We are running a parallel computation and need to reconstruct the global connectivity matrix and the global node vector. Specifically, we compute a quantity h locally on each node of our mesh within each processor. Now, we need to assemble the global vector (h_global) of this quantity h, ordered according to the global node numbering.
We’ve attached a simplified example of our code.
Do you have any suggestions on how to correctly build the global vectors in the proper order?
import basix
def compute_face_area(A,B,C):
A = np.array(A)
B = np.array(B)
C = np.array(C)
AB = B - A
AC = C - A
cross_product = np.cross(AB, AC)
area = 0.5 * np.linalg.norm(cross_product)
return area
comm = MPI.COMM_WORLD
rank = comm.rank
size = comm.size
msh = dolfinx.mesh.create_unit_cube(MPI.COMM_WORLD, 5, 5, 5)
elem = basix.ufl.element("Lagrange", msh.basix_cell(), 1)
V= dolfinx.fem.functionspace(msh, elem)
num_cells = len(V.dofmap.list)
h_ele_vect = np.zeros(num_cells)
for (ii,k) in enumerate(V.dofmap.list):
p0 = msh.geometry.x[k[0]]
p1 = msh.geometry.x[k[1]]
p2 = msh.geometry.x[k[2]]
p3 = msh.geometry.x[k[3]]
area1 = compute_face_area(p0,p1,p2)
area2 = compute_face_area(p1,p2,p3)
area3 = compute_face_area(p2,p3,p0)
area4 = compute_face_area(p3,p0,p1)
h = np.sum([area1, area2, area3, area4])
h_ele_vect[ii] = h
num_nodes = len(msh.geometry.x)
# we don't know how to avoid the ghosts nodes in the global vector reconstruction
ghosts = msh.geometry.index_map().ghosts
h_nodes_vect = np.zeros(num_nodes-len(ghosts))
for ii in range(len(h_nodes_vect)):
k = np.where(np.array(V.dofmap.list)==ii)
h_nodes_vect[ii] = np.mean(h_ele_vect[k[0]])
h_global = comm.gather(h_nodes_vect, root=0)
if rank == 0:
h_global = np.concatenate(h_global)
print("h_nodes_vect", h_global)
I’m a bit confused about what you are trying to do.
It seems like you for each cell want to find the accumulated area of all faces of that element.
Is this what you want to do?
If so, I don’t really understand why you are constructing a P1 function space, and are assuming that the degrees of freedom are 1 to 1 with the mesh geometry.
Sorry for the confusion. To clarify, we are working on a mesh adaptation problem. The specific way we compute the function h is not important for our question— in our actual code, h depends on the solution of a PDEs problem.
We didn’t attach the full code because it would have been too long and complex. Instead, we provided a simplified toy example to illustrate the core issue.
Our main question is: How can we assemble a global vector in MPI for a generic function h defined on the mesh nodes, ensuring it is correctly ordered according to the global node numbering across all processors? The challenge is related to the presence of ghost nodes, which are shared among multiple processors, and we want to avoid duplication or inconsistencies when building the global vector.
You can always just work on the local part of your array, and then call u.x.scatter_forward() to distribute results from the process that owns the data, to those that “ghosts” it. See for instance Parallel Computations with Dolfinx using MPI — MPI tutorial
Thank you. We need to write the node coordinates, connectivity matrix, and the h vector to a file in order to use them with TetGen, which does not support parallel execution. Our idea is to gather all the data on the first processor and write the file from there.
It is quite easy to gather the local mesh geometry and topology, as each of them has an index map that can be used to map from local to global indices.
