Hello!
Cell to vertex mapping using domain.topology.connectivity(dim, 0) gives different output from domain.geometry.dofmap. Here is my code below:
from dolfinx import mesh, fem, la
filepath = "results_new/"
filename = "mass_output"
fl = open(filepath + filename + '.txt', 'a')
comm = MPI.COMM_WORLD
rank = comm.Get_rank()
# create mesh
domain = domain = mesh.create_unit_cube(comm, 2, 2, 2, ghost_mode=mesh.GhostMode.shared_facet)
# dimension of mesh/domain
dim = domain.topology.dim
# initialized mesh topology
domain.topology.create_connectivity(dim, 0)
domain.topology.create_connectivity(0, dim)
# get connectivity matrix from topology
cell_to_vertices_topology = domain.topology.connectivity(dim, 0)
# number of cells and vertices
num_cells = domain.topology.index_map(dim)
# cell to vertex map from geometry
dof_map = domain.geometry.dofmap
cell_to_vertices_dof_map = np.array(dof_map)
fl.write(f"rank: {rank} \n Using topology \t Using geometry dof map \n")
for i in range(num_cells.size_local + num_cells.num_ghosts):
fl.write(f"{cell_to_vertices_topology.links(i)} \t {cell_to_vertices_dof_map[i]} \n")
I calculated mass vector using both mapping as code given below which gives different outputs
size = comm.Get_size()
# create mesh
# definition of function space
degree = 1
shape = (dim,)
W = fem.functionspace(domain, ("P", degree))
DG = fem.functionspace(domain, ("DG", 0))
# Volume of each cell
cell_volume_form = fem.form(ufl.TestFunction(DG) * ufl.dx)
volumes = fem.assemble_vector(cell_volume_form)
# initialized mass vector
mass_topology = fem.Function(W)
for cell_index in range(num_cells.size_local + num_cells.num_ghosts):
cell_vertices = cell_to_vertices_topology.links(cell_index)
volume = volumes.array[cell_index]
# Calculating mass vector
mass_per_vertex = rho * volume / len(cell_vertices)
mass_topology.x.array[cell_vertices] += mass_per_vertex
mass_topology.x.scatter_reverse(la.InsertMode.add)
mass_topology.x.scatter_forward()
fl.write(f"Rank {rank}: \n Mass vector using topology: \n {mass_topology.x.array[:]}\n")
mass_dof_map = fem.Function(W)
cell_vertices = dof_map[cell_index]
mass_dof_map.x.array[cell_vertices] += mass_per_vertex
mass_dof_map.x.scatter_reverse(la.InsertMode.add)
mass_dof_map.x.scatter_forward()
fl.write(f"Mass vector using dof map: \n {mass_dof_map.x.array[:]}\n")
mass_form = fem.form(ufl.TestFunction(W) * rho * ufl.dx)
mass_vector = fem.assemble_vector(mass_form)
mass_vector.scatter_reverse(la.InsertMode.add)
mass_vector.scatter_forward()
fl.write(f"Mass vector using assemble vector: \n {mass_vector.array[:]} \n \n")
I compared results with single processor run which shows mass vector is correct from geometry.dofmap
Please help me to resolve this problem as I need topology.connectivity of different dimensions to communicate data between processors.
If this is already resolved, where to find and how to integrate that in current version.
I am using following setup of Fenicsx:
OS: Ubuntu 24.04.2 LTS
Fenicsx v0.9.0 using conda
command to run: mpirun -np 2 python3 test.py
Thank you in advance!
