Assertion error, mesh is None
from dolfinx import *
from mpi4py import *
mesh = mesh.create_unit_interval(MPI.COMM_WORLD,8)
V = fem.FunctionSpace(mesh,"Lagrange",2)
print('done')
root@818ab534cb85:~/sandbox# cd /root/sandbox ; /usr/bin/env /bin/python3 /root/.vscode-server/extensions/ms-python.python-2023.12.0/pythonFiles/lib/python/debugpy/adapter/…/…/debugpy/launcher 46521 – /root/sandbox/sandbox.py
File “/root/sandbox/sandbox.py”, line 5, in
V = fem.FunctionSpace(mesh,“Lagrange”,2)
File “/usr/local/dolfinx-real/lib/python3.10/dist-packages/dolfinx/fem/function.py”, line 469, in init
assert mesh is None
AssertionError
Anyone can shed light on why this assertion error. Is that the way things are included on an rc1 docker image for cpp?
You should avoid wildcard import while using dolfinx as written here FEniCSx tutorial. So, the code becomes -
from dolfinx import mesh
from dolfinx.fem import FunctionSpace
points = [0., 8.]
mesh = mesh.create_interval(MPI.COMM_WORLD,8,points)
V = FunctionSpace(mesh,("CG", 2))
You can use pyvista or paraview to visualize as the mesh as done in the same tutorial I mentioned above FEniCSx tutorial.
