] Number of vertices : {mesh.num_vertices()}")
mvc = MeshValueCollection("size_t", mesh, mesh.topology().dim() - 1)
with XDMFFile(FACET_FILE) as f:
f.read(mvc, "f")
facets = MeshFunction("size_t", mesh, mvc)
log(f"[FACETS] Unique facet IDs found: {np.unique(facets.array())}")
# EXTRACT INLET GEOMETRY
log("[STEP] Extracting inlet geometry")
inlet_facets = np.where(facets.array() == INLET_ID)[0]
log(f"[INLET] Number of inlet facets: {len(inlet_facets)}")
vertex_ids = []
for f in inlet_facets:
vertex_ids.extend(Facet(mesh, int(f)).entities(0))
vertex_ids = np.unique(vertex_ids)
coords = mesh.coordinates()[vertex_ids]
if coords.shape[0] < 3:
raise RuntimeError("[ERROR] Not enough inlet vertices")
domain_center = mesh.coordinates().mean(axis=0)
normal, inlet_center = compute_inlet_normal(coords, domain_center)
radius = np.max(np.linalg.norm(coords - inlet_center, axis=1))
log(f"[INLET] Center = {inlet_center}")
log(f"[INLET] Radius = {radius}")
# FUNCTION SPACES
log("[STEP] Creating function spaces")
V_el = VectorElement("CG", mesh.ufl_cell(), 2)
P_el = FiniteElement("CG", mesh.ufl_cell(), 1)
W = FunctionSpace(mesh, MixedElement([V_el, P_el]))
(v, q) = TestFunctions(W)
w = Function(W)
(u, p) = split(w)
log(f"[DoF] Velocity DoFs : {W.sub(0).dim()}")
log(f"[DoF] Pressure DoFs : {W.sub(1).dim()}")
# BOUNDARY CONDITIONS
log("[STEP] Defining boundary conditions")
inlet_expr = ParabolicInlet(
center=inlet_center,
radius=radius,
normal=normal,
Umax=INLET_U_TARGET,
degree=2
bcs = [
DirichletBC(W.sub(0), inlet_expr, facets, INLET_ID),
DirichletBC(W.sub(0), Constant((0, 0, 0)), facets, WALL_ID),
DirichletBC(W.sub(1), Constant(0.0), facets, OUTLET_IDS[0]),
DirichletBC(W.sub(1), Constant(0.0), facets, OUTLET_IDS[1]),
# VARIATIONAL FORM
log("[STEP] Building variational form")
nu = Constant(NU)
F = (
dot(dot(u, nabla_grad(u)), v) * dx
+ nu * inner(grad(u), grad(v)) * dx
- div(v) * p * dx
- q * div(u) * dx
dw = TrialFunction(W)
dF = derivative(F, w, dw)
problem = NonlinearVariationalProblem(F, w, bcs, dF)
prm = solver.parameters
prm["nonlinear_solver"] = "newton"
prm["newton_solver"]["absolute_tolerance"] = 1e-5
prm["newton_solver"]["relative_tolerance"] = 1e-8
prm["newton_solver"]["maximum_iterations"] = 30
prm["newton_solver"]["linear_solver"] = "gmres"
prm["newton_solver"]["preconditioner"] = "hypre_amg"
# "gmres" # General nonsymmetric (most robust)
# "cg" # Conjugate Gradient (SPD only)
# "bicgstab" # Nonsymmetric, faster but less robust
# "tfqmr" # Similar to BiCGStab
# "minres" # Symmetric indefinite
# "richardson" # Simple iteration (rarely useful alone)
# prm["newton_solver"]["preconditioner"] = "jacobi"
# "jacobi" # Diagonal scaling
# "sor" # Successive over-relaxation
# "ilu" # Incomplete LU (default good choice)
# "icc" # Incomplete Cholesky (SPD only)
# "asm" # Additive Schwarz (domain decomposition)
# "hypre_amg" # Algebraic multigrid (very strong)
# "petsc_amg" # PETSc AMG
# Scability
# prm["newton_solver"]["linear_solver"] = "gmres"
# prm["newton_solver"]["preconditioner"] = "hypre_amg"
prm["newton_solver"]["krylov_solver"]["relative_tolerance"] = 1e-7
# SOLVER LOOP (PER-VELOCITY RAMP TIMING)
log("[STEP] Starting Newton continuation solves")
xdmf = XDMFFile(OUTPUT_FILE)
xdmf.parameters["rewrite_function_mesh"] = False
xdmf.parameters["flush_output"] = True
U_vals = np.linspace(
(1.0 / NUM_STEPS) * INLET_U_TARGET,
INLET_U_TARGET,
NUM_STEPS
global_start_time = time.time()
for i, U in enumerate(U_vals):
inlet_expr.Umax = float(U)
ramp_start_time = time.time()
log("----------------------------------------------------")
log(f"[RAMP] {i+1}/{NUM_STEPS} | Inlet Umax = {U:.6f}")
log("[RAMP] Newton solve starting...")
solver.solve()
ramp_time = time.time() - ramp_start_time
total_time = time.time() - global_start_time
log(f"[TIME] Ramp {i+1} time : {ramp_time:.2f} s")
log(f"[TIME] Total elapsed so far : {total_time:.2f} s")
if i == NUM_STEPS - 1:
u_sol, p_sol = w.split(deepcopy=True)
u_sol.rename("velocity", "velocity")
xdmf.write(u_sol, i)
# DONE
log("[DONE] Steady Navier–Stokes solve completed")
while the IPC method it’s giving me this error
*** Reason: Solution failed to converge in 0 iterations (PETSc reason DIVERGED_NANORINF, residual norm ||r|| = 0.000000e+00).
