Odd convergence properties for IPCS scheme with N-S lid driven cavity flow
Hi!
I have been toying around with Jorgen’s IPCS schemes (from his tutorial) for the Navier-Stokes equation and was evaluating their performance on the lid-driven cavity flow benchmark (see https://doi.org/10.1115/1.4052149). While I am able to obtain qualitatively accurate results that look fine, the convergence seems quite suspect:
The solver code I have implemented is transient, so I tested the simulation time to check if I have actually reached steady state and this was not the source of the issue. I have also compared the simulation results to other benchmarks in the literature and observed similar behavior. I also used the 2D CFL number to set the dt for the simulation with a CFL of 0.5.
Would appreciate any insight that anyone may have!
Lid‐driven cavity IPCS in DOLFINx, with center‐line sampling of u and p
moved inside the solver function.  Uses Marchi et al, 2021 Tables 20 & 21
for reference.
from pathlib import Path
from dolfinx.fem import (Constant, Function, functionspace,
                         dirichletbc, locate_dofs_geometrical,
                         form, Expression)
from dolfinx.fem.petsc import (assemble_matrix, assemble_vector,
                               apply_lifting, create_vector, set_bc)
from dolfinx.mesh import create_unit_square
from basix.ufl import element
from ufl import (FacetNormal, Identity, TestFunction, TrialFunction,
                 div, dot, ds, dx, inner, lhs, nabla_grad, rhs, sym)
from dolfinx import geometry
#formatting
plt.rcParams["text.usetex"] = True
plt.rc('font', family='serif')
# ————— Reference data from Tables 9 & 10 —————
y_ref   = np.array([0.0546875, 0.0625, 0.0703125, 0.1015625,0.125,0.171875,0.1875,
                    0.25,0.28125,0.3125,0.375,0.4375,0.453125,0.5,0.5625,0.6171875,
                    0.625,0.6875,0.734375,0.75,0.8125,0.8515625,0.875,
                    0.9375,0.953125,0.9609375,0.96875,0.9765625])
u_ref = np.array([-1.8125321e-1,-2.023291e-1,-2.229271e-1,-3.003688e-1,-3.478431e-1,-3.885676e-1,-3.844078e-1,
                  -3.1894525e-1,-2.8042785e-1,-2.4569306e-1,-1.8373161e-1,-1.2341016e-1, -1.0817529e-1,-6.205605e-2,5.6167e-4,
                  5.700436e-2,6.524839e-2,1.3357199e-1,1.8864358e-1,2.0791378e-1,2.884412e-1,3.371763e-1,3.625438e-1,
                  4.229307e-1,4.724491e-1,5.171830e-1,5.803655e-1,6.6397203e-1])
x_ref = np.array([
    0.0625,   0.0703125, 0.078125,   0.09375,
    0.125,    0.15625,   0.1875,    0.2265625,
    0.234375, 0.25,      0.3125,    0.375,
    0.4375,   0.5,       0.5625,    0.625,
    0.6875,   0.75,      0.8046875, 0.8125,
    0.859375, 0.875,     0.90625,   0.9375,
    0.9453125,0.953125,  0.9609375, 0.96875
v_ref = np.array([
    2.807042e-1,   2.962922e-1,   3.099493e-1,   3.329768e-1,
    3.650400e-1,   3.769157e-1,   3.678512e-1,   3.340319e-1,
    3.253866e-1,   3.0710340e-1,  2.3126780e-1,  1.6056381e-1,
    0.9296911e-1,  2.5799473e-2,  -4.184046e-2,   -1.1079783e-1,
    -1.8167907e-1,  -2.533806e-1,   -3.201954e-1,   -3.31565806e-1,
    -4.263892e-1,   -4.677741e-1,   -5.264155e-1,   -4.561505e-1,
    -4.102923e-1,   -3.551312e-1,   -2.933786e-1,   -2.283407e-1
def sample_function_at_points(mesh, func, phys_points):
    # build bounding‐box tree
    bb = geometry.bb_tree(mesh, mesh.topology.dim)
