Adjecency list creates unexpected triangles with multiple MPI processes
For every cell in a 2D mesh I am trying to obtain the transformation from the reference cell to that cell. For this I need the location of the vertices and the adjacency list between the cells and vertices. The following snippet of code extracts that information and saves it into a file. Running it with multiple MPI processes, it ignores ghost cells and stores the information for each processes separately.
save.py
import dolfinx.mesh as mesh
import basix
import sys
from pathlib import Path
if __name__ == "__main__":
    assert (
        len(sys.argv) == 2
    ), "Usage: python3 save.py <Number of cells in both x and y direction>"
    n_cells: int = int(sys.argv[1])
    width: float = 10.0
    height: float = 8.0
    cell_type: basix.CellType = basix.CellType.triangle
    msh: mesh.Mesh = mesh.create_rectangle(
        comm=MPI.COMM_WORLD,
        points=[[0.0, 0.0], [width, height]],
        n=[n_cells, n_cells],
        dtype=np.float64,
    tdim: int = msh.topology.dim
    gdim: int = msh.geometry.dim
    local_vertices: np.ndarray = np.asarray(msh.geometry.x.copy())[:, :gdim]
    num_local_cells: int = msh.topology.index_map(tdim).size_local
    msh.topology.create_connectivity(tdim, 0)
    adj_list = msh.topology.connectivity(tdim, 0)
    adj_list_arr = adj_list.array.reshape((-1, tdim + 1))[:num_local_cells]
    vertex_max = np.max(adj_list_arr)
    local_vertices = local_vertices[: vertex_max + 1]
    np.save(Path(f"./vertices_{MPI.COMM_WORLD.rank}.npy"), local_vertices)
    np.save(Path(f"./adjlist_{MPI.COMM_WORLD.rank}.npy"), adj_list_arr)
With the next snippet of code I reconstruct the mesh and plot it using matplotlib
view.py
import matplotlib.tri as tri
import re
    par_dir = Path(__file__).parent
    pattern = re.compile(r"_(\d+)\.npy")
    sort_fnc = lambda f: int(pattern.search(f.name).group(1))
    vertex_files: list[Path] = sorted(par_dir.glob("vertices_*.npy"), key=sort_fnc)
    adjlist_files: list[Path] = sorted(par_dir.glob("adjlist_*.npy"), key=sort_fnc)
    vertices: list[np.ndarray] = [np.load(v) for v in vertex_files]
    adjlists: list[np.ndarray] = [np.load(a) for a in adjlist_files]
    cmap = plt.get_cmap("winter")
    colors = cmap(np.linspace(0, 1, len(vertex_files)))
    fig, ax = plt.subplots()
    for v, a, c in zip(vertices, adjlists, colors):
        ax.scatter(v[:, 0], v[:, 1], color=c)
        ax.triplot(tri.Triangulation(x=v[:, 0], y=v[:, 1], triangles=a), color=c)
Running mpiexec -np 2 python3 save.py 4 a rectangular mesh with 4 cells in each direction is created and subsequently running python3 view.py plots it, and everything looks as expected. Similarly, using a single MPI process everything works fine for arbitrary number of cells. However, running — for example — mpiexec -np 2 python3 save.py 5 and viewing again with python3 view.py the result is completely wrong near the “MPI boundary”. Here is an stdout of the latter, printing the vertices and adjacency list:
RANK: 0
	VERTICES:
[[ 8.   0. ]
 [10.   0. ]
 [10.   1.6]
 [ 8.   1.6]
 [ 6.   0. ]
 [10.   3.2]
 [ 6.   1.6]
 [ 8.   3.2]
 [ 4.   0. ]
 [10.   4.8]
 [ 4.   1.6]
