Subdomains with different material properties
I am trying to solve a problem with different materials, based on examples I have found so far.
The code i am using is:
from ufl import nabla_div
Len = 10.0; W = 4.0; H=2.0;
mesh = BoxMesh(Point(0.0, 0.0, 0.0), Point(Len, W, H), 21, 8, 4)
V = VectorFunctionSpace(mesh, “Lagrange”, 1)
Define boundary condition
tol = 1E-14
Mark boundary subdomians
left = CompiledSubDomain(“near(x[0], side) && on_boundary”, side = 0.0)
right = CompiledSubDomain(“near(x[0], side) && on_boundary”, side = 10.0)
Material Variable
mu = 1
rho = 1
delta2 = 0.4*(W/Len)*2
delta1 = 0.4
(2.0*W/Len)**2
class Omega0(SubDomain):
return True if x[2] <= 0.5 + tol else False
class Omega1(SubDomain):
return True if x[2] >= 0.5 - tol else False
subdomains = MeshFunction(‘size_t’, mesh, mesh.topology().dim(), 0)
subdomain0 = Omega0().mark(subdomains, 0)
subdomain1 = Omega1().mark(subdomains, 1)
class K(Expression):
def init(self, subdomains, k_0, k_1, **kwargs):
self.subdomains = subdomains
self.k_0 = k_0
self.k_1 = k_1
if self.subdomains[cell.index] == 0:
values[0] = self.k_0
values[0] = self.k_1
delta = K(subdomains, delta1, delta2, degree=0)
#gamma = 0.4*delta**2
beta = 1.25
lambda_ = beta
#g = gamma
c = Constant((0, 0, 0))
bcl = DirichletBC(V, c, left)
bcr = DirichletBC(V, c, right)
bcs = [bcl, bcr]
Define strain and stress
def sigma(u):
return lambda_nabla_div(u)Identity(d) + 2muepsilon(u)
Define variational problem
d = u.geometric_dimension() # space dimension
f = Constant((0, 0, -rho*delta))
T = Constant((0, 0, 0))
L = dot(f, v)*dx + dot(T, v)*ds
Compute solution
solve(a == L, u, bcs)
Save solution to file in VTK format
File(‘liner_def/displacement.pvd’) << u
However, I always get this Error:
File “test_def_linear2.py”, line 45, in
File “test_def_linear2.py”, line 35, in init
File “/usr/lib/python3/dist-packages/dolfin/function/expression.py”, line 438, in setattr
elif name in self._parameters:
File “/usr/lib/python3/dist-packages/dolfin/function/expression.py”, line 432, in getattr
return self._parameters[name]
[Previous line repeated 327 more times]
RecursionError: maximum recursion depth exceeded
Thanks for you help :slight_smile:
Likely you want UserExpression not Expression,
cf. https://fenicsproject.org/docs/dolfin/2019.1.0/python/demos/cahn-hilliard/demo_cahn-hilliard.py.html
Hi
There are a couple issues in your example. First, the K Expression needs some modifications. Second there are some missing mathematical operators for example in sigma(u). Third, the term f in LHS should be defined as a vector not as a constant. With that being said you may want to consider the following:
Len = 10.0
W = 4.0
H=2.0
V = VectorFunctionSpace(mesh, 'Lagrange', 1)
tol = 1E-14
left = CompiledSubDomain('near(x[0], side) && on_boundary', side = 0.0)
right = CompiledSubDomain('near(x[0], side) && on_boundary', side = 10.0)
mu = 1
rho = 1
delta1 = 0.4*(2.0*W/Len)**2
subdomains = MeshFunction('size_t', mesh, mesh.topology().dim(), 0)
    def __init__(self, **kwargs):
        self.subdomains = kwargs['subdomains']
        self.k_0 = kwargs['k_0']
        self.k_1 = kwargs['k_1']
delta = K(subdomains=subdomains, k_0 = delta1, k_1 = delta2, degree=0)
beta = 1.25
lambda_ = beta
bcs = [bcl, bcr]
def sigma(u):
    return lambda_*nabla_div(u)*Identity(d) + 2*mu*epsilon(u)
f = as_vector([0] + [0]+ [-rho*delta])
File('displacement.pvd') << u
so I have changed the Expression to UserExpression:
class K(UserExpression):
self.k_0 = k_0
self.k_1 = k_1
def value_shape(self):
return (2,)
and f to:
Now I get this Error:
File “test_def_linear3.py”, line 54, in
File “/usr/lib/python3/dist-packages/dolfin/fem/dirichletbc.py”, line 131, in init
super().init(*args)
RuntimeError:
*** Error: Unable to create Dirichlet boundary condition.
*** Reason: Illegal value rank (1), expecting (2).
*** Where: This error was encountered inside DirichletBC.cpp.
*** Process: 0
*** DOLFIN version: 2019.1.0
*** Git changeset: unknown
Thank again :slight_smile:
Please provide your full example code like your very first post. In addition edit your code in a format so we could copy and paste it without issue.