*** Where: This error was encountered inside PETScKrylovSolver.cpp.
*** Process: 0
*** DOLFIN version: 2018.1.0
*** Git changeset: 9e1777c0df7c762c7230189c87c13fd5ad33a4f0
srun: error: notch482: task 0: Exited with exit code 1
Below is my IPC Script
#!/usr/bin/env python3
# coding: utf-8
import os
import time
# GLOBAL LOGGING HELPERS
def log(msg):
if rank == 0:
def banner(msg):
if rank == 0:
print("\n" + "="*80)
print(msg)
print("="*80 + "\n", flush=True)
# FEniCS SETTINGS
banner("FEniCS INITIALIZATION")
log(f"[MPI] Rank {rank} / {MPI.size(comm)} active")
# USER PARAMETERS
banner("USER PARAMETERS")
MU = 0.04
RHO = 1.06
NU = MU / RHO
INLET_ID = 1
OUTLET_IDS = [2, 3]
WALL_ID = 4
N_RAMP = 100
DT = 1e-4
T_MAX = 10.0
MAX_STEPS = int(np.ceil(T_MAX / DT))
STEADY_TOL = 1e-6
STEADY_STREAK = 300
SAVE_EVERY = 500
PRINT_EVERY = 50
log(f"MU={MU}, RHO={RHO}, NU={NU}")
log(f"INLET_U_TARGET={INLET_U_TARGET}")
log(f"N_RAMP={N_RAMP}")
log(f"DT={DT}, MAX_STEPS={MAX_STEPS}")
log(f"STEADY_TOL={STEADY_TOL}, STEADY_STREAK={STEADY_STREAK}")
# FILES
banner("FILES & DIRECTORIES")
OUT_DIR = "results_unsteady_ramp_VERBOSE"
U_TRANSIENT = os.path.join(OUT_DIR, "velocity_unsteady.xdmf")
U_STEADY = os.path.join(OUT_DIR, "velocity_steady.xdmf")
os.makedirs(OUT_DIR, exist_ok=True)
log(f"MESH_FILE = {MESH_FILE}")
log(f"FACET_FILE = {FACET_FILE}")
log(f"OUT_DIR = {OUT_DIR}")
# LOAD MESH
banner("LOADING MESH")
mesh = Mesh()
with XDMFFile(comm, MESH_FILE) as f:
f.read(mesh)
log(f"[MESH] Cells : {mesh.num_cells()}")
log(f"[MESH] Vertices : {mesh.num_vertices()}")
log(f"[MESH] Dim : {mesh.geometry().dim()}")
with XDMFFile(comm, FACET_FILE) as f:
f.read(mvc, "f")
if rank == 0:
log(f"[FACETS] Unique IDs: {np.unique(facets.array())}")
# INLET GEOMETRY (PCA NORMAL)
banner("INLET GEOMETRY EXTRACTION")
inlet_facet_ids = np.where(facets.array() == INLET_ID)[0]
log(f"[INLET] Number of inlet facets: {len(inlet_facet_ids)}")
vertex_ids = []
for fid in inlet_facet_ids:
vertex_ids.extend(Facet(mesh, int(fid)).entities(0))
log(f"[INLET] Unique inlet vertices: {coords.shape[0]}")
X = coords - coords.mean(axis=0)
C = np.dot(X.T, X) / X.shape[0]
normal = eigvecs[:, np.argmin(eigvals)]
normal /= np.linalg.norm(normal)
if np.dot(normal, domain_center - coords.mean(axis=0)) < 0:
normal *= -1
log("[INLET] Normal flipped to point INTO domain")
radius = np.max(np.linalg.norm(coords - coords.mean(axis=0), axis=1))
log(f"[INLET] Center = {coords.mean(axis=0)}")
log(f"[INLET] Normal = {normal}")
# FUNCTION SPACES
banner("FUNCTION SPACES")
V = VectorFunctionSpace(mesh, "CG", 2)
Q = FunctionSpace(mesh, "CG", 1)
log(f"[DoF] Velocity DoFs = {V.dim()}")
log(f"[DoF] Pressure DoFs = {Q.dim()}")
# Trial/Test
p = TrialFunction(Q)
q = TestFunction(Q)
# Solution fields
u_n = Function(V, name="u_n")
u_t = Function(V, name="u_tent")
u_new = Function(V, name="u")
p_n = Function(Q, name="p_n")
p_ = Function(Q, name="p")
# INLET PROFILE
banner("INLET PROFILE DEFINITION")
self.c = np.array(center)
self.R = radius
self.n = normal
self.Umax = Umax
