Applying Multipoint Constraint on subspace using dolfinx_mpc
Dear. All
I would like to use dolfinx_mpc extension to apply multipoint constraint on the right edge of 2D rectangular domain. The purpose is to ensure that the right edge remain straight throughout simulation. I implies that the displacement in the x direction of all nodes on this boundary is the same. To achieve this goal, I first specified the degree of freedom associated to the right edge and then selected one degree of freedom as the master and the others as the salves DOFs. After running the code I received the following error:
File “/home/mohhammad/Documents/files/simulations/090/fenics-reaction-diffusion/reaction-diffusion-test2D2-scaled-fenicsx-stress-mpc.py”, line 172, in
MPC_right.add_constraint(ME.sub(2).sub(0), np.array([slave], dtype= np.int32), master_dof, np.array([1.0]),0,0)
File “/home/mohhammad/anaconda3/envs/fenicsx/lib/python3.13/site-packages/dolfinx_mpc/multipointconstraint.py”, line 145, in add_constraint
assert V == self.V
AssertionError
any assistance will be appreciated. I enclosed the relevant part of code:
from dolfinx.mesh import create_rectangle
import basix.ufl
from dolfinx.mesh import meshtags, locate_entities_boundary
from dolfinx.fem import functionspace, Function, locate_dofs_topological, Constant, locate_dofs_geometrical
from dolfinx.mesh import compute_midpoints
from dolfinx import geometry
from dolfinx.cpp.mesh import CellType
from ufl.classes import *
from ufl.algorithms import *
from ufl import Measure
import os
from pathlib import Path
from dolfinx import default_real_type, log, plot
import dolfinx_mpc
# Time parameters
#num_steps = 480000
num_steps= 3600
t = 0.0
t_end = 10*3600
dt = t_end/num_steps
BC_thickness = 100e-6
Oxide_thickness = 1e-6
Lx = 60e-6
Ly = BC_thickness + Oxide_thickness
x_bar = 10e-6
BC_bar = BC_thickness/x_bar
Oxide_bar = Oxide_thickness/x_bar
Lx_bar = Lx/x_bar
Ly_bar = Ly/x_bar
refine_length_bar = 0.01*BC_bar
print(refine_length_bar)
c_characteristic = 0.32e6
#nx, ny = 200,335
nx,ny = 200,335
refined_domain = create_rectangle(MPI.COMM_WORLD, [np.array([0,0]), np.array([Lx_bar,Ly_bar])], [nx,ny])
tdim = refined_domain.topology.dim
def refine_cells(x, tol=1e-16):
return x[1] >= refine_length_bar + tol
with XDMFFile(MPI.COMM_WORLD,"refined_domain_scaled.xdmf","w") as xdmf:
xdmf.write_mesh(refined_domain)
element_degree = 1
variant = basix.LagrangeVariant.equispaced
c_el = basix.ufl.element("Lagrange", refined_domain.topology.cell_name(), element_degree, variant, dtype = default_real_type)
n_el = basix.ufl.element("Lagrange", refined_domain.topology.cell_name(), element_degree, variant, dtype = default_real_type)
u_el = basix.ufl.element("Lagrange", refined_domain.topology.cell_name(), element_degree, variant, dtype = default_real_type, shape = (2,))
s_el = basix.ufl.element("Lagrange", refined_domain.topology.cell_name(), element_degree, variant, dtype = default_real_type, shape = (2,2))
total_elements = basix.ufl.mixed_element([c_el,n_el,u_el])
ME = dolfinx.fem.functionspace(refined_domain, total_elements)
TT = dolfinx.fem.functionspace(refined_domain, s_el)
sig = dolfinx.fem.Function(TT)
w = dolfinx.fem.Function(ME)
w_old = dolfinx.fem.Function(ME)
dw = ufl.TrialFunction(ME)
x= ufl.SpatialCoordinate(refined_domain)
w.sub(1).interpolate(lambda x: np.where(x[1] >= BC_bar, 1.0, 0.0))
with XDMFFile(refined_domain.comm, "phase_sub.xdmf", "w") as xdmf:
xdmf.write_function(w.sub(1))
def top(x):
return np.isclose(x[1], Ly_bar)
def bottom(x):
return np.isclose(x[1], 0.0)
def left(x):
return np.isclose(x[0], 0.0)
def right(x):
return np.isclose(x[0], Lx_bar)
u_space,_ = ME.sub(2).collapse()
u_left = dolfinx.fem.Function(u_space)
u_left.x.array[:] = 0.0
left_facets = dolfinx.mesh.locate_entities_boundary(refined_domain, refined_domain.topology.dim-1,left)
left_u_dofs = dolfinx.fem.locate_dofs_topological((ME.sub(2),u_space),tdim-1,left_facets)
