Hello everyone,
I am trying to apply a load on the edge within the domain as shown in the attached figure. Outer boundary of the green rectangle is constrained.
My code is as follows
mesh = Mesh('domain_nm_b.xml')
V = VectorFunctionSpace(mesh, 'CG', 1)
tol = 1E-7
def boundary_D_1(x, on_boundary):
return x[0] <= 0.0 + tol
def boundary_D_2(x, on_boundary):
return x[0] >= 4000.0 - tol
def boundary_D_3(x, on_boundary):
return x[1] <= 0.0 + tol
def boundary_D_4(x, on_boundary):
return x[1] >= 4000.0 - tol
bc_1 = DirichletBC(V, Constant((0.,0.)), boundary_D_1, method='pointwise')
bc_2 = DirichletBC(V, Constant((0.,0.)), boundary_D_2, method='pointwise')
bc_3 = DirichletBC(V, Constant((0.,0.)), boundary_D_3, method='pointwise')
bc_4 = DirichletBC(V, Constant((0.,0.)), boundary_D_4, method='pointwise')
bc_disp = [bc_1, bc_2, bc_3, bc_4]
class boundary_N_y(SubDomain):
return x[0] >= 3000.-tol and x[0] <= 3000. + tol
B_N_Y = boundary_N_y()
B_N_Y.mark(boundary_markers, 1)
E = 210000.
nu = 0.3
lmbda = E * nu / ((1 + nu) * (1 - 2 * nu))
mu = E / (2 * (1 + nu))
u, du, v = Function(V), TrialFunction(V), TestFunction(V)
T = Constant((300., 0))
L = dot(T, u)*ds(1)
def eps(u):
return sym(grad(u))
def sigma(u):
return 2.0*mu*(eps(u)) + lmbda*tr(eps(u))*Identity(2)
elastic_energy = 0.5*inner(sigma(u), eps(u))*dx - L
E_u = derivative(elastic_energy,u,v)
Jd = derivative(E_u, u, du)
problem_u = NonlinearVariationalProblem(E_u, u, bc_disp, Jd)
solver_u = NonlinearVariationalSolver(problem_u)
prm = solver_u.parameters
solver_u.solve()
this code is not applying the load on the required edge and solver is giving the following response:
Newton iteration 0: r (abs) = 0.000e+00 (tol = 1.000e-10) r (rel) = -nan (tol = 1.000e-09)
Newton solver finished in 0 iterations and 0 linear solver iterations.
Mesh can be taken from here. Please help me to fix this issue.
Thank you,
Manish
