Dear all,
I try to solve the thermal problem of two phases material in fenics with the below code:
# Define mesh and function space
mesh = UnitSquareMesh(32, 32)
# Define material properties
alpha1 = 1.0 # thermal expansion coefficient of phase 1
alpha2 = 0.5 # thermal expansion coefficient of phase 2
epsilon = 0.5 # volume fraction of phase 1
T_ref = Constant(0.0) # reference temperature
# Define boundary conditions
u_L = Constant(0.0) # left boundary temperature
u_R = Constant(1.0) # right boundary temperature
T = Function(V)
T_n = Function(V) # previous time step solution
F = ((1 + alpha1*(T - T_ref))*epsilon + (1 + alpha2*(T - T_ref))*(1-epsilon))*u*v*dx \
+ dot(grad(u), grad(v))*dx \
- ((1 + alpha1*(T_ref - u_L))*epsilon + (1 + alpha2*(T_ref - u_R))*(1-epsilon))*v*dx
# Define time step and solve
dt = 0.01
t_end = 1.0
t = dt
while t <= t_end:
solve(F == 0, T)
T_n.assign(T)
# Compute average thermal expansion coefficient
alpha = assemble(((1 + alpha1*(T - T_ref))*epsilon + (1 + alpha2*(T - T_ref))*(1-epsilon)) * dx) / assemble(u * dx)
# Output thermal expansion coefficient
print("The thermal expansion coefficient is: ", alpha)
when I run this code, there is an error:
Adding expressions with non-matching form arguments ('v_0',) vs ('v_0', 'v_1').
how to fix this problem please
thank you very much and wait for your response