    # find candidate cells for each point (points as 3×N in tutorial, so transpose)
    candidates = geometry.compute_collisions_points(bb, phys_points)
    # filter to actual containing cells
    colliding  = geometry.compute_colliding_cells(mesh, candidates, phys_points)
    pts_on_proc, cells, indices = [], [], []
    for i, p in enumerate(phys_points):
        links = colliding.links(i)
        if len(links) > 0:
            pts_on_proc.append(p)
            cells.append(links[0])
            indices.append(i)
    if not pts_on_proc:
        # no sample on this rank
        return np.full(len(phys_points), np.nan)
    pts_on_proc = np.array(pts_on_proc, dtype=np.float64)
    cells       = np.array(cells, dtype=np.int32)
    # evaluate your FE function
    vals = func.eval(pts_on_proc, cells)
    # flatten scalar result
    if vals.ndim == 2 and vals.shape[1] == 1:
        vals = vals[:, 0]
    # reassemble full‐length array
    if vals.ndim == 1:
        full = np.full(len(phys_points), np.nan)
        for idx, v in zip(indices, vals):
            full[idx] = v
        # vector case
        dim = vals.shape[1]
        full = np.full((len(phys_points), dim), np.nan)
            full[idx, :] = v
    return full
def solve_lid_cavity(Nx, T, Re):
    #Set up time stepping
    Re      = Re
    CFL     = 0.5
    T       = T
    stride  = 50
    nu_val  = 1.0 / Re
    Nx=Ny = Nx
    #Set up mesh
    domain = create_unit_square(MPI.COMM_WORLD, Nx, Ny)
    v_cg2 = element("Lagrange", domain.topology.cell_name(), 2, shape=(domain.geometry.dim, ))
    s_cg1 = element("Lagrange", domain.topology.cell_name(), 1)
    V = functionspace(domain, v_cg2)
    Q = functionspace(domain, s_cg1)
    coords = domain.geometry.x
    xs = np.unique(coords[:, 0]); ys = np.unique(coords[:, 1])
    dxs = float(np.min(np.diff(np.sort(xs))))
    dy = float(np.min(np.diff(np.sort(ys))))
    dt_value = CFL * (dxs * dy) / (dxs + dy)
    dt = PETSc.ScalarType(dt_value)
    dt_const = Constant(domain, dt)
    nu_const = Constant(domain, PETSc.ScalarType(nu_val))
    p = TrialFunction(Q)
    q = TestFunction(Q)
    def top(x): return np.isclose(x[1], 1.0)
    def walls(x):
        return np.logical_or(
            np.isclose(x[1], 0.0),
            np.logical_or(np.isclose(x[0], 0.0), np.isclose(x[0], 1.0))
    wall_dofs = locate_dofs_geometrical(V, walls)
    u_noslip = np.array((0.0,)*domain.geometry.dim, dtype=PETSc.ScalarType)
    bc_walls = dirichletbc(u_noslip, wall_dofs, V)
    lid_dofs = locate_dofs_geometrical(V, top)
    u_lid   = np.array((1.0, 0.0), dtype=PETSc.ScalarType)
    bc_lid   = dirichletbc(u_lid, lid_dofs, V)
    bcs_u = [bc_lid, bc_walls]
    p_dofs   = locate_dofs_geometrical(
        Q, lambda x: np.logical_and(np.isclose(x[0], 0.0),
                                     np.isclose(x[1], 0.0))
    bc_p     = [dirichletbc(Constant(domain, 0.0),p_dofs, Q)]
    u_n = Function(V)
    u_  = Function(V)
    p_n = Function(Q)
    p_  = Function(Q)
    n = FacetNormal(domain)
    U = 0.5*(u_n + u)
    f = Constant(domain, PETSc.ScalarType((0, 0)))
        return sym(nabla_grad(u))
    def sigma(u, p):
        return 2 * nu_const * epsilon(u) - p * Identity(len(u))
    F1 = dot((u - u_n) / dt_const, v) * dx
    F1 += dot(dot(u_n, nabla_grad(u_n)), v) * dx
    F1 += inner(sigma(U, p_n), epsilon(v)) * dx
