Hi, I am facing an issue while importing Gmsh msh file which I converted to xdmf format using meshio, but when I define boundary conditions on top and bottom side of the geometry it gives an error -
*** Warning: Found no facets matching domain for boundary condition.
Minimum Working Example -
mesh_from_file = meshio.read("mesh.msh")
out_mesh = meshio.Mesh(points=points, cells={cell_type: cells})
return out_mesh
triangle_mesh = create_mesh(mesh_from_file, "triangle", prune_z=True)
mesh = Mesh()
infile.read(mesh)
class top(SubDomain):
return on_boundary and near(x[1], 1., 0.1)
class bottom(SubDomain):
return on_boundary and near(x[1], 0., 0.1)
boundaries = MeshFunction("size_t", mesh, mesh.geometry().dim() - 1)
top().mark(boundaries, 1)
bottom().mark(boundaries, 2)
bc_top = DirichletBC(V.sub(1), Constant(2.), boundaries, 1)
bc_bottom = DirichletBC(V, Constant((0., 0.)), boundaries, 2)
bc_top.apply(u.vector())
bc_bottom.apply(u.vector())
with XDMFFile("bcs.xdmf") as xdmf:
xdmf.write(u)
Something is really strange with your msh file, as it seems like dolfin cannot find a single exterior facet in your mesh, i.e. assemble(1*ds(domain=mesh)) is equal to zero.
This can also be check by adding a print of the variable on_boundary in any of your inside functions or by calling:
mesh.init(mesh.topology().dim()-1, mesh.topology().dim())
f_to_c = mesh.topology()(mesh.topology().dim()-1,mesh.topology().dim())
for facet in facets(mesh):
print(facet.index(), f_to_c(facet.index()), len(f_to_c(facet.index())))
and so on till 485 [318 319] 2 .
I have a doubt that isn’t cell index() supposed to give an integer value then why it is giving output like [116 278] ?
Thanks for the help.
Ok, understood. Thanks, by the way, can you please have a look at this post Unexpected results in the application of Hertzian contact tutorial ? I think I am unable to define correct boundary conditions due to which the results are not what I was expecting. Happy to learn where I am making mistake.
I work on this forum on my spare time, and I’ve got limited capacity as to look at longer questions.
If you can reduce the problem, i.e. pin down where things go wrong in your code (is it the BCs, the contact expression or the solver) I might be able to help you
