Hello, everyone, i am trying to solve the nonlinear Cahn-Hilliard equation using Fixed point method for nonlinear term. I have used the following fixed point method code for the Allen-Cahn equation.
from dolfinx.fem.petsc import assemble_matrix, assemble_vector, create_vector
from dolfinx import default_real_type, log, plot
from ufl import Measure, SpatialCoordinate, TestFunctions, TrialFunctions, div, exp, inner, grad
def run_simulation(N, dt, T=1.0, degree=1, max_fp_iter=10, fp_tol=1e-6):
# Create structured mesh
domain = mesh.create_unit_square(MPI.COMM_WORLD, N, N, mesh.CellType.quadrilateral)
x = SpatialCoordinate(domain)
dx = Measure("dx", domain)
V = fem.functionspace(domain, ("Lagrange", degree))
class exact_solution:
def __init__(self, t):
self.t = t
def __call__(self, x):
return np.exp(np.cos(self.t)) * np.cos(np.pi * x[0]) * np.cos(np.pi * x[1])
def f_expr(x, t):
return (-np.sin(t) * np.exp(np.cos(t)) * np.cos(np.pi * x[0]) * np.cos(np.pi * x[1])
+ 2 * np.pi**2 * np.exp(np.cos(t)) * np.cos(np.pi * x[0]) * np.cos(np.pi * x[1])
+ (np.exp(np.cos(t)) * np.cos(np.pi*x[0]) * np.cos(np.pi*x[1]))**3
- np.exp(np.cos(t)) * np.cos(np.pi*x[0]) * np.cos(np.pi*x[1]))
f = fem.Function(V)
t = 0
u_exact = exact_solution(t)
# Initial condition
u_n = fem.Function(V)
u_n.interpolate(u_exact)
# Variational problem components
u, phi = ufl.TrialFunction(V), ufl.TestFunction(V)
uh = fem.Function(V) # Current solution
# Time stepping
num_steps = int(T / dt)
for n in range(num_steps):
u_exact.t = t
f.interpolate(lambda x: f_expr(x, t))
# Fixed-point iteration
uh.x.array[:] = u_n.x.array # Initial guess for fixed-point iteration
for k in range(max_fp_iter):
# Linearized form (Newton-like)
a = (inner(u, phi)*dx + dt*inner(grad(u), grad(phi))*dx
+ dt*inner(3*uh**2 * u, phi)*dx - dt*inner(u, phi)*dx)
# Remaining nonlinear terms
L = (inner(u_n + dt*f, phi)*dx + dt*inner(2*uh**3, phi)*dx)
# Solve the linear system
problem = LinearProblem(
a, L,
petsc_options={
"ksp_type": "preonly",
"pc_type": "lu",
"pc_factor_mat_solver_type": "superlu_dist",
uh_new = problem.solve()
# Compute difference between iterations
diff = uh_new.x.array - uh.x.array
diff_norm = np.sqrt(domain.comm.allreduce(
np.sum(diff**2), op=MPI.SUM))
# Update solution for next iteration
uh.x.array[:] = uh_new.x.array
# Check for convergence
if diff_norm < fp_tol:
if MPI.COMM_WORLD.rank == 0 and n % 10 == 0:
print(f"Time step {n}, FP iteration {k}: converged with diff {diff_norm:.2e}")
break
# Update for next time step
u_n.x.array[:] = uh.x.array
# Save solution
with io.XDMFFile(domain.comm, "solution.xdmf", "w") as xdmf:
xdmf.write_mesh(domain)
xdmf.write_function(uh, t)
# Error computation
V_ex = fem.functionspace(domain, ("Lagrange", degree + 1))
u_ex = fem.Function(V_ex)
u_ex.interpolate(u_exact)
error = np.sqrt(domain.comm.allreduce(
fem.assemble_scalar(fem.form(inner(uh - u_ex, uh - u_ex)*dx)), op=MPI.SUM))
h = 1.0 / N
return h, dt, error
if __name__ == "__main__":
Ns = [8, 16, 32, 64]
hs, dts, errors = [], [], []
for N in Ns:
h = 1.0 / N
dt = h**2
h_val, dt_val, error = run_simulation(N, dt)
hs.append(h_val)
dts.append(dt_val)
errors.append(error)
if MPI.COMM_WORLD.rank == 0:
print(f"N={N:2d}, h={h_val:.3e}, dt={dt_val:.3e}, L2 error={error:.3e}")
# Compute convergence rate
print("\nConvergence rates (combined h and dt):")
for i in range(1, len(errors)):
ratesp = np.log(errors[i-1]/errors[i])/np.log(hs[i-1]/hs[i])
print(f"From N={Ns[i-1]} to N={Ns[i]}: ratesp ≈ {ratesp:.2f}")
ratetime = np.log(errors[i-1]/errors[i])/np.log(dts[i-1]/dts[i])
print(f"From dt={dts[i-1]:.3e} to dt={dts[i]:.3e}: ratetime ≈ {ratetime:.2f}")
Above code yields for P1 elements with dt=h^2:
But while i am trying to use same fixed point loop in the Cahn-Hilliard equation in mixed form, it does not converging.