# Define boundary condition
tol = 1E-14
# Mark boundary subdomians
left =  CompiledSubDomain("near(x[0], side) && on_boundary", side = 0.0)
right = CompiledSubDomain("near(x[0], side) && on_boundary", side = 10.0)
# Material Variable
mu = 1
rho = 1
delta2 = 0.4*(W/Len)**2
delta1 = 0.4*(1.0*W/Len)**2
    def __init__(self, subdomains, k_0, k_1, **kwargs):
        self.k_0 = k_0
        self.k_1 = k_1
        return (2,)
beta = 1.25
lambda_ = beta
bcs = [bcl, bcr]
# Define strain and stress
def sigma(u):
#f = Constant((0, 0, -rho*delta))
# Compute solution
# Save solution to file in VTK format
File('liner_def3/displacement.pvd') << u
You do not need a vector-valued expression in this case. Consider this:
Len = 10.0;
W = 4.0;
H = 2.0;
tol = 1E-14
left = CompiledSubDomain("near(x[0], side) && on_boundary", side=0.0)
right = CompiledSubDomain("near(x[0], side) && on_boundary", side=10.0)
# Material Variable
mu = 1
rho = 1
delta2 = 0.4 * (W / Len) ** 2
delta1 = 0.4 * (1.0 * W / Len) ** 2
beta = 1.25
lambda_ = beta
bcs = [bcl, bcr]
    return 0.5 * (nabla_grad(u) + nabla_grad(u).T)
def sigma(u):
    return lambda_ * nabla_div(u) * Identity(d) + 2 * mu * epsilon(u)
f = as_vector([0] + [0] + [-rho*delta])
a = inner(sigma(u), epsilon(v)) * dx
L = dot(f, v) * dx + dot(T, v) * ds
# Compute solution
File('disp.pvd') << u
That gives the same Error:
File “test_def_linear4.py”, line 82, in
File “/usr/lib/python3/dist-packages/ufl/exproperators.py”, line 203, in _rmul
return _mult(o, self)
File “/usr/lib/python3/dist-packages/ufl/exproperators.py”, line 124, in _mult
s1, s2 = a.ufl_shape, b.ufl_shape
File “/usr/lib/python3/dist-packages/ufl/coefficient.py”, line 73, in ufl_shape
return self._ufl_shape
AttributeError: ‘K’ object has no attribute ‘_ufl_shape’
I guess you are using 2018 version and python 3. I am using 2017.2.0 with python 2.7 and it works fine on my machine. Adding Super Function in the class K:
super().__init__(**kwargs)
may solve the problem. Take a look at this demo
Yes, I Am using 2019 with python3.
The K - class looks like this now:
delta = K(subdomains=subdomains, k_0 = delta1, k_1 = delta2)
And a new Error appears…:
File “test_def_linear4.py”, line 56, in
File “test_def_linear4.py”, line 46, in init
super().init(**kwargs)
File “/usr/lib/python3/dist-packages/dolfin/function/expression.py”, line 256, in init
raise RuntimeError(“Invalid keyword argument”)
RuntimeError: Invalid keyword argument
Try this, I think it should works:
    		self.k_0 = k_0
    		self.k_1 = k_1
Well it did not work, but this did:
       self.k_0 = k_0
       self.k_1 = k_1
So the programs runs with a warning:
WARNING: user expression has not supplied value_shape method or an element. Assuming scalar element.
then it works or not ? since you have an scalar value to evaluate you don’t need to define the value shape
anyway you can add it after def eval_cell block as follows:
def values_shape(self):
    return (1,)
sorry for the short answer. Yes it works now thank you very much.
cool :), you can mark it as solved then
How? ^^ I dont see the button
hi :slight_smile: , below the message you can choose it to mark the message as solved in the answer than has solved your problem, from left to right you have solve, share, edit, show more and Reply as in the image I attached below. have a nice day!
Hi cas91, I have a similar problem in defining different materials. Could you help me? This is my code
Blockquote
def boundary(x, on_boundary):
tol = 1E-14
return on_boundary and near(x[0], 0, tol)
class Boundary(SubDomain):
tol = 1E-14
N_POINTS_P_AXIS = 11
mesh = UnitSquareMesh(N_POINTS_P_AXIS, N_POINTS_P_AXIS)
tol = 1E-14
k_0 = 1.0
k_1 = 0.01
V = FunctionSpace(mesh, “DG”, 0)
boundary = Boundary()
bc = DirichletBC(V, Constant(0), boundary)
class Omega_0(SubDomain):
return x[1] <= 0.5 + tol
class Omega_1(SubDomain):
return x[1] >= 0.5 - tol
materials = MeshFunction(‘size_t’, mesh, mesh.topology().dim())
print(materials)
subdomain_0 = Omega_0()
subdomain_1 = Omega_1()
subdomain_0.mark(materials, 0)
subdomain_1.mark(materials, 1)
materials.set_all(0)
plot(materials)
def init(self, materials, k_0, k_1, **kwargs):
self.materials = materials
self.k_0 = k_0
self.k_1 = k_1
if self.materials[cell.index] == 0:
kappa = K(materials, k_0, k_1, degree=0)
I would strongly suggest that you use 3x` encapsulation, to ensure that the indentation and formatting is consistent, i.e.
```python
def test(x):
    return x[0]
An apology, I think I was able to fix my mistake, now what I want to see is if I did it correctly. I want to know the kappa value, is it possible? This is my code
    tol = 1E-14
        tol = 1E-14
tol = 1E-14
k_0 = 1.0
k_1 = 0.01
V = FunctionSpace(mesh, "DG", 0)
kappa = Function(V)
materials = MeshFunction('size_t', mesh, mesh.topology().dim())
print(materials)
File('materials.xml') << materials
plot(materials)
    def __init__(self, materials, k_0, k_1, **kwargs):
        self.k_0 = k_0
        self.k_1 = k_1
        return ()
print(K.compute_vertex_values(mesh))
