Point load and methods for solving constraint problems
Hello everyone,
I would like to know that in dolfinx, is it possible to solve methods like Augmented Lagrangian methods or Primal–Dual Active Set Algorithms for solving the constrain problems, as I have seen some queries asked before had remained unanswered. So it will be helpful if someone had any idea on implementation of the same in dolfinx.
Additionally I have noticed that there is no “Point source” in fenicsx for applying a point load like in fenics. If someone had any ideas on application of point load, please suggest some ideas. It will be very much helpful.
Thanks for all your time and consideration. Any ideas regarding the above two queries were appreciated.
For the second question, please make a search with a keyword like “point source”. The topic was discussed a few times in the last month or so, so you may want to sort the search results by “latest post”. Once you’ve found a relevant topic, please post it here in a reply.
Thanks for your response. I refereed to the previous discussion on point source How to construct a sparse matrix used for calculating function values at multiple points - #4 by dokken which is very much helpful. As per the advice, I attempted to apply point load in a simple problem. I created function and obtained the basis values and cells from the function.
After that, it is needed to be inserted in the matrix/vector, which is where I am confused in execution of the same. I tried so far what I understood in the below code on a simple problem of rectangular domain with application of point load on top middle surface, but it is showing Error which is not usual. My code is
import os
from basix.ufl import element
from dolfinx import default_real_type, log, io
from dolfinx.fem import Function, functionspace,assemble_scalar
from dolfinx import fem, default_scalar_type,mesh
import scipy.sparse as sps
from dolfinx.fem import (Function, dirichletbc, form, functionspace, locate_dofs_geometrical)
                               create_matrix, create_vector, set_bc)
from ufl import TestFunction, TrialFunction, derivative, dx, grad, inner
def construct_force_matrix(V, points):
    mesh = V.mesh
    sdim = V.dofmap.index_map_bs
    num_dofs = V.dofmap.index_map.size_local * sdim
    nx, dim = points.shape
    _, _, owning_points, cells = dolfinx.cpp.geometry.determine_point_ownership(
        mesh._cpp_object, points)
    owning_points = np.asarray(owning_points).reshape(-1, 3)
    mesh_nodes = mesh.geometry.x
    cmap = mesh.geometry.cmaps[0]
    ref_x = np.zeros((len(cells), mesh.geometry.dim), dtype=mesh_nodes.dtype)
    for i, (point, cell) in enumerate(zip(owning_points, cells)):
        geom_dofs = mesh.geometry.dofmap[cell]
        ref_x[i] = cmap.pull_back(point.reshape(-1, 3), mesh_nodes[geom_dofs])
    u = ufl.TrialFunction(V)
    num_dofs = V.dofmap.dof_layout.num_dofs * V.dofmap.bs
    if len(cells) > 0:
        # Strip out basis function values per cell
        expr = dolfinx.fem.Expression(u, ref_x, comm=MPI.COMM_SELF)
        values = expr.eval(mesh, cells)
        basis_values = values[:num_dofs:num_dofs*len(cells)]
        basis_values = np.zeros(
            (0, num_dofs), dtype=dolfinx.default_scalar_type)
    print (cells)
    print (basis_values)
    return cells, basis_values
class NonlinearPDEProblem:
    """Nonlinear problem class for a PDE problem."""
    def __init__(self, F, u, bc):
        V = u.function_space
        du = TrialFunction(V)
        self.L = form(F)
        self.a = form(derivative(F, u, du))
        self.bc = bc
    def form(self, x):
        x.ghostUpdate(addv=PETSc.InsertMode.INSERT, mode=PETSc.ScatterMode.FORWARD)
    def F(self, x, b):
        """Assemble residual vector."""
        with b.localForm() as b_local:
            b_local.set(0.0)
        assemble_vector(b, self.L)
        apply_lifting(b, [self.a], bcs=[[self.bc]], x0=[x], scale=-1.0)
        set_bc(b, [self.bc], x, -1.0)
        #Constructing the force matrix for the point load
        cells, basis_values = construct_force_matrix(x.function_space, points_array)
        # Add the point load contribution to the residual vector
            for i in range(len(cells)):
                x_vals = np.repeat(x.array[cells[i]], x.function_space.dofmap.index_map_bs)
                x_local = np.sum(x_vals * basis_values[i, :])
                b_local.array[cells[i]] -= point_load_magnitude * basis_values[i, :] * x_local
        set_bc(b, self.bcs, x, -1.0)
    def J(self, x, A):
        """Assemble Jacobian matrix."""