    F1 -= dot(f, v) * dx
    a1 = form(lhs(F1))
    L1 = form(rhs(F1))
    A1 = assemble_matrix(a1, bcs=bcs_u)
    A1.assemble()
    b1 = create_vector(L1)
    F2 = (dot(nabla_grad(p - p_n), nabla_grad(q))*dx
        +(1/dt_const)*div(u_)*q*dx
    a2, L2 = form(lhs(F2)), form(rhs(F2))
    A2 = assemble_matrix(a2, bcs=bc_p)
    A2.assemble()
    b2 = create_vector(L2)
    F3 = dot(u, v)*dx + dt_const*dot(nabla_grad(p_ - p_n), v)*dx
    F3 -= dot(u_, v)*dx
    a3, L3 = form(lhs(F3)), form(rhs(F3))
    A3 = assemble_matrix(a3)
    A3.assemble()
    b3 = create_vector(L3)
    solver1 = PETSc.KSP().create(domain.comm)
    solver1.setOperators(A1)
    pc1 = solver1.getPC()
    pc1.setHYPREType("boomeramg")
    solver2 = PETSc.KSP().create(domain.comm)
    solver2.setOperators(A2)
    solver2.setType(PETSc.KSP.Type.BCGS)
    pc2 = solver2.getPC()
    pc2.setHYPREType("boomeramg")
    solver3 = PETSc.KSP().create(domain.comm)
    solver3.setOperators(A3)
    pc3 = solver3.getPC()
    u_n.interpolate(lambda x: (np.zeros_like(x[0]), np.zeros_like(x[0])))
    p_n.interpolate(lambda x: np.zeros_like(x[0]))
    step = 0
    t = 0.0
    while t < T - 1e-6:
        t += float(dt)
        print(t)
        with b1.localForm() as loc_1:
            loc_1.set(0)
        assemble_vector(b1, L1)
        apply_lifting(b1, [a1], [bcs_u])
        b1.ghostUpdate(addv=PETSc.InsertMode.ADD,
                       mode=PETSc.ScatterMode.REVERSE)
        set_bc(b1, bcs_u)
        solver1.solve(b1, u_.x.petsc_vec)
        u_.x.scatter_forward()
        with b2.localForm() as loc_2:
            loc_2.set(0)
        assemble_vector(b2, L2)
        apply_lifting(b2, [a2], [bc_p])
        b2.ghostUpdate(addv=PETSc.InsertMode.ADD,
        set_bc(b2, bc_p)
        solver2.solve(b2, p_.x.petsc_vec)
        p_.x.scatter_forward()
        with b3.localForm() as loc_3:
            loc_3.set(0)
        assemble_vector(b3, L3)
        b3.ghostUpdate(addv=PETSc.InsertMode.ADD,
        solver3.solve(b3, u_.x.petsc_vec)
        u_n.x.array[:] = u_.x.array[:]
        p_n.x.array[:] = p_.x.array[:]
        step += 1
    b1.destroy()
    b2.destroy()
    b3.destroy()
    solver1.destroy()
    solver2.destroy()
    solver3.destroy()
    # ————— sample at final time —————
    mesh = u_n.function_space.mesh
    # coarse points for error
    if MPI.COMM_WORLD.rank == 0:
        phys_u     = np.column_stack([0.5*np.ones_like(y_ref), y_ref,     np.zeros_like(y_ref)])
        phys_v     = np.column_stack([x_ref,               0.5*np.ones_like(x_ref), np.zeros_like(x_ref)])
        # fine points for plotting
        y_plot     = np.linspace(0.0, 1.0, 100)
        x_plot     = np.linspace(0.0, 1.0, 100)
        phys_u_f   = np.column_stack([0.5*np.ones_like(y_plot), y_plot, np.zeros_like(y_plot)])
        phys_v_f   = np.column_stack([x_plot, 0.5*np.ones_like(x_plot), np.zeros_like(x_plot)])
        phys_u = phys_v = phys_u_f = phys_v_f = np.empty((0,3), dtype=np.float64)
    # coarse samples
    u_vals   = sample_function_at_points(mesh, u_n, phys_u)[:,0]
    p_u_vals = sample_function_at_points(mesh, p_n, phys_u)
    v_vals   = sample_function_at_points(mesh, u_n, phys_v)[:,1]
    p_v_vals = sample_function_at_points(mesh, p_n, phys_v)
    # fine samples for smooth plotting
    u_plot   = sample_function_at_points(mesh, u_n, phys_u_f)[:,0]
