I’m far from an expert on level set methods, but I thought the idea was to use the function itself as a definition of the geometry of the interface \vec{x}_\text{interface} = \{\vec{x} : \phi(\vec{x}) = 0\}.
To this end I just compute (please forgive the haphazard notation)
A_\text{interior} = \int_\Omega \begin{cases} 1 & \phi < 0 \\ 0 & \text{otherwise} \end{cases} \mathrm{d}x
and
A_\text{exterior} = \int_\Omega \begin{cases} 1 & \phi \geq 0 \\ 0 & \text{otherwise} \end{cases} \mathrm{d}x.
See the following modifications:
from tabulate import tabulate
r = 0.2
def phi(x):
return (x[0] - 0.5)**2 + (x[1]-0.5)**2 - r**2 #Zero level set is a circle centered in (0.5,0.5) with radius 0.2
class Omega(SubDomain):
return phi(x) > 0
class PhiExpr(UserExpression):
def eval(self, value, x):
value[0] = phi(x)
def value_shape(self):
return ()
#Total domain area: 1
#Interior expected area: pi*r^2
#Exterior expected area: 1 - pi*r^2
a = 10; q = 2; length = 6
size = [a * q** (n - 1) for n in range(1, length + 1)]
a_int = []; a_ext = []; e_int = []; e_ext=[]; k = 0
algebraic_int, algebraic_ext, e_algebraic_int, e_algebraic_ext = [], [], [], []
for N in size:
print('Mesh size:', N)
mesh = UnitSquareMesh(N, N,'crossed')
phi_function = Function(V)
phi_function.interpolate(PhiExpr())
algebraic_int.append(assemble(conditional(lt(phi_function, 0.0), 1, 0)*dx))
algebraic_ext.append(assemble(conditional(gt(phi_function, 0.0), 1, 0)*dx))
e_algebraic_int.append(pi*r**2 - algebraic_int[k])
e_algebraic_ext.append(1 - pi*r**2 - algebraic_ext[k])
domains = MeshFunction("size_t", mesh, mesh.topology().dim(), 0)
omega = Omega()
omega.mark(domains, 1)
dx_int = Measure("dx", domain=mesh, subdomain_data=domains)
a_int.append(assemble(Constant(1)*dx_int(0)))
a_ext.append(assemble(Constant(1)*dx_int(1)))
e_int.append(pi*r**2 - a_int[k])
e_ext.append(1 - pi*r**2 - a_ext[k])
print('Interior area:', a_int[k])
print('Error on interior area:', e_int[k])
print('Exterior area:', a_ext[k])
print('Error on extrior area:', e_ext[k])
print('Interior algebraic area:', algebraic_int[k])
print('Error on algebraic interior area:', e_algebraic_int[k])
print('Exterior algebraic area:', algebraic_ext[k])
print('Error on algebraic exterior area:', e_algebraic_ext[k])
k+=1
e_size = np.ones(length)/size
headers=['mesh size','element size', 'interior area', 'exterior area', 'interior error', 'exterior error']
table = [size, e_size,a_int,a_ext, e_int, e_ext]
print(tabulate(np.transpose(table),headers=headers, floatfmt=".3e"))
headers2=['mesh size','element size', 'algebraic interior area', 'algebraic exterior area', 'algebraic interior error', 'algebraic exterior error']
table2 = [size, e_size,algebraic_int,algebraic_ext, e_algebraic_int, e_algebraic_ext]
print(tabulate(np.transpose(table2),headers=headers2, floatfmt=".3e"))
where table2 gives a slightly better approximation
mesh size element size interior area exterior area interior error exterior error
1.000e+01 1.000e-01 1.800e-01 8.200e-01 -5.434e-02 5.434e-02
2.000e+01 5.000e-02 1.500e-01 8.500e-01 -2.434e-02 2.434e-02
4.000e+01 2.500e-02 1.375e-01 8.625e-01 -1.184e-02 1.184e-02
8.000e+01 1.250e-02 1.313e-01 8.687e-01 -5.586e-03 5.586e-03
1.600e+02 6.250e-03 1.286e-01 8.714e-01 -2.930e-03 2.930e-03
3.200e+02 3.125e-03 1.271e-01 8.729e-01 -1.465e-03 1.465e-03
mesh size element size algebraic interior area algebraic exterior area algebraic interior error algebraic exterior error
1.000e+01 1.000e-01 1.400e-01 8.600e-01 -1.434e-02 1.434e-02
2.000e+01 5.000e-02 1.250e-01 8.750e-01 6.637e-04 -6.637e-04
4.000e+01 2.500e-02 1.250e-01 8.750e-01 6.637e-04 -6.637e-04
8.000e+01 1.250e-02 1.253e-01 8.747e-01 3.512e-04 -3.512e-04
1.600e+02 6.250e-03 1.256e-01 8.744e-01 3.871e-05 -3.871e-05
3.200e+02 3.125e-03 1.257e-01 8.743e-01 -3.564e-07 3.563e-07
You can probably get even better results by modifying the space in which \phi lives or some fancy quadrature scheme.
I’m pretty sure you can do wonderful things with splines to get even more precise and smooth representations of level sets using splines. See for example @kamensky’s tIGAr.