Here, is my CH code:
import os
try:
if not dolfinx.has_petsc:
print("This demo requires DOLFINx to be compiled with PETSc enabled.")
exit(0)
except ModuleNotFoundError:
print("This demo requires petsc4py.")
exit(0)
from dolfinx.fem import Function, functionspace
from dolfinx.mesh import CellType, create_unit_square
from math import log2 # Add this import at the top of your file
try:
import pyvista as pv
import pyvistaqt as pvqt
have_pyvista = True
if pv.OFF_SCREEN:
pv.start_xvfb(wait=0.5)
print("pyvista and pyvistaqt are required to visualise the solution")
have_pyvista = False
# Save all logging to file
#log.set_output_file("log.txt")
def run_simulation(N, dt, T=1.0, degree=1, max_fp_iter=10, fp_tol=1e-6,p=0.1):
#msh = create_unit_square(MPI.COMM_WORLD, N, N, CellType.triangle)
msh = create_unit_square(MPI.COMM_WORLD, N, N, CellType.quadrilateral)
P1 = element("Lagrange", msh.basix_cell(), 1, dtype=default_real_type)
ME = functionspace(msh, mixed_element([P1, P1]))
V = functionspace(msh, P1)
# Test and trial functions for the mixed space
u, w = ufl.TrialFunctions(ME)
phi, psi = ufl.TestFunctions(ME)
x = SpatialCoordinate(msh)
dx = Measure("dx", msh)
# Set default tolerance if not provided
if fp_tol is None:
fp_tol = 1e-3/log2(N) if N > 1 else 1e-3
class exact_solution_u:
self.t = t
class exact_solution_w:
def __init__(self,t):
self.t = t
self.p = p # Assuming p is a parameter needed for the solution
return ((np.exp(np.cos(self.t)) *np.cos(np.pi * x[0])* np.cos(np.pi * x[1]))**3
-(np.exp(np.cos(self.t)) *np.cos(np.pi * x[0])* np.cos(np.pi * x[1]))
+2*(np.pi**2)*self.p*(np.exp(np.cos(self.t)) *np.cos(np.pi * x[0])* np.cos(np.pi * x[1])))
def f_expr(x,t):
return (np.cos(np.pi*x[0])*np.cos(np.pi*x[1])*np.exp(np.cos(t))*(-np.sin(t))
- 6*(np.pi)**2*np.exp(3*np.cos(t))*(np.cos(np.pi*x[0])*((np.sin(np.pi*x[0]))**2)*(np.cos(np.pi*x[1]))**3
+ np.cos(np.pi*x[1])*((np.sin(np.pi*x[1]))**2)*(np.cos(np.pi*x[0]))**3)
+ 6*(np.pi)**2*np.exp(3*np.cos(t))*(np.cos(np.pi*x[0])*np.cos(np.pi*x[1]))**3
+ (4*(np.pi)**4*p - 2*(np.pi)**2)*np.cos(np.pi*x[0])*np.cos(np.pi*x[1])*np.exp(np.cos(t)))
f = fem.Function(V)
t = 0
u_exact = exact_solution_u(t)
w_exact = exact_solution_w(t)
# Initial conditions
w_n = fem.Function(V)
w_n.interpolate(w_exact)
# Solution functions
vh = fem.Function(ME)
uh, wh = vh.split()
#stab = fem.Constant(msh, default_real_type(10.0))
#epsilon = 1e-2 # Stabilization parameter (adjust as needed)
# Time stepping
# Update exact solutions and source term
u_exact.t = t
w_exact.t = t
# Initialize with previous solution
uh.interpolate(u_n)
wh.interpolate(w_n) # Important: initialize both variables
# Fixed-point iterations
# Bilinear form
a1 =(inner(u, phi)*dx
+ dt*inner(grad(w), grad(phi))*dx
+inner(w, psi)*dx
- p*dt*inner(grad(u), grad(psi))*dx
- inner(3*uh**2 * u, psi)*dx
#+stab*inner(u,psi)*dx
+ inner(u, psi)*dx
# Linear form
L = (inner(u_n + dt*f, phi)*dx +inner(2*uh**3, psi)*dx)
#-stab*inner(u_n,psi)*dx)
