Am using dolfinx_mpc for the first time and am stuck with the implementation part. I wanted to couple the nodes along facet 3( all the dofs on this facet should have the same temperature). Can anyone guide me through how it should be implemented in a 2D case? I have attached my code where I haven’t implemented the multi-point constraint correctly:
$PhysicalNames
3
1 2 “convection”
1 3 “coupling”
2 1 “domain”
$EndPhysicalNames
from dolfinx.fem import (Constant,dirichletbc, Function, FunctionSpace, LinearProblem,assemble_scalar, locate_dofs_geometrical, locate_dofs_topological)
from dolfinx.fem import (assemble_matrix, assemble_vector, form, apply_lifting, locate_dofs_geometrical, set_bc)
from ufl import (SpatialCoordinate, TestFunction, TrialFunction,dx, ds, grad, inner)
import dolfinx.io
import dolfinx_mpc
import dolfinx_mpc.utils
with dolfinx.io.XDMFFile(MPI.COMM_WORLD, “Mesh.xdmf”, “r”) as xdmf:
mesh = xdmf.read_mesh(name=“Grid”)
mesh.topology.create_connectivity(mesh.topology.dim, mesh.topology.dim)
m_subdomains = xdmf.read_meshtags(mesh, name=“Grid”)
with dolfinx.io.XDMFFile(MPI.COMM_WORLD, “mt.xdmf”, “r”) as xdmf:
m_boundaries = xdmf.read_meshtags(mesh, name=“Grid”)
function space
V = FunctionSpace(mesh, (“CG”, 1))
num_dofs_global = V.dofmap.index_map.size_global * V.dofmap.index_map_bs
print(f"Number of dofs global: {num_dofs_global}")
dx = ufl.Measure(“dx”, domain=mesh, subdomain_data=m_subdomains)
ds = ufl.Measure(“ds”, domain=mesh, subdomain_data=m_boundaries)
Solve Problem without MPC for reference
trial and test functions
T = TrialFunction(V)
parameters
T_amb = Constant(mesh, 50.0) # ambient temperature
kappa = Constant(mesh, 52.0) # thermal conductivity [W/(m*K)]
h = Constant(mesh, 5.0) # heat Transfer Co-efficient [W/(m^2 deg C)]
Robin boundary conditions
r1 = h
Integral_Ra =
Integral_RL =
Integral_Ra.append(r1 * T * v * ds(2))
Integral_RL.append(r1 * T_amb * v * ds(2))
JZ: reformulate for steady state
a = kappa * inner(grad(T),grad(v)) * dx + sum(Integral_Ra)
L = sum(Integral_RL)
problem = LinearProblem(a, L, petsc_options={“ksp_type”: “preonly”, “pc_type”: “lu”})
uh = problem.solve()
Create multipoint constraint
def l2b(li):
return np.array(li, dtype=np.float64).tobytes()
n = dolfinx_mpc.utils.create_normal_approximation(V, m_boundaries, 3)
mpc = dolfinx_mpc.MultiPointConstraint(V)
mpc.finalize()
problem = dolfinx_mpc.LinearProblem(a, L, mpc ,petsc_options={“ksp_type”: “preonly”, “pc_type”: “lu”})
u_h = problem.solve(
