I am receiving the error:
VerificationError: CompileError: command '/usr/bin/x86_64-linux-gnu-gcc' failed with exit code 1
when I try to define my problem. I am modeling a reaction-diffusion equation and have done it successfully with one variable, but it fails when I go to a mixed space. All of my code runs fine until I define “problem = …”. Here’s how I set it up:
from dolfinx import fem, io, nls, log, mesh, plot
L = 5e-3
D = 6.591637557240176e-06
k = 0.12
C_0 = 0.00133
t_final = 60*60*24
t_step = 1
N_0 = 20
domain = mesh.create_interval(MPI.COMM_WORLD, 100, [0, L])
P1 = ufl.FiniteElement('CG', domain.ufl_cell(), 1)
element = ufl.MixedElement([P1, P1])
V = fem.FunctionSpace(domain, element)
# test functions
v1, v2 = ufl.TestFunctions(V)
# fields to solve for
u = fem.Function(V)
u1, u2 = u.split()
# concentrations from previous timestep
u_n = fem.Function(V)
u_n1, u_n2 = u_n.split()
# apply timestep variable to each node in the mesh
dt = fem.Constant(domain, ScalarType(t_step))
# turn floats to Constant objects
D_ = fem.Constant(domain, ScalarType(D))
k_ = fem.Constant(domain, ScalarType(k))
# set initial conditions
u1.vector.array = C_0 * np.ones(u1.vector.array.shape)
u2.vector.array = N_0 * np.ones(u2.vector.array.shape)
# function determining if a node is on the tray top
def on_top_boundary(x):
return(np.isclose(x[0], L))
# fetch subspace for just u1
V0, submap = V.sub(0).collapse()
# determine boundary DOFs
boundary_dofs = fem.locate_dofs_geometrical((V.sub(0), V0), on_top_boundary)
# apply dirichlet BC to boundary DOFs
bc = fem.dirichletbc(ScalarType(C_0), boundary_dofs[0], V.sub(0))
F = (1/dt)*(u1 - u_n1)*v1*ufl.dx + \
(1/dt)*(u2 - u_n2)*v2*ufl.dx + \
D_*ufl.inner(ufl.grad(u1), ufl.grad(v1))*ufl.dx + \
k_*u1*u2*v1*ufl.dx + \
k_*u1*u2*v2*ufl.dx
problem = fem.petsc.NonlinearProblem(F, u, bcs=[bc])
The full error it spits out is:
libffcx_forms_54c4dce6faad875e8265b909b02c0945426b6539.c: In function ‘functionspace_form_libffcx_forms_54c4dce6faad875e8265b909b02c0945426b6539_0’:
libffcx_forms_54c4dce6faad875e8265b909b02c0945426b6539.c:1076:59: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘-’ token
1076 | static ufcx_function_space functionspace_f_140433230527424-1 =
libffcx_forms_54c4dce6faad875e8265b909b02c0945426b6539.c:1077:1: error: expected expression before ‘{’ token
1077 | {
libffcx_forms_54c4dce6faad875e8265b909b02c0945426b6539.c:1085:59: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘-’ token
1085 | static ufcx_function_space functionspace_f_140433230524672-1 =
libffcx_forms_54c4dce6faad875e8265b909b02c0945426b6539.c:1086:1: error: expected expression before ‘{’ token
1086 | {
libffcx_forms_54c4dce6faad875e8265b909b02c0945426b6539.c:1094:59: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘-’ token
1094 | static ufcx_function_space functionspace_f_140433230524672-0 =
libffcx_forms_54c4dce6faad875e8265b909b02c0945426b6539.c:1095:1: error: expected expression before ‘{’ token
1095 | {
libffcx_forms_54c4dce6faad875e8265b909b02c0945426b6539.c:1103:59: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘-’ token
1103 | static ufcx_function_space functionspace_f_140433230527424-0 =
libffcx_forms_54c4dce6faad875e8265b909b02c0945426b6539.c:1104:1: error: expected expression before ‘{’ token
1104 | {