 [ 6.   3.2]
 [ 2.   0. ]
 [ 2.   1.6]
 [ 6.   4.8]
 [ 0.   0. ]
 [ 8.   4.8]
 [10.   6.4]
 [ 4.   3.2]
 [ 0.   1.6]
 [ 2.   3.2]]
	ADJACENCY:
<AdjacencyList> with 30 nodes
  0: [0 1 2 ]
  1: [0 3 2 ]
  2: [4 0 3 ]
  3: [3 2 5 ]
  4: [4 6 3 ]
  5: [3 7 5 ]
  6: [8 4 6 ]
  7: [6 3 7 ]
  8: [7 5 9 ]
  9: [8 10 6 ]
  10: [6 11 7 ]
  11: [7 19 9 ]
  12: [12 8 10 ]
  13: [10 6 11 ]
  14: [11 7 19 ]
  15: [19 9 20 ]
  16: [12 13 10 ]
  17: [10 18 11 ]
  18: [11 14 19 ]
  19: [15 12 13 ]
  20: [13 10 18 ]
  21: [18 11 14 ]
  22: [15 16 13 ]
  23: [13 17 18 ]
  24: [16 13 17 ]
  25: [16 21 17 ]
  26: [17 18 22 ]
  27: [18 22 14 ]
  28: [14 19 23 ]
  29: [19 23 20 ]
RANK: 1
	VERTICES:
[[ 0.   1.6]
 [ 0.   3.2]
 [ 2.   3.2]
 [ 0.   6.4]
 [ 0.   8. ]
 [ 2.   8. ]
 [ 0.   4.8]
 [ 2.   4.8]
 [ 2.   6.4]
 [ 4.   4.8]
 [ 4.   8. ]
 [ 4.   6.4]
 [ 4.   3.2]
 [ 6.   6.4]
 [ 6.   8. ]
 [ 8.   6.4]
 [ 8.   8. ]
 [ 8.   4.8]
 [10.   6.4]
 [10.   8. ]
 [ 6.   4.8]]
	ADJACENCY:
  0: [0 1 2 ]
  1: [3 4 5 ]
  2: [1 6 7 ]
  3: [6 3 8 ]
  4: [1 2 7 ]
  5: [3 8 5 ]
  6: [6 7 8 ]
  7: [2 7 9 ]
  8: [8 5 10 ]
  9: [7 8 11 ]
  10: [2 12 9 ]
  11: [7 9 11 ]
  12: [8 11 10 ]
  13: [12 9 20 ]
  14: [9 11 13 ]
  15: [11 10 14 ]
  16: [9 20 13 ]
  17: [11 13 14 ]
  18: [20 13 15 ]
  19: [13 14 16 ]
  20: [20 17 15 ]
  21: [13 15 16 ]
  22: [17 15 18 ]
  23: [15 16 19 ]
  24: [15 18 19 ]
  25: [0 21 2 ]
  26: [21 2 12 ]
  27: [12 22 20 ]
  28: [22 20 17 ]
  29: [17 23 18 ]
For example — from drawing it out by hand — the 11th cell on rank 0 has connectivity [7 19 9] with corresponding vertices (8, 3.2), (0, 1.6) and (10, 4.8) respectively. This triangle is not what I would
have expected. It should probably have been [7 16 9]. For reference, vertex 16 corresponds to (8, 4.8).
I installed the v0.9.0 version of dolfinx (tagged on GitHub) manually with Intel oneAPI compilers and MPI libraries.
Thanks in advance for helping to resolve this issue.
Here you are making a mistake, which is quite common, as users tend to forget that DOLFINx supports arbitrary order geometries.
This means that we have an explicit split between topology and geometry, which usually is only seen when you have curved grids.
However, when run in parallel, you might experience that the ghost indices of the geometry nodes are in a different order than those of your topology.
The best way of mapping between topology and geometry, is to use dolfinx.mesh.entities_to_geometry, as for instance shown in:
Thank you very much for the swift response. In case it helps anyone in the future, modifying the save.py script to the following
save.py
import basix
import sys
    assert (
        len(sys.argv) == 2
    width: float = 10.0
    height: float = 8.0
        dtype=np.float64,
    vertex_map = msh.topology.index_map(0)
    num_owned_vertices = vertex_map.size_local
    num_ghost_vertices = vertex_map.num_ghosts
    local_start = vertex_map.local_range[0]
    msh.topology.create_connectivity(0, tdim)
    geometry_indices = mesh.entities_to_geometry(
        msh, 0, np.arange(num_owned_vertices + num_ghost_vertices, dtype=np.int32)
    ).flatten()
    local_vertices = msh.geometry.x[geometry_indices]
Solves the issue.
