Hi, I want to do affine transformation of a function in parallel. Below is the sample code I am using from : Affine transformation: Translation X-Axis of Function
This works fine in serial but gives incorrect result in parallel.
from dolfin_adjoint import *
lx = 1.0
xmin=0.0
xmax=1.0
mesh = UnitSquareMesh(16,16)
V = FunctionSpace(mesh,'CG', 1)
u_0 = interpolate(Expression("x[0]",degree=3), V)
# Shift spatially along x the dofs
b = lx/2.0 #shift along x-axis
class ShiftedExpr(UserExpression):
def __init__(self,func,**kwargs):
super().__init__(**kwargs)
self.func = func
def eval(self,values,x):
x0_shift = x[0] - b
if(x0_shift < xmin):
x0_shift += lx
x_shift = np.array([x0_shift,x[1]])
values[0] = self.func(x_shift)
def value_shape(self):
return ()
u_1 = project(ShiftedExpr(u_0),V)
The problem in parallel seems to be in the line:
How to interpolate between non-matching meshes in parallel? : I also tried to use transfer_function given in this link instead of project(), but it fails too.
Could this be resolved for parallel?
I found that LagrangeInterpolator works in parallel as an alternative to interpolate or project for Lagrange functions as per this link: Function interpolation in parallel? - FEniCS Q&A
But, with LagrangeInterpolator used in parallel, my code is not completing.
Am I missing anything here?
Any help will be highly appreciated! Thanks!
After running in parallel, the code is stuck with the similar message shown below:
"Process 0: Computed bounding box tree with 249 nodes for 125 points.
Process 3: Building point search tree to accelerate distance queries.
Process 3: Computed bounding box tree with 263 nodes for 132 points. "
Here is the minimal test code that I am running in parallel.
lx = 1.0
xmin=0.0
xmax=1.0
# u_0 = interpolate(Expression("x[0]",degree=3), V)
self.func = func
x0_shift = x[0] - b
x0_shift += lx
return ()
# u_1 = project(ShiftedExpr(u_0),V)
u_0= Function(V)
u_0.set_allow_extrapolation(True)
u_1=Function(V)
LagrangeInterpolator.interpolate(u_1, ShiftedExpr(u_0))
