Anisotropic heterogeneous diffusion
Hello everyone,
anybody knows how to define a tensorial (constant or non-constant) function to insert into the weak form for an anisotropic heterogeneous diffusion term, e.g.,
ufl.dot(ufl.grad(v),ufl.dot(K,ufl.grad(u)))*ufl.dx
I tried to define K as a constant numpy matrix or as a function or using ufl.TensorConstant but without success and can’t find any example related to this
I love fenicsx compared to fences but the definition of constants and functions has become non intuitive IMHO
Thanks
Consider the following:
constant_tensor = dolfinx.fem.Constant(
    mesh, np.array([[1, 0], [2, 1]], dtype=np.float64))
variable_tensor = ufl.as_tensor([[x[0], 0], [1, 3*x[1]]])
print(constant_tensor.ufl_shape)
print(variable_tensor.ufl_shape)
print(dolfinx.fem.assemble_scalar(
    dolfinx.fem.form(
        ufl.inner(constant_tensor, variable_tensor)*ufl.dx)))
Hi Dokken,
Would you mind giving a detailed example to show how to achieve anisotropic diffusion in dolfinx?
Here is my demo:
import dolfinx.fem.petsc
from dolfinx import mesh
from dolfinx.fem import FunctionSpace
from dolfinx import fem
import numpy
domain = mesh.create_unit_square(MPI.COMM_WORLD, 8, 8, mesh.CellType.quadrilateral)
V = FunctionSpace(domain, ("CG", 1))
uD = fem.Function(V)
uD.interpolate(lambda x: 1 + x[0]**2 + 2 * x[1]**2)
# Create facet to cell connectivity required to determine boundary facets
tdim = domain.topology.dim
fdim = tdim - 1
boundary_dofs = fem.locate_dofs_topological(V, fdim, boundary_facets)
bc = fem.dirichletbc(uD, boundary_dofs)
u = ufl.TrialFunction(V)
f = fem.Constant(domain, ScalarType(-6))
ijk = ufl.SpatialCoordinate(domain)
K = ufl.as_tensor([[ijk[0], 0], [1, 3*ijk[1]]])
a = (K  * ufl.dot(ufl.grad(u), ufl.grad(v))) * ufl.dx
L = f * v * ufl.dx
problem = fem.petsc.LinearProblem(a, L, bcs=[bc], petsc_options={"ksp_type": "preonly", "pc_type": "lu"})
uh = problem.solve()
There is an error: ERROR:UFL:Can only integrate scalar expressions. The integrand is a tensor expression with value shape (2, 2) and free indices with labels ().
Would you mind helping me to solve the problem?
Your variational form is not correct.
You start with -div(K*grad(u))*v*dx which is integrated by part to be inner(K*grad(u), grad(v))*dx
Sorry for my stupid mistake and thank you Dokken.
The code works well now.