        A.zeroEntries()
        assemble_matrix(A, self.a, bcs=[self.bc])
    def matrix(self):
        return create_matrix(self.a)
    def vector(self):
        return create_vector(self.L)
#Creating mesh
msh = mesh.create_rectangle (comm=MPI.COMM_WORLD, points=((0.0, 0.0), (6.0,1.0)), n=(96,16), cell_type=mesh.CellType.quadrilateral)
#Creating function space
V = fem.VectorFunctionSpace(msh,("Lagrange",1))
def clamped_boundary(x):
    return np.isclose(x[1], 0)
u_zero = np.array((0,) * msh.geometry.dim, dtype=default_scalar_type)
bc = fem.dirichletbc(u_zero, fem.locate_dofs_geometrical(V, clamped_boundary), V)
def left(x):
    return np.isclose(x[0],0)
left_facets = mesh.locate_entities_boundary(msh,msh.topology.dim-1,left)
left_dof = fem.locate_dofs_topological(V.sub(0),msh.topology.dim-1,left_facets)
bc_left = fem.dirichletbc(default_scalar_type(0),left_dof,V.sub(0))
bcs = [bc,bc_left]
#Defining point for application of force
point_to_apply_force = np.array([3,1])
points_array = np.array([point_to_apply_force])
# Call the function with the array of points
cells,basis_val = construct_force_matrix(V, points_array)
#Defining traction and body forces
T=fem.Constant(msh,default_scalar_type((0,0)))
B=fem.Constant(msh,default_scalar_type((0,0)))
#Defining test and solution function
v=ufl.TestFunction(V)
u=fem.Function(V)
#Spatial dimension
d=len(u)
#Identity tensor
I=ufl.variable(ufl.Identity(d))
#Deformation gradient
F=ufl.variable(I+grad(u))
# Right Cauchy-Green tensor
C = ufl.variable(F.T * F)
Ic = ufl.variable(ufl.tr(C))
J = ufl.variable(ufl.det(F))
# Elasticity parameters
E =default_scalar_type(1e4)
nu = default_scalar_type(0.3)
mu = fem.Constant(msh, E / (2 * (1 + nu)))
lmbda = fem.Constant(msh, E * nu / ((1 + nu) * (1 - 2 * nu)))
psi = (mu / 2) * (Ic - 3) - mu * ufl.ln(J) + (lmbda / 2) * (ufl.ln(J))**2
# Hyper-elasticity
P = ufl.diff(psi, F)
ds = ufl.Measure('ds')
dx = ufl.Measure('dx')
#Defining the weak form
FF = ufl.inner(ufl.grad(v), P) * dx - ufl.inner(v, B) * dx - ufl.inner(v, T) * ds
# External point load magnitude
point_load_magnitude = 100.0
problem = NonlinearProblem(FF, u, bcs, J=None, form_compiler_options=None, jit_options=None)
#Solving using newton solver
solver=NewtonSolver(msh.comm,problem)
solver.atol = 1e-8
solver.rtol = 1e-8
solver.solve(u) #Error when tried to solve.
a=u.x.array
print(a)
The error is may be my proceeding with basis value is wrong on my understanding. If approach of solving is correct, it will be very much helpful for all questions related to application of point load. As per my understanding I started, could you please help me further how to avoid this error . It will be very much helpful to proceed further for my problem. I hope the issues is in the addition of vector to existing vector, please help in further proceeding.
Thanks for all your time and considerations. Any tips or advice on the above problem is greatly appreciated. I will be waiting for your responses.
Error message for your reference:
terminate called after throwing an instance of 'std::runtime_error'
  what():  pybind11_object_dealloc(): Tried to deallocate unregistered instance!
[Legion:476503] *** Process received signal ***
[Legion:476503] Signal: Aborted (6)
[Legion:476503] Signal code:  (-6)
[Legion:476503] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x42520)[0x7fa2ba0d3520]
[Legion:476503] [ 1] /lib/x86_64-linux-gnu/libc.so.6(pthread_kill+0x12c)[0x7fa2ba1279fc]
[Legion:476503] [ 2] /lib/x86_64-linux-gnu/libc.so.6(raise+0x16)[0x7fa2ba0d3476]
[Legion:476503] [25] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0x80)[0x7fa2ba0bae40]
[Legion:476503] [26] /bin/python3(_start+0x25)[0x55a2d6110f25]
[Legion:476503] *** End of error message ***
I am able to run your code if I apply the following patch
diff --git a/pload.py b/pload.py
index 549642d..6b02398 100644
--- a/pload.py
+++ b/pload.py
@@ -26,7 +26,8 @@ def construct_force_matrix(V, points):
-        mesh._cpp_object, points)
+        mesh._cpp_object, points, 1e-6)
+    cells = np.array(cells, dtype=np.int32)
@@ -101,7 +102,7 @@ class NonlinearPDEProblem:
-V = fem.VectorFunctionSpace(msh,("Lagrange",1))
+V = fem.functionspace(msh,("Lagrange",1, (2,)))
The first change is probably the only relevant one, the other cosmetic but you’ll need them when the next DOLFINx version will be released, so it’s good to have them in even now.
I do not have any error when running the modified code, either with DOLFINx 0.7.2 or main branch. I still get the zero solution, but that’s not surprising considering that you never use cells,basis_val after you compute them…
Thanks for your immediate response Mr.Ballarin. I am having dolfinx version 0.7.1, so when I ran with the first correction,
It shows me the following error, so i dropped the term. Without it I can able to get the value of basis values and cells in my version but while adding this to matrix and solving makes error.
In response to your last statement, I used the values sir, in the class NonlinearPDEproblem, in the thought of adding it to the b matrix. Maybe this approach of adding is wrong, because of the error. So could you please confirm me that, also if it is not the right way, sir please do suggest me some advice of adding the same as this is the only approach I found from the previous topics and discussion. I am sure that from the instruction (How to construct a sparse matrix used for calculating function values at multiple points - #4 by dokken) that I need to use basis values to insert it to matrix/vector but I am lacking how to. Could you please help?
Thank you very much again for your time and considerations. It means a lot.
We might need to ask @dokken for help, because I cannot understand what you are currently implementing in def F(self, x, b).
However, your example is too complicated for us to be in the best position to help you. Please simplify it according to the following guidelines:
minimal set of imports: there are a lot of unused imports in your code
definition of a mesh
definition function space V
definition of two points at which you want to apply the load:
    please make sure to have one of them that coincides with a DOF of V
    (e.g., a mesh vertex for P1 element), and another point which does
    NOT coincide with a DOF.
vector = dolfinx.la.create_petsc_vector(V.index_map, V.index_map_bs)
# note that the above call will create a vector with all entries equal to zero
modification of vector to apply point load contributions
# only a handful of entries will be changed from their original zero value
