Assertion error on Poisson problem with complex option
In testing the complex number option on FEniCSx, I got an assertion error.
%python3 CmplxPoisson.py
float64
complex128
<class ‘numpy.float64’>****THIS IS SUPPOSED TO BE <class ‘numpy.complex128’>
File “/Users/carlajadamson/Documents/CmplxPoisson.py”, line 16, in
assert np.dtype(PETSc.ScalarType).kind == ‘c’
AssertionError
I assume this means that I did not get the correct version of PETSc downloaded when I downloaded FEniCSx from this site: https://fenicsproject.org/download/. Is there an update I missed?
I am on MAC Book running Apple M3 Max.
See: Conda install dolfinx for complex-valued problem - #4 by dokken
The output was
no matches found: petsc==complex
This is what was downloaded from FEniCSx
petsc conda-forge/osx-arm64::petsc-3.20.5-real_h7646cce_100
petsc4py conda-forge/osx-arm64::petsc4py-3.20.5-real_hd567e68_100
Please provide the full command that you were running, and the full output (not just the last line of the error message).
conda create -n env3-10-complex -c conda-forge python=3.10 fenics-dolfinx petsc=*=complex* mpich
zsh: no matches found: petsc==complex
I cannot reproduce this on my linux system. @minrk do you know why this isn’t working on osx-arm64?
zsh (not mac-specific, but it is the default shell on macs) expands globs a little differently from bash, you need to put strings with * that aren’t file globs in quotes to prevent glob expansion:
conda create -n env3-10-complex -c conda-forge python=3.10 fenics-dolfinx 'petsc=*=complex*' mpich
bash has weird but useful glob expansion behavior where if a glob doesn’t match anything it’s replaced by the original pattern, effectively assuming you didn’t mean it as a glob, whereas zsh always treats globs as globs and tells you when they don’t match anything.
used yours and got the complex download:
petsc conda-forge/osx-arm64::petsc-3.20.5-complex_h8e9ca2b_0
petsc4py conda-forge/osx-arm64::petsc4py-3.20.5-complex_h1f0f144_0
However, when I run the program:
float64
complex128
AssertionError
should I put * in somewhere in code?
Please provide the output of conda env export
Never mind! I was so excited at a solution to my problem, I forgot to activate the environment!
Thank you!