u_left_bc = dolfinx.fem.dirichletbc(u_left,left_u_dofs, ME.sub(2).sub(0))
u_bot = dolfinx.fem.Function(u_space)
u_bot.x.array[:] = 0.0
bot_u_dofs = dolfinx.fem.locate_dofs_topological((ME.sub(2),u_space),tdim-1,bottom_facets)
u_bot_bc = dolfinx.fem.dirichletbc(u_bot,bot_u_dofs, ME.sub(2).sub(1))
right_facets = dolfinx.mesh.locate_entities_boundary(refined_domain, refined_domain.topology.dim-1,right)
right_u_dofs = dolfinx.fem.locate_dofs_topological((ME.sub(2),u_space),tdim-1,right_facets)
ux_dofs = right_u_dofs[0]
master_dof = ux_dofs[0]
MPC_right = dolfinx_mpc.MultiPointConstraint(ME.sub(2).sub(0))
slaves = right_u_dofs[0][1:]
MPC_right.add_constraint(ME.sub(2).sub(0), np.array([slaves], dtype= np.int32), master_dof, np.array([1.0]),0,0)
have you had a look at Rigidity constraint · Issue #9 · jorgensd/dolfinx_mpc · GitHub
which I believe implements the constraint you are thinking of
Massive thanks for your guidance. I applied the procedure in rigidity constrain. Issue #9. Afterwards, the code works but from the results it seems that the multipoint constraint did not function properly because the x-displacement of nodes especially in upper right part of the right edge are not equal. I enclose the updated code and the plot of x displacement of the right edge for further clarification.
import basix.ufl
import os
import dolfinx_mpc
# Time parameters
#num_steps = 480000
num_steps= 3600
t = 0.0
t_end = 10*3600
Lx = 60e-6
x_bar = 10e-6
Lx_bar = Lx/x_bar
Ly_bar = Ly/x_bar
nx, ny = 200,335
element_degree = 1
c_new,n_new,u_new = ufl.split(w)
c_old,n_old,u_old = ufl.split(w_old)
v_c,v_n,v_u = ufl.TestFunctions(ME)
dc,dn,du = ufl.TrialFunctions(ME)
w.sub(0).x.array[:] = 0.0
w.sub(1).x.array[:] = 0.0
w.sub(2).x.array[:] = 0.0
def top(x):
def bottom(x):
def left(x):
def right(x):
c_space, _ = ME.sub(0).collapse()
c_bc_top = dolfinx.fem.Function(c_space)
c_bc_top.x.array[:] = 5e-5
top_facets = dolfinx.mesh.locate_entities_boundary(refined_domain, tdim-1, top)
top_dofs = dolfinx.fem.locate_dofs_topological((ME.sub(0), c_space), tdim-1, top_facets)
c_space_bot, _ = ME.sub(0).collapse()
c_bc_bot = dolfinx.fem.Function(c_space)
c_bc_bot.x.array[:] = 0.0
bottom_facets = dolfinx.mesh.locate_entities_boundary(refined_domain, tdim-1, bottom)
bot_dofs = dolfinx.fem.locate_dofs_topological((ME.sub(0), c_space_bot), tdim-1, bottom_facets)
bc_c_top = dolfinx.fem.dirichletbc(c_bc_top, top_dofs,ME.sub(0))
bc_c_bot = dolfinx.fem.dirichletbc(c_bc_bot,bot_dofs,ME.sub(0))
bcs_problem = [bc_c_top, bc_c_bot,u_left_bc,u_bot_bc]
def mapping(x):
vals = np.zeros(x.shape)
vals[0] = x[0]
vals[1] = 0
vals[2] = 0
return vals
mpc = dolfinx_mpc.MultiPointConstraint(ME.sub(2))
mpc.create_periodic_constraint_geometrical(ME.sub(2).sub(0), right, mapping,bcs_problem)
mpc.finalize()
Could you supply your full code, with 3x` encapsulation, as currently the indentation is wrong, and the code ends at finalizing the MPC, not at the end of solve.
To me, it also seems like you are importing things that are not needed, such as
The following is unused:
and I would be careful with:
as those should be from your MPC space, as discussed in:
In accordance with your note, I changed the function space of solution function to the function space of mpc and now the code works and it seems that rigidity constraint on the right edge is functioned properly. From this communication, I have recognized that mpc cannot be instantiated in subspaces (MultiPointConstraint(subspace)) but the methods like create_periodic_constraint_geometrical() and create_periodic_constraint_topological() can be defined on space or appropriate subspaces. please verify this intuition.
best regards.
The MultiPointConstraint class should be initiated on the patent space, as it is modifying the global (parent) matrix. As you state the constructors can work o subspaces.
I am so grateful.
best regards.