return (3,)
if r <= self.R:
values[:] = self.Umax * (1 - (r/self.R)**2) * self.n
values[:] = (0,0,0)
center=coords.mean(axis=0),
radius=radius,
normal=normal,
Umax=0.0,
degree=2
log("[INLET] Parabolic profile initialized (Umax=0)")
banner("BOUNDARY CONDITIONS")
bcu = [
DirichletBC(V, inlet_expr, facets, INLET_ID),
DirichletBC(V, Constant((0,0,0)), facets, WALL_ID),
bcp = [DirichletBC(Q, Constant(0.0), facets, i) for i in OUTLET_IDS]
log(f"[BC] Inlet ID = {INLET_ID}")
log(f"[BC] Wall ID = {WALL_ID}")
log(f"[BC] Outlet IDs = {OUTLET_IDS}")
# VARIATIONAL FORMS (IPCS)
banner("VARIATIONAL FORMS (IPCS)")
dt = Constant(DT)
mu = Constant(MU)
rho = Constant(RHO)
nrm = FacetNormal(mesh)
def epsilon(u): return sym(nabla_grad(u))
def sigma(u,p): return 2*mu*epsilon(u) - p*Identity(3)
U_mid = 0.5*(u_n + u)
F1 = (
rho*dot((u-u_n)/dt, v)*dx
+ rho*dot(dot(u_n, nabla_grad(u_n)), v)*dx
+ inner(sigma(U_mid, p_n), epsilon(v))*dx
- dot(mu*nabla_grad(U_mid)*nrm, v)*ds
a1, L1 = lhs(F1), rhs(F1)
a2 = dot(nabla_grad(p), nabla_grad(q))*dx
L2 = dot(nabla_grad(p_n), nabla_grad(q))*dx - (1/dt)*div(u_t)*q*dx
a3 = dot(u, v)*dx
L3 = dot(u_t, v)*dx - dt*dot(nabla_grad(p_ - p_n), v)*dx
log("[FORMS] Assembling matrices...")
A1 = assemble(a1)
A2 = assemble(a2)
A3 = assemble(a3)
for bc in bcu: bc.apply(A1)
for bc in bcp: bc.apply(A2)
log("[FORMS] Matrices assembled and BCs applied")
# OUTPUT
banner("OUTPUT FILES")
xdmf = XDMFFile(comm, U_TRANSIENT)
xdmf_steady = XDMFFile(comm, U_STEADY)
xdmf_steady.parameters["flush_output"] = True
xdmf_steady.parameters["rewrite_function_mesh"] = False
# TIME LOOP
banner("STARTING TIME LOOP (RAMP → STEADY)")
u_prev = u_n.vector().copy()
steady_count = 0
t = 0.0
for step in range(MAX_STEPS):
inlet_expr.Umax = (
INLET_U_TARGET*(step+1)/N_RAMP if step < N_RAMP else INLET_U_TARGET
# Step 1
b1 = assemble(L1)
for bc in bcu: bc.apply(b1)
solve(A1, u_t.vector(), b1, "gmres", "hypre_amg")
# Step 2
b2 = assemble(L2)
for bc in bcp: bc.apply(b2)
solve(A2, p_.vector(), b2, "gmres", "hypre_amg")
# Step 3
b3 = assemble(L3)
solve(A3, u_new.vector(), b3, "cg", "sor")
# Steady detection
du = u_new.vector().copy()
du.axpy(-1.0, u_prev)
rel = du.norm("l2") / max(u_new.vector().norm("l2"), 1e-30)
if step >= N_RAMP and rel < STEADY_TOL:
steady_count += 1
steady_count = 0
if step % PRINT_EVERY == 0:
log(f"[STEP {step:6d}] "
f"Uin={inlet_expr.Umax:7.3f} | "
f"rel={rel:.2e} | "
f"streak={steady_count:4d} | "
f"u_max={u_new.vector().get_local().max():.3e}")
if step % SAVE_EVERY == 0:
xdmf.write(u_new, t)
if steady_count >= STEADY_STREAK:
banner("STEADY STATE REACHED")
log(f"Step = {step}")
log(f"Relative change = {rel}")
break
u_prev = u_new.vector().copy()
u_n.assign(u_new)
p_n.assign(p_)
t += DT
# FINAL OUTPUT
banner("WRITING FINAL STEADY FIELD")
u_new.rename("velocity", "velocity")
xdmf_steady.write(u_new, t)
elapsed = time.time() - start_time
log(f"[DONE] Total wall time = {elapsed:.2f} s")
banner("SIMULATION COMPLETE")
I also got the mesh from Simvascular and converted it into .xdmf
