Hi, I am using dolfinx_mpc and I am trying to create a MultiPointConstraint. I am trying to apply the create_general_constraint to a Vector Function Space within a Mixed Function Space. I get the following error: “RuntimeError: Multiple slaves found at same point. You should use sub-space locators.” But I am already using the sub-space locators for accessing the Vector Function Space within my Mixed Function Space. Is there a work around? Thank you very much!
Here below is my MWE.
from dolfinx import mesh, fem
from ufl import VectorElement, FiniteElement, MixedElement, TestFunctions, inner, grad, dx
from dolfinx.mesh import locate_entities_boundary
from dolfinx_mpc import MultiPointConstraint
Lx, Ly, Lz = 1.0, 1.0, 1.0
nx, ny, nz = 3, 3, 3
domain = mesh.create_box(MPI.COMM_WORLD, [[0.0, 0.0, 0.0], [Lx, Ly, Lz]], [nx, ny, nz])
V_element = VectorElement("CG", domain.ufl_cell(), 2)
Q_element = FiniteElement("CG", domain.ufl_cell(), 1)
W = fem.FunctionSpace(domain, MixedElement([V_element, Q_element]))
slave_facets = locate_entities_boundary(domain, dim=2, marker=lambda x: np.isclose(x[0], 0.0))
master_facets = locate_entities_boundary(domain, dim=2, marker=lambda x: np.isclose(x[0], Lx))
ZS_v = fem.FunctionSpace(domain, FiniteElement("CG", domain.ufl_cell(), 2))
ZS_q = fem.FunctionSpace(domain, FiniteElement("CG", domain.ufl_cell(), 1))
slave_dofs_velocity = fem.locate_dofs_topological(ZS_v, 2, slave_facets)
master_dofs_velocity = fem.locate_dofs_topological(ZS_v, 2, master_facets)
slave_dofs_pressure = fem.locate_dofs_topological(ZS_q, 2, slave_facets)
master_dofs_pressure = fem.locate_dofs_topological(ZS_q, 2, master_facets)
def create_slave_master_dict(slave_coords, master_coords):
slave_master_dict = {}
for i, slave_coord in enumerate(slave_coords):
master_index = np.argmin(np.linalg.norm(master_coords - slave_coord, axis=1))
master_coord = master_coords[master_index]
slave_master_dict[slave_coord.tobytes()] = {master_coord.tobytes(): 1.0}
return slave_master_dict
dof_coords_velocity = ZS_v.tabulate_dof_coordinates()
slave_coords_velocity = dof_coords_velocity[slave_dofs_velocity]
master_coords_velocity = dof_coords_velocity[master_dofs_velocity]
dof_coords_pressure = ZS_q.tabulate_dof_coordinates()
slave_coords_pressure = dof_coords_pressure[slave_dofs_pressure]
master_coords_pressure = dof_coords_pressure[master_dofs_pressure]
slave_master_dict_velocity = create_slave_master_dict(slave_coords_velocity, master_coords_velocity)
slave_master_dict_pressure = create_slave_master_dict(slave_coords_pressure, master_coords_pressure)
mpc = MultiPointConstraint(W)
mpc.create_general_constraint(
slave_master_dict=slave_master_dict_velocity,
subspace_slave=0,
subspace_master=0
slave_master_dict=slave_master_dict_pressure,
subspace_slave=1,
subspace_master=1
