Thanks for the quick reply! I post the minimal example below. The line
nsp.orthogonalize(b1)
raises
AttributeError: 'petsc4py.PETSc.NullSpace' object has no attribute 'orthogonalize'
Minimal example:
from dolfinx.fem import Function, FunctionSpace, assemble_matrix_block, assemble_vector_block, form
from dolfinx.mesh import CellType, create_rectangle
from ufl import FiniteElement, TrialFunction, TestFunction, variable, diff, dx, grad, inner
# Parameters
epsilon = 1.0e-03
dt = 1.0e-05
t = 0
T = 1e-04
# Mesh and function spaces
mesh = create_rectangle(MPI.COMM_WORLD, [np.array([0, 0]), np.array([10, 2.5])], [200, 100], CellType.triangle)
P1 = FiniteElement('Lagrange', mesh.ufl_cell(), 1)
MEc, MEmu = FunctionSpace(mesh, P1), FunctionSpace(mesh, P1)
# Functions
dc1, dmu1 = TrialFunction(MEc), TrialFunction(MEmu)
q1, v1 = TestFunction(MEc), TestFunction(MEmu)
c1, c01 = Function(MEc), Function(MEc)
mu1, mu01 = Function(MEmu), Function(MEmu)
# Initial conditions
mu1.x.array[:] = 0.0
c1.interpolate(lambda x: 0.35 + 0.02 * (0.5 - np.random.rand(x.shape[1])))
c1.x.scatter_forward()
def setup_potential(c01):
# Potential
c01 = variable(c01)
f = 3.5 * c01**2 * (1 - c01)**2
dfdc01 = diff(f, c01)
return dfdc01
def assemble_IMEX(dt, dc1, q1, dmu1, v1, c01, dfdc01):
# Weak form
Lone_block = form([[dt*inner(grad(dmu1),grad(q1))*dx, inner(dc1, q1)*dx],
[inner(dmu1, v1)*dx, - epsilon*inner(grad(dc1),grad(v1))*dx]])
fone_block = form([inner(c01, q1)*dx, inner(dfdc01, v1)*dx])
# Assemble linear system
A1_block = assemble_matrix_block(Lone_block)
A1_block.assemble()
b1 = assemble_vector_block(fone_block, Lone_block)
# Preconditioner
a_p_11 = form(epsilon*inner(grad(dc1),grad(v1))*dx)
a_p = [[Lone_block[0][0], None],
[None, a_p_11]]
P1 = assemble_matrix_block(a_p)
P1.assemble()
##### Code snippet 1
# Nullspace
null_vec = b1.copy() # A1_block.createVecLeft()
null_vec.array[:] = np.sqrt(1.0/null_vec.getSize())
null_vec.normalize()
nsp = PETSc.NullSpace().create(vectors=[null_vec])
A1_block.setNullSpace(nsp)
#nsp.orthogonalize(b1)
# Krylov solver
ksp1 = PETSc.KSP()
ksp1.create(PETSc.COMM_WORLD)
#ksp1.setType("minres")
ksp1.setTolerances(rtol=1e-06)
ksp1.setOperators(A1_block, P1)
ksp1.getPC().setType("gamg")
return ksp1, b1, A1_block
dfdc01 = setup_potential(c01)
n = len(c1.vector.array)
# Loop over time
while t < T:
c01.x.array[:] = c1.x.array
mu01.x.array[:] = mu1.x.array
ksp1, b1, A1 = assemble_IMEX(dt, dc1, q1, dmu1, v1, c01, dfdc01)
# Solve linear system
x1 = A1.createVecRight()
ksp1.solve(b1, x1)
res1 = A1*x1 - b1
##### Code snippet 2
print('pol, type:', ksp1.getType(), 'residual:', ksp1.getResidualNorm(), 'iterations: ', ksp1.getIterationNumber(), '\n\tconvergence reason', ksp1.getConvergedReason(), 'manually computed residual:', res1.norm())
mu1.x.array[:] = x1.array_r[:n]
c1.x.array[:] = x1.array_r[n:2*n]