    v_plot   = sample_function_at_points(mesh, u_n, phys_v_f)[:,1]
    return (
        u_vals, p_u_vals,    # coarse (y_ref/x_ref) samples
        v_vals, p_v_vals,
        y_plot, x_plot,      # the fine grids
        u_plot, v_plot,dxs       # smooth samples on the fine grids
if __name__ == "__main__":
    comm = MPI.COMM_WORLD
    rank = comm.rank
    Nx_list = [20,40,50]
    u_plot_list, v_plot_list = [], []
    dx_list = []
    du_list, dv_list = [], []
    err_L2_u, err_inf_u = [], []
    err_L2_v, err_inf_v = [], []
    for Nx in Nx_list:
        print(f"\nRunning Nx={Nx}")
        (u_vals, pu_vals,
            v_vals, pv_vals,
            y_plot, x_plot,
            u_plot, v_plot,dxs) = solve_lid_cavity(Nx, 40.0, 1000.0)
        du = u_vals - u_ref
        dv = v_vals - v_ref
        u_plot_list.append(u_plot)
        v_plot_list.append(v_plot)
        du_list.append(du)
        dv_list.append(dv)
        dx_list.append(dxs)
        err_L2_u.append(np.sqrt(np.mean(du**2)))
        err_inf_u.append(np.max(np.abs(du)))
        err_L2_v.append(np.sqrt(np.mean(dv**2)))
        err_inf_v.append(np.max(np.abs(dv)))
    if rank == 0:
        fig, axs = plt.subplots(2, 2, figsize=(12, 8))
        # Top‐left: Table 9 reference and simulations
        axs[0, 0].scatter(y_ref, u_ref, marker='o', color='k', label='Reference')
        for Nx, u_plot, dxs in zip(Nx_list, u_plot_list, dx_list):
            axs[0, 0].plot(y_plot, u_plot, '-', label=rf'$\Delta x={dxs:.4f}$')
        axs[0, 0].set_xlabel('y')
        axs[0, 0].set_ylabel('u')
        axs[0, 0].set_title(r'$u_{x}$ along x=0.5')
        axs[0, 0].legend()
        # Top‐right: Table 10 reference and simulations
        axs[0, 1].scatter(x_ref, v_ref, marker='o', color='k', label='Reference')
        for Nx, v_plot, dxs in zip(Nx_list, v_plot_list, dx_list):
            axs[0, 1].plot(x_plot, v_plot, '-', label=rf'$\Delta x={dxs:.4f}$')
        axs[0, 1].set_xlabel('x')
        axs[0, 1].set_ylabel('v')
        axs[0, 1].set_title(r'$u_{y}$ along y=0.5')
        axs[0, 1].legend()
        # Bottom‐left: Error metrics for u (RMSE & max abs vs Nx)
        axs[1, 0].plot(dx_list, err_L2_u, 'o-', label='RMSE')
        axs[1, 0].plot(dx_list, err_inf_u, 's--', label='MAE')
        axs[1, 0].set_xlabel(r'$\Delta x$')
        axs[1, 0].set_ylabel('Error')
        # axs[1, 0].set_title('Error metrics: Horizontal velocity')
        axs[1,0].set_yscale("log")
        axs[1,0].set_xscale("log")
        axs[1, 0].legend()
        # Bottom‐right: Error metrics for v (RMSE & max abs vs Nx)
        axs[1, 1].plot(dx_list, err_L2_v, 'o-', label='RMSE')
        axs[1, 1].plot(dx_list, err_inf_v, 's--', label='MAE')
        axs[1, 1].set_xlabel(r'$\Delta x$')
        axs[1, 1].set_ylabel('Error')
        axs[1,1].set_yscale("log")
        axs[1,1].set_xscale("log")
        # axs[1, 1].set_title('Error metrics: Vertical velocity')
        axs[1, 1].legend()
        plt.tight_layout()
        plt.savefig("ipcs_a_liddriven.png",dpi=300)
Is this working with the «first» navier stokes splitting scheme, ie Test problem 1: Channel flow (Poiseuille flow) — FEniCSx tutorial
I would recommend Test problem 2: Flow past a cylinder (DFG 2D-3 benchmark) — FEniCSx tutorial for reasons explained in Splitting schemes — Oasisx
Hi @dokken Thanks for the follow up.