# Solve the linearized system
problem1 = LinearProblem(
a1, L,
petsc_options={
"pc_type": "lu",
#Solve
vh_new = problem1.solve()
uh_new, wh_new = vh_new.split()
diff_u = uh_new.x.array - uh.x.array
diff_w = wh_new.x.array - wh.x.array
diff_norm_u = np.sqrt(msh.comm.allreduce(np.sum(diff_u**2), op=MPI.SUM))
diff_norm_w = np.sqrt(msh.comm.allreduce(np.sum(diff_w**2), op=MPI.SUM))
diff_norm = max(diff_norm_u, diff_norm_w) # Use worst-case convergence
# Update solution for next FP iteration
#uh.x.array[:] = uh_new.x.array
#wh.x.array[:] = wh_new.x.array
uh.interpolate(uh_new)
wh.interpolate(wh_new)
if MPI.COMM_WORLD.rank == 0: # Removed n%10 condition to see all convergences
print(f"Time step {n:3d}, FP iteration {k:2d}: converged with diff {diff_norm:.2e} "
f"(u: {diff_norm_u:.2e}, w: {diff_norm_w:.2e})")
break
elif k == max_fp_iter-1 and MPI.COMM_WORLD.rank == 0:
print(f"WARNING: Time step {n} did not converge after {max_fp_iter} iterations "
f"(final diff: {diff_norm:.2e})")
# Only update time step variables AFTER FP iterations converge
u_n.interpolate(uh)
w_n.interpolate(wh)
# Error computation (moved outside time loop)
V_ex = fem.functionspace(msh, ("Lagrange", degree + 1))
w_ex = fem.Function(V_ex)
w_ex.interpolate(w_exact)
erroru = np.sqrt(msh.comm.allreduce(
fem.assemble_scalar(fem.form(inner((uh - u_ex),(uh - u_ex))*dx)), op=MPI.SUM))
errorw = np.sqrt(msh.comm.allreduce(
fem.assemble_scalar(fem.form(inner((wh - w_ex),(wh - w_ex))*dx)), op=MPI.SUM))
h = 1.0 / N
return h, dt, erroru, errorw
hs, dts, errorsu, errorsw = [], [], [], []
for N in Ns:
h = 1.0 / N
dt = h**2
h_val, dt_val, erroru, errorw = run_simulation(N, dt)
hs.append(h_val)
dts.append(dt_val)
errorsu.append(erroru)
errorsw.append(errorw)
print(f"N={N:2d}, h={h_val:.3e}, dt={dt_val:.3e}, L2 erroru={erroru:.3e}, L2 errorw={errorw:.3e}")
# Compute convergence rate of u
for i in range(1, len(errorsu)):
ratespu = np.log(errorsu[i-1] / errorsu[i]) / np.log(hs[i-1] / hs[i])
print(f"From N={Ns[i-1]} to N={Ns[i]}: ratespu ≈ {ratespu:.2f}")
ratetimeu = np.log(errorsu[i-1] / errorsu[i]) / np.log(dts[i-1] / dts[i])
print(f"From dt={dts[i-1]:.3e} to dt={dts[i]:.3e}: ratetimeu ≈ {ratetimeu:.2f}")
# Compute convergence rate of w
for i in range(1, len(errorsw)):
ratespw = np.log(errorsw[i-1] / errorsw[i]) / np.log(hs[i-1] / hs[i])
print(f"From N={Ns[i-1]} to N={Ns[i]}: ratespw ≈ {ratespw:.2f}")
ratetimew = np.log(errorsw[i-1] / errorsw[i]) / np.log(dts[i-1] / dts[i])
print(f"From dt={dts[i-1]:.3e} to dt={dts[i]:.3e}: ratetimew ≈ {ratetimew:.2f}")
(For mixed i have used the following poisson mixed form code ideas:
Mixed formulation for the Poisson equation — DOLFINx 0.9.0 documentation)
What is the issues in CH code?. Is it due to mixed for or for nonlinear term. But same nonlinear term code i have used in above Allen-Chan code that works fine.
I will very gratefull if i get some help on this CH code to get optimal order for P1 and P2.
Thanks in advance!.
