Applying dynamic loads to given points in the structural dynamic analysis
Hi, I’m new on Fenics. Now I’m encountering a problem in the structural dynamic analysis.
As for the loads are applied to several interior points (the coordinates are given) as below and are a discrete value at every timestep, they cannot be uniformly described by Expressions.
*Amplitude, Name=N1_X
          0.02,   -0.000602584839,          0.04,     -0.0973661804,          0.06,       -2.63061237,          0.08,       -34.7715683,
           0.1,        -292.87326,          0.12,       -1759.55915,          0.14,       -8015.15675,          0.16,       -28724.2546,
          0.18,       -82932.8842,           0.2,       -196220.825,          0.22,       -387184.113,          0.24,       -656762.817,
          0.26,       -1019174.46,          0.28,       -1597426.06,           0.3,        -2720511.2,          0.32,       -4893093.11,
          0.34,       -8597781.18,          0.36,       -14063301.1,          0.38,       -21133379.0,           0.4,       -29211088.2,
          0.42,       -37278133.4,          0.44,       -44185226.4,          0.46,       -49219863.9,          0.48,       -52382289.9,
           0.5,       -53873630.5
I referred to the case here:How can point loads be applied to the end of the cantilever beam? But in this case the load is constant and the code is for dolfin rather than dolfinx.
Is there any similar cases for dolfinx that I can refer to?
Can you provide any effective ideas? Thank you very much!
