Here is the code:
from dolfinx import mesh
import warnings
warnings.filterwarnings("ignore")
from dolfinx import fem
from dolfinx import nls
from dolfinx import log
from dolfinx import io
from dolfinx.cpp.mesh import to_type, cell_entity_type
from dolfinx.fem import Constant, Function, FunctionSpace, assemble_scalar, dirichletbc, form, locate_dofs_topological, set_bc
from dolfinx.fem.petsc import apply_lifting, assemble_matrix, assemble_vector, create_vector, set_bc
from dolfinx.graph import create_adjacencylist
from dolfinx.geometry import BoundingBoxTree, compute_collisions, compute_colliding_cells
from dolfinx.io import (XDMFFile, cell_perm_gmsh, distribute_entity_data, extract_gmsh_geometry,
extract_gmsh_topology_and_markers, ufl_mesh_from_gmsh)
from dolfinx import geometry
from dolfinx.mesh import create_mesh, meshtags_from_entities
from ufl import (FacetNormal, FiniteElement, Identity, Measure, TestFunction, TrialFunction, VectorElement,
as_vector, div, dot, ds, dx, inner, lhs, grad, nabla_grad, rhs, sym)
import tqdm.notebook
import scipy.constants as c
L = 24.
H = 18.
c_x1 = 8.
c_y1 = 13.
r1 = 0.001
c_x2 = 16.
c_y2 = 13.
r2 = 0.001
gdim = 2
rank = MPI.COMM_WORLD.rank
if rank == 0:
rectangle = gmsh.model.occ.addRectangle(0,0,0, L, H, tag=1)
obstacle1 = gmsh.model.occ.addDisk(c_x1, c_y1, 0, r1, r1)
obstacle2 = gmsh.model.occ.addDisk(c_x2, c_y2, 0, r2, r2)
if rank == 0:
Mesh_domain = gmsh.model.occ.cut([(gdim, rectangle)], [(gdim, obstacle1), (gdim, obstacle2)])
gmsh.model.occ.synchronize()
Mesh_domain_marker = 1
if rank == 0:
gmsh.model.addPhysicalGroup(volumes[0][0], [volumes[0][1]], Mesh_domain_marker)
gmsh.model.setPhysicalName(volumes[0][0], Mesh_domain_marker, "Mesh_domain")
inlet_marker, outlet_marker, wall_marker, obstacle1_marker,obstacle2_marker, wall_top = 2, 3, 4, 5, 6, 7
inflow, outflow, walls, obstacle1, obstacle2 , top = [], [], [], [], [], []
if rank == 0:
for boundary in boundaries:
if np.allclose(center_of_mass, [0, H/2, 0]):
inflow.append(boundary[1])
elif np.allclose(center_of_mass, [L, H/2, 0]):
outflow.append(boundary[1])
elif np.allclose(center_of_mass, [L/2, 0, 0]):
walls.append(boundary[1])
elif np.allclose(center_of_mass, [L/2, H, 0]):
top.append(boundary[1])
obstacle2.append(boundary[1])
obstacle1.append(boundary[1])
gmsh.model.setPhysicalName(1, inlet_marker, "Inlet")
gmsh.model.addPhysicalGroup(1, outflow, outlet_marker)
gmsh.model.setPhysicalName(1, outlet_marker, "Outlet")
gmsh.model.addPhysicalGroup(1, obstacle1, obstacle1_marker)
gmsh.model.setPhysicalName(1, obstacle1_marker, "Obstacle1")
gmsh.model.addPhysicalGroup(1, obstacle2, obstacle2_marker)
gmsh.model.setPhysicalName(1, obstacle2_marker, "Obstacle2")
gmsh.model.addPhysicalGroup(1, top, wall_top)
gmsh.model.setPhysicalName(1, wall_top, "top")
if rank == 0:
gmsh.option.setNumber("Mesh.RecombinationAlgorithm", 8)
gmsh.option.setNumber("Mesh.RecombineAll", 2)
gmsh.option.setNumber("Mesh.SubdivisionAlgorithm", 1)
if MPI.COMM_WORLD.rank == 0:
x = extract_gmsh_geometry(gmsh.model)
topologies = extract_gmsh_topology_and_markers(gmsh.model)
num_cell_types = len(topologies.keys())
cell_information = {}
cell_dimensions = np.zeros(num_cell_types, dtype=np.int32)
for i, element in enumerate(topologies.keys()):
properties = gmsh.model.mesh.getElementProperties(element)
name, dim, order, num_nodes, local_coords, _ = properties
cell_information[i] = {"id": element, "dim": dim, "num_nodes": num_nodes}
cell_dimensions[i] = dim
perm_sort = np.argsort(cell_dimensions)
cell_id = cell_information[perm_sort[-1]]["id"]
tdim = cell_information[perm_sort[-1]]["dim"]
num_nodes = cell_information[perm_sort[-1]]["num_nodes"]
cell_id, num_nodes = MPI.COMM_WORLD.bcast([cell_id, num_nodes], root=0)
if tdim - 1 in cell_dimensions:
num_facet_nodes = MPI.COMM_WORLD.bcast( cell_information[perm_sort[-2]]["num_nodes"], root=0)
gmsh_facet_id = cell_information[perm_sort[-2]]["id"]
marked_facets = np.asarray(topologies[gmsh_facet_id]["topology"], dtype=np.int64)
facet_values = np.asarray(topologies[gmsh_facet_id]["cell_data"], dtype=np.int32)
cells = np.asarray(topologies[cell_id]["topology"], dtype=np.int64)
cell_values = np.asarray(topologies[cell_id]["cell_data"], dtype=np.int32)
cell_id, num_nodes = MPI.COMM_WORLD.bcast([None, None], root=0)
cells, x = np.empty([0, num_nodes], np.int64), np.empty([0, gdim])
cell_values = np.empty((0,), dtype=np.int32)
num_facet_nodes = MPI.COMM_WORLD.bcast(None, root=0)
marked_facets = np.empty((0, num_facet_nodes), dtype=np.int64)
facet_values = np.empty((0,), dtype=np.int32)
ufl_domain = ufl_mesh_from_gmsh(cell_id, gdim)
gmsh_cell_perm = cell_perm_gmsh(to_type(str(ufl_domain.ufl_cell())), num_nodes)
cells = cells[:, gmsh_cell_perm]
mesh = create_mesh(MPI.COMM_WORLD, cells, x[:, :gdim], ufl_domain)
tdim = mesh.topology.dim
fdim = tdim - 1
facet_type = cell_entity_type(to_type(str(ufl_domain.ufl_cell())), fdim, 0)
gmsh_facet_perm = cell_perm_gmsh(facet_type, num_facet_nodes)
marked_facets = np.asarray(marked_facets[:, gmsh_facet_perm], dtype=np.int64)
local_entities, local_values = distribute_entity_data(mesh, fdim, marked_facets, facet_values)
adj = create_adjacencylist(local_entities)
ft = meshtags_from_entities(mesh, fdim, adj, np.int32(local_values))
ft.name = "Facet tags"
print(ft.indices[ft.values == obstacle1_marker])
print(ft.indices[ft.values == obstacle2_marker])
I have deleted some of it I can’t get it much smaller