I have similarly tested your channel flow benchmark and it yielded similarly strange results:
I have adapted your code (similarly using CFL = 0.5 for the 2D CFL number to specify dt):
from dolfinx.fem import Constant, Function, functionspace, assemble_scalar, dirichletbc, form, locate_dofs_geometrical
from dolfinx.fem.petsc import assemble_matrix, assemble_vector, apply_lifting, create_vector, set_bc
def evaluate_error(N):
    mesh = create_unit_square(MPI.COMM_WORLD, N, N)
    #Evaluate dx, dt base on CFL
    CFL     = 0.5
    T       = 5
    t=0
    coords = mesh.geometry.x
    dt = CFL * (dxs * dy) / (dxs + dy)
    num_steps = int(T/dt)+1
    v_cg2 = element("Lagrange", mesh.topology.cell_name(), 2, shape=(mesh.geometry.dim, ))
    s_cg1 = element("Lagrange", mesh.topology.cell_name(), 1)
    V = functionspace(mesh, v_cg2)
    Q = functionspace(mesh, s_cg1)
    q = TestFunction(Q)
    def walls(x):
        return np.logical_or(np.isclose(x[1], 0), np.isclose(x[1], 1))
    u_noslip = np.array((0,) * mesh.geometry.dim, dtype=PETSc.ScalarType)
    bc_noslip = dirichletbc(u_noslip, wall_dofs, V)
    def inflow(x):
        return np.isclose(x[0], 0)
    inflow_dofs = locate_dofs_geometrical(Q, inflow)
    bc_inflow = dirichletbc(PETSc.ScalarType(8), inflow_dofs, Q)
    def outflow(x):
        return np.isclose(x[0], 1)
    outflow_dofs = locate_dofs_geometrical(Q, outflow)
    bc_outflow = dirichletbc(PETSc.ScalarType(0), outflow_dofs, Q)
    bcu = [bc_noslip]
    bcp = [bc_inflow, bc_outflow]
    u_n = Function(V)
    u_n.name = "u_n"
    U = 0.5 * (u_n + u)
    f = Constant(mesh, PETSc.ScalarType((0, 0)))
    mu = Constant(mesh, PETSc.ScalarType(1))
    rho = Constant(mesh, PETSc.ScalarType(1))
    # Define strain-rate tensor
    # Define stress tensor
    def sigma(u, p):
        return 2 * mu * epsilon(u) - p * Identity(len(u))
    # Define the variational problem for the first step
    p_n = Function(Q)
    p_n.name = "p_n"
    F1 = rho * dot((u - u_n) / k, v) * dx
    F1 += rho * dot(dot(u_n, nabla_grad(u_n)), v) * dx
    F1 += dot(p_n * n, v) * ds - dot(mu * nabla_grad(U) * n, v) * ds
    a1 = form(lhs(F1))
    L1 = form(rhs(F1))
    A1 = assemble_matrix(a1, bcs=bcu)
    A1.assemble()
    u_ = Function(V)
    a2 = form(dot(nabla_grad(p), nabla_grad(q)) * dx)
    L2 = form(dot(nabla_grad(p_n), nabla_grad(q)) * dx - (rho / k) * div(u_) * q * dx)
    A2.assemble()
    p_ = Function(Q)
    a3 = form(rho * dot(u, v) * dx)
    L3 = form(rho * dot(u_, v) * dx - k * dot(nabla_grad(p_ - p_n), v) * dx)
    A3.assemble()
    # Solver for step 1
    solver1 = PETSc.KSP().create(mesh.comm)
    # Solver for step 2
    solver2 = PETSc.KSP().create(mesh.comm)
    # Solver for step 3
    solver3 = PETSc.KSP().create(mesh.comm)
    def u_exact(x):
        values = np.zeros((2, x.shape[1]), dtype=PETSc.ScalarType)
        values[0] = 4 * x[1] * (1.0 - x[1])
        return values
    u_ex = Function(V)
    u_ex.interpolate(u_exact)
    L2_error = form(dot(u_ - u_ex, u_ - u_ex) * dx)
    for i in range(num_steps):
        # Update current time step
        # Step 1: Tentative veolcity step
            loc_1.set(0)
        set_bc(b1, bcu)
        # Step 2: Pressure corrrection step
            loc_2.set(0)
        set_bc(b2, bcp)
            loc_3.set(0)
        # Compute error at current time-step
        error_L2 = np.sqrt(mesh.comm.allreduce(assemble_scalar(L2_error), op=MPI.SUM))
        error_max = mesh.comm.allreduce(np.max(u_.x.petsc_vec.array - u_ex.x.petsc_vec.array), op=MPI.MAX)
        # Print error only every 20th step and at the last step
        if (i % 20 == 0):
            print(f"Time {t:.2f}, L2-error {error_L2:.2e}, Max error {error_max:.2e}")
    b1.destroy()
    b2.destroy()
    b3.destroy()
    solver1.destroy()
    solver2.destroy()
    solver3.destroy()
    return error_L2, dxs
Loop
Ns = [10,20,25,40,50]
results = []
dxs_ = []
for N in Ns:
    err, dxs = evaluate_error(N)
    results.append(err)
    dxs_.append(dxs)
plt.figure(figsize=(5,4))
plt.loglog(dxs_,results, marker="o")
plt.xlabel("Mesh spacing h")
plt.ylabel(r"$\|u - u_{\mathrm{exact}}\|_{L^2(\Omega)}$")
plt.title("L2 error vs mesh spacing")
plt.grid(False)
plt.tight_layout()
plt.savefig("channel_benchmark.png",dpi=300)
I have also tested the scheme developed in your second test problem and it performs similarly strangely.
for reference.
