Applying a constraint using a Lagrange multiplier dolfinx
I’m trying to impose a global constraint using a Lagrange multiplier on dolfinx. I have created a minimal example to test the constraint, however, I’m receiving a different result compared with dolfin.
Here is a minimal working example (dolfin):
# Create mesh
mesh = UnitSquareMesh.create(50, 50, CellType.Type.quadrilateral)
# Build function space with Lagrange multiplier
V = FiniteElement("Lagrange", mesh.ufl_cell(), 2)
R = FiniteElement("Real", mesh.ufl_cell(), 0)
W = FunctionSpace(mesh, MixedElement([V, R]))
bc1 = DirichletBC(W.sub(0), 0.0, "on_boundary")
bcs = [bc1]
(u, lm) = TrialFunctions(W)
(v, c) = TestFunctions(W)
g = Constant(0.0)
F = inner(grad(u), grad(v))*dx - g*v*dx
F += lm*v*dx + c*(u - Constant(0.5))*dx
a = lhs(F)
L = rhs(F)
# Compute solution
w = Function(W)
solve(a == L, w, bcs)
(u, lm) = w.split()
# Save solution in VTK format
file1 = File("lagrange_multipliers/u.pvd")
file1 << u
file2 = File("lagrange_multipliers/lm1.pvd")
file2 << lm
Here is a minimal working example (dolfinx):
import os
os.environ["OMP_NUM_THREADS"] = "1"
from dolfinx import (DirichletBC, Function, FunctionSpace, Constant)
from dolfinx.fem import locate_dofs_topological
from dolfinx.mesh import locate_entities_boundary
from ufl import (lhs, rhs, FiniteElement, MixedElement, TestFunctions, TrialFunctions, dx,
grad, inner)
from dolfinx.la import solve
# Create mesh
mesh = dolfinx.UnitSquareMesh(MPI.COMM_WORLD, 50, 50,
       dolfinx.cpp.mesh.CellType.quadrilateral)
def boundary(x):
    return np.logical_or(np.isclose(x[1], 1.0), np.logical_or(np.isclose(x[1], 0.0),
    np.logical_or(np.isclose(x[0], 1.0), np.isclose(x[0], 0.0))))
facets = locate_entities_boundary(mesh, 1, boundary)
u_bc = Function(W.sub(0).collapse())
u_bc.vector.set(0.0)
u_bc.vector.ghostUpdate(addv=PETSc.InsertMode.INSERT, mode=PETSc.ScatterMode.FORWARD)
dofs = locate_dofs_topological((W.sub(0), FunctionSpace(mesh, V)), 1, facets)
bc1 = DirichletBC(u_bc, dofs, W.sub(0))
bcs = [bc1]
g = Constant(mesh, 0.0)
F += lm*v*dx + c*(u - Constant(mesh, 0.5))*dx
a = lhs(F)
L = rhs(F)
# Compute solution
w = Function(W)
A = dolfinx.fem.assemble_matrix(a, bcs)
b = dolfinx.fem.assemble_vector(L)
dolfinx.fem.apply_lifting(b, [a], [bcs])
dolfinx.fem.set_bc(b, bcs)
solve(A, w.vector, b)
with XDMFFile(MPI.COMM_WORLD, "u.xdmf", "w") as u_file:
    u_file.write_mesh(mesh)
    u_file.write_function(w.sub(0))
#with XDMFFile(MPI.COMM_WORLD, "lm.xdmf", "w") as lm_file:
#    lm_file.write_mesh(mesh)
#    lm_file.write_function(w.sub(1))
Another issue is that I’m receiving the following error when I try to save the Lagrange multiplier using XDMFFile
Loguru caught a signal: SIGSEGV
Segmentation fault (core dumped)
This is related to this issue around Real spaces not doing what they are meant to.
as far as I’ve tracked the related issues within the git repository this issue hasn’t be solve yet or did I missed something?
Kind regards,
Maximilian
Good news: @jackhale has been working on Real spaces and there’s a now a PR open that adds support for them to DOLFINx (Add Real Space by jhale · Pull Request #2266 · FEniCS/dolfinx · GitHub)
