Time dependent diffusion constant in dolfinx
Hello everyone.
We would like to perform a diffusion calculation in which the diffusion coefficient changes with time.
We succeeded with the program shown below.
However, solver object is re-defined for each time step.
We think that is not efficient.
Can we conduct a calculation with varying diffusion coefficients without redefining the solver object?
# Module
from dolfinx.mesh import create_rectangle
from dolfinx.fem import FunctionSpace, Function, Constant, locate_dofs_geometrical, dirichletbc, form, Expression
from dolfinx.fem.petsc import assemble_matrix, assemble_vector, apply_lifting, create_vector, set_bc
from ufl import TrialFunction, TestFunction, dot, grad, dx, lhs, rhs
# Parameters
lx,ly,nx,ny = 10.0,5.0,10,5
vl,vr,vt,vb = 5.0,10.0,10.0,0.0
D = 1.0
f = 0.0
dt = 1.0
u0 = 0.0
# Mesh
domain = create_rectangle(MPI.COMM_WORLD, ([0, 0],[lx, ly]), [nx, ny])
# Function space
V = FunctionSpace(domain, ("CG", 1))
# Functions
u,v = TrialFunction(V),TestFunction(V)
u_n = Function(V)
# initial value
u_n.vector.array[:] = u0 * np.ones(u_n.vector.array.shape)
# Boundary condition
def left_boundary(x):
    return(np.isclose(x[0], 0.0))
def right_boundary(x):
    return(np.isclose(x[0], lx))
def top_boundary(x):
    return(np.isclose(x[1], ly))
def bottom_boundary(x):
    return(np.isclose(x[1], 0.0))
b_dofs_l = locate_dofs_geometrical(V, left_boundary)
b_dofs_r = locate_dofs_geometrical(V, right_boundary)
b_dofs_t = locate_dofs_geometrical(V, top_boundary)
b_dofs_b = locate_dofs_geometrical(V, bottom_boundary)
bc_l = dirichletbc(ScalarType(vl), b_dofs_l, V)
bc_r = dirichletbc(ScalarType(vr), b_dofs_r, V)
bc_t = dirichletbc(ScalarType(vt), b_dofs_t, V)
bc_b = dirichletbc(ScalarType(vb), b_dofs_b, V)
bcs = [bc_l, bc_r, bc_t, bc_b]
# Variational problem
f_ = Constant(domain, ScalarType(f))
dt_ = Constant(domain, ScalarType(dt))
#D_ = Expression('D', D=D)
t = 0
# solve problem
xdmf = XDMFFile(domain.comm, "output.xdmf", "w")
# Step 1
D_ = Constant(domain, ScalarType(D))
F = (u - u_n)*v*dx + dt_*D_*dot(grad(u),grad(v))*dx + dt_*f_*v*dx
a = form(lhs(F))
L = form(rhs(F))
# Solve problem
u_ = Function(V)
# assemble bilinear matrix
A = assemble_matrix(a, bcs=bcs)
# assemble linear vector
b = assemble_vector(L)
# solver object
solver.setOperators(A)
# write value
xdmf.write_mesh(domain)
xdmf.write_function(u_n, t)
# re-define assembled vector
with b.localForm() as loc_b:
    loc_b.set(0)
assemble_vector(b, L)
apply_lifting(b, [a], [bcs])
set_bc(b, bcs)
solver.solve(b, u_.vector)
u_.x.scatter_forward()
# update u_n
u_n.x.array[:] = u_.x.array[:]
# step 2
# change diffusion constant
D_ = Constant(domain, ScalarType(D*0.1))
a = form(lhs(F))
L = form(rhs(F))
# solver object
    loc_b.set(0)
set_bc(b, bcs)
# solve problem
# update u_n
xdmf.close()
See for instance: Hyperelasticity — FEniCSx tutorial
where T (Only the z-value) is updated within the time loop without redefining the form by calling:
    T.value[2] = n * tval0
I.e:
D_.value[0]= 0.1*D
Thank you for your reply.
I changed the part you pointed out and calculated again, but the results were different from that of the program where we re-defined the form shown above.
What is wrong with the program below?
# Module
# Parameters
D = 1.0
f = 0.0
dt = 1.0
u0 = 0.0
# Mesh
# Function space
# Functions
u_n = Function(V)
# initial value
t = 0
# solve problem
# Step 1
a = form(lhs(F))
L = form(rhs(F))
# Solve problem
u_ = Function(V)
# solver object
# write value
    loc_b.set(0)
set_bc(b, bcs)
# update u_n
# step 2
D_.value = 0.1*D
    loc_b.set(0)
set_bc(b, bcs)
# solve problem
# update u_n
xdmf.close()
Please start by simplifying your programs by using a for loop to avoid repeating code.
Sorry for the confusion.
I have rewritten it as follows using for loop.
We obtained the results with time dependent diffusion coefficient.
Thank you very much!
However, new question has emerged.
We will post that question to new thread.
# Module
# Parameters
D = 1.0
f = 0.0
dt = 1.0
u0 = 0.0
# Mesh
# Function space
# Functions
u_n = Function(V)
# initial value
t = 0
# solve problem
xdmf = XDMFFile(domain.comm, "output2.xdmf", "w")
# Step 1
a = form(lhs(F))
L = form(rhs(F))
# Solve problem
u_ = Function(V)
# solver object
# write value
for n in range(10):
    D_.value = 0.1*D*(n+1)
        loc_b.set(0)
    set_bc(b, bcs)
    # update u_n
xdmf.close()