                         form, Expression)
                 div, dot, ds, dx, inner, lhs, nabla_grad, rhs, sym, grad)
#formatting
x_ref = np.array([
v_ref = np.array([
        if len(links) > 0:
            indices.append(i)
    if not pts_on_proc:
        vals = vals[:, 0]
    if vals.ndim == 1:
            full[idx] = v
        # vector case
        dim = vals.shape[1]
            full[idx, :] = v
    return full
    Re      = Re
    CFL     = 0.5
    T       = T
    stride  = 50
    nu_val  = 1.0 / Re
    Nx=Ny = Nx
    #Set up mesh
    def walls(x):
    u_ = Function(V)
    u_.name = "u"
    u_s = Function(V)
    u_n = Function(V)
    u_n1 = Function(V)
    q = TestFunction(Q)
    p_ = Function(Q)
    p_.name = "p"
    phi = Function(Q)
    F1 += inner(dot(1.5 * u_n - 0.5 * u_n1, 0.5 * nabla_grad(u + u_n)), v) * dx
    F1 += 0.5 * nu_const * inner(grad(u + u_n), grad(v)) * dx - dot(p_, div(v)) * dx
    a1 = form(lhs(F1))
    L1 = form(rhs(F1))
    A1.assemble()
    a2 = form(dot(grad(p), grad(q)) * dx)
    L2 = form((-1/dt_const) * dot(div(u_s), q) * dx)
    A2.assemble()
    F3 = dot(u, v)*dx + dt_const*dot(nabla_grad(phi), v)*dx
    F3 -= dot(u_s, v)*dx
    A3.assemble()
    pc1.setType(PETSc.PC.Type.JACOBI)
    step = 0
    t = 0.0
    while t < T - 1e-6:
        t += float(dt)
        print(t)
            loc_1.set(0)
        set_bc(b1, bcs_u)
        solver1.solve(b1, u_s.x.petsc_vec)
        u_s.x.scatter_forward()
            loc_2.set(0)
        set_bc(b2, bc_p)
        solver2.solve(b2, phi.x.petsc_vec)
        phi.x.scatter_forward()
        p_.x.petsc_vec.axpy(1, phi.x.petsc_vec)
            loc_3.set(0)
        # p_n.x.array[:] = p_.x.array[:]
        step += 1
    b2.destroy()
    b3.destroy()
    solver1.destroy()
    solver2.destroy()
    solver3.destroy()
    # coarse samples
    # p_u_vals = sample_function_at_points(mesh, p_n, phys_u)
    # p_v_vals = sample_function_at_points(mesh, p_n, phys_v)
    return (
        v_vals,
    rank = comm.rank
    Nx_list = [20,40,50,80]
    dx_list = []
    for Nx in Nx_list:
        (u_vals,
            v_vals,
            y_plot, x_plot,
            u_plot, v_plot,dxs) = solve_lid_cavity(Nx, 30.0, 1000.0)
        du = u_vals - u_ref
        dv = v_vals - v_ref
        du_list.append(du)
        dv_list.append(dv)
        dx_list.append(dxs)
    if rank == 0:
        axs[0, 0].legend()
        axs[0, 1].legend()
        axs[1, 0].legend()
        axs[1, 1].legend()
        plt.tight_layout()
        plt.savefig("ipcs_b_liddriven.png",dpi=300)
Hi Pavan,
Could you try running direct solvers (ie LU factorization for all steps)?
As iterative solvers has a stopping tolerance (I think around 1e-6 by default that will definitely disrupt converge rates at the error size you are seeing. Alternatively, try setting atol and rtol small (like 1e-14).
Hi @dokken
That worked perfectly! Setting solver.atol / solver.rtol to 1e-14 gives sensible results!
For posterity’s sake:
Turns out playing with the linear solver tolerances is just a partial solution to the original lid driven cavity problem. It turns out it takes longer to reach steady state. In the original simulation, i ran it to t=30. I have run it to t=100 and we get sensible results.
