Assertion error while using functionspace with MixedElement
I am trying to use two function spaces V and Q for variable u and p of Navier Stokes equation. I need to combine the spaces so as to use Newton Solver to solve the steady state equation. But I getting AssertionError. My code is as follows:
from dolfinx.io import (gmshio)
from ufl.finiteelement import MixedElement
from dolfinx.fem import Function
from ufl import (TestFunction, TrialFunction,split)
gdim = 2
mesh_comm = MPI.COMM_WORLD
model_rank = 0
mesh, _, ft =gmshio.read_from_msh("cylinder.msh", mesh_comm, model_rank, gdim)
##function spaces
v_cg2 = element("Lagrange", mesh.topology.cell_name(), 2,shape=(mesh.geometry.dim, ))
s_cg1 = element("Lagrange", mesh.topology.cell_name(), 1)
mixEl = MixedElement([v_cg2, s_cg1])
#combined space
W = functionspace(mesh, mixEl)
# Test and trial functions: monolithic
(v, q) = TestFunctions(W)
dup = TrialFunction(W)
uh  = fem.Function(W)
(u, p) = split(uh)
The error message is:
AssertionError                            Traceback (most recent call last)
Cell In[9], line 6
      4 mixEl = MixedElement([v_cg2, s_cg1])
      5 #combined space
----> 6 W = functionspace(mesh, mixEl)
      7         # Test and trial functions: monolithic
      8 (v, q) = TestFunctions(W)
File /usr/lib/petsc/lib/python3/dist-packages/dolfinx/fem/function.py:655, in functionspace(mesh, element, form_compiler_options, jit_options)
    653     form_compiler_options = dict()
    654 form_compiler_options["scalar_type"] = dtype
--> 655 (ufcx_element, ufcx_dofmap), module, code = jit.ffcx_jit(
    656     mesh.comm,
    657     ufl_e,
    658     form_compiler_options=form_compiler_options,
    659     jit_options=jit_options,
    660 )
    662 ffi = module.ffi
    663 if np.issubdtype(dtype, np.float32):
File /usr/lib/petsc/lib/python3/dist-packages/dolfinx/jit.py:51, in mpi_jit_decorator.<locals>.mpi_jit(comm, *args, **kwargs)
     47 @functools.wraps(local_jit)
     48 def mpi_jit(comm, *args, **kwargs):
     49     # Just call JIT compiler when running in serial
     50     if comm.size == 1:
---> 51         return local_jit(*args, **kwargs)
     53     # Default status (0 == ok, 1 == fail)
     54     status = 0
File /usr/lib/petsc/lib/python3/dist-packages/dolfinx/jit.py:203, in ffcx_jit(ufl_object, form_compiler_options, jit_options)
    201     r = ffcx.codegeneration.jit.compile_forms([ufl_object], options=p_ffcx, **p_jit)
    202 elif isinstance(ufl_object, ufl.AbstractFiniteElement):
--> 203     r = ffcx.codegeneration.jit.compile_elements([ufl_object], options=p_ffcx, **p_jit)
    204 elif isinstance(ufl_object, ufl.Mesh):
    205     r = ffcx.codegeneration.jit.compile_coordinate_maps([ufl_object], options=p_ffcx, **p_jit)
File /usr/lib/python3/dist-packages/ffcx/codegeneration/jit.py:158, in compile_elements(elements, options, cache_dir, timeout, cffi_extra_compile_args, cffi_verbose, cffi_debug, cffi_libraries, visualise)
    156 names = []
    157 for e in elements:
--> 158     name = ffcx.naming.finite_element_name(e, module_name)
    159     names.append(name)
    160     name = ffcx.naming.dofmap_name(e, module_name)
File /usr/lib/python3/dist-packages/ffcx/naming.py:107, in finite_element_name(ufl_element, prefix)
    105 def finite_element_name(ufl_element: basix.ufl._ElementBase, prefix: str) -> str:
    106     """Get finite element name."""
--> 107     assert isinstance(ufl_element, basix.ufl._ElementBase)
    108     sig = compute_signature([ufl_element], prefix)
    109     return f"element_{sig}"
AssertionError:
Any help is appreciated.
Please note that you havent provided a minimal reproducible example, as we do not have the mesh. Could you provide a minimal example using a unit square mesh?
Please also note that I did modify your code by adding
```python
# code here
to make it properly format.
Thanks for pointing out.
here is the minimalist code:
from basix.ufl import element
from dolfinx import mesh
from dolfinx.fem import Function, functionspace
gdim = 2
model_rank = 0
dom = mesh.create_unit_square(MPI.COMM_WORLD, 10, 10)
##function spaces
v_cg2 = element("Lagrange", dom.topology.cell_name(), 2,shape=(dom.geometry.dim, ))
s_cg1 = element("Lagrange", dom.topology.cell_name(), 1)
#combined space
W = functionspace(dom, mixEl)
(u, p) = split(uh)
You should use basix.ufl.mixed_element.
MWE below:
from ufl import (TestFunctions, TrialFunction,split)
gdim = 2
model_rank = 0
##function spaces
mixEl = mixed_element([v_cg2, s_cg1])
#combined space
uh  = Function(W)
(u, p) = split(uh)
Thanks this worked. I am able to produce desired results