libffcx_forms_54c4dce6faad875e8265b909b02c0945426b6539.c:1115:11: error: ‘functionspace_f_140433230527424’ undeclared (first use in this function)
1115 | return &functionspace_f_140433230527424-1;
libffcx_forms_54c4dce6faad875e8265b909b02c0945426b6539.c:1115:11: note: each undeclared identifier is reported only once for each function it appears in
libffcx_forms_54c4dce6faad875e8265b909b02c0945426b6539.c:1117:11: error: ‘functionspace_f_140433230524672’ undeclared (first use in this function)
1117 | return &functionspace_f_140433230524672-1;
DistutilsExecError Traceback (most recent call last)
File /usr/lib/python3.9/distutils/unixccompiler.py:117, in UnixCCompiler._compile(self, obj, src, ext, cc_args, extra_postargs, pp_opts)
116 try:
--> 117 self.spawn(compiler_so + cc_args + [src, '-o', obj] +
118 extra_postargs)
119 except DistutilsExecError as msg:
File /usr/lib/python3.9/distutils/ccompiler.py:910, in CCompiler.spawn(self, cmd)
909 def spawn(self, cmd):
--> 910 spawn(cmd, dry_run=self.dry_run)
File /usr/lib/python3.9/distutils/spawn.py:91, in spawn(cmd, search_path, verbose, dry_run)
90 cmd = cmd[0]
---> 91 raise DistutilsExecError(
92 "command %r failed with exit code %s" % (cmd, exitcode))
DistutilsExecError: command '/usr/bin/x86_64-linux-gnu-gcc' failed with exit code 1
CompileError Traceback (most recent call last)
File /usr/local/lib/python3.9/dist-packages/cffi/ffiplatform.py:51, in _build(tmpdir, ext, compiler_verbose, debug)
50 distutils.log.set_verbosity(compiler_verbose)
---> 51 dist.run_command('build_ext')
52 cmd_obj = dist.get_command_obj('build_ext')
File /usr/lib/python3.9/distutils/dist.py:985, in Distribution.run_command(self, command)
984 cmd_obj.ensure_finalized()
--> 985 cmd_obj.run()
986 self.have_run[command] = 1
File /usr/lib/python3.9/distutils/command/build_ext.py:340, in build_ext.run(self)
339 # Now actually compile and link everything.
--> 340 self.build_extensions()
File /usr/lib/python3.9/distutils/command/build_ext.py:449, in build_ext.build_extensions(self)
448 else:
--> 449 self._build_extensions_serial()
File /usr/lib/python3.9/distutils/command/build_ext.py:474, in build_ext._build_extensions_serial(self)
473 with self._filter_build_errors(ext):
--> 474 self.build_extension(ext)
File /usr/lib/python3.9/distutils/command/build_ext.py:529, in build_ext.build_extension(self, ext)
527 macros.append((undef,))
--> 529 objects = self.compiler.compile(sources,
530 output_dir=self.build_temp,
531 macros=macros,
532 include_dirs=ext.include_dirs,
533 debug=self.debug,
534 extra_postargs=extra_args,
535 depends=ext.depends)
537 # XXX outdated variable, kept here in case third-part code
538 # needs it.
File /usr/lib/python3.9/distutils/ccompiler.py:574, in CCompiler.compile(self, sources, output_dir, macros, include_dirs, debug, extra_preargs, extra_postargs, depends)
573 continue
--> 574 self._compile(obj, src, ext, cc_args, extra_postargs, pp_opts)
576 # Return *all* object filenames, not just the ones we just built.
File /usr/lib/python3.9/distutils/unixccompiler.py:120, in UnixCCompiler._compile(self, obj, src, ext, cc_args, extra_postargs, pp_opts)
--> 120 raise CompileError(msg)
VerificationError Traceback (most recent call last)
Input In [151], in <cell line: 1>()
----> 1 problem = fem.petsc.NonlinearProblem(F, u, bcs=[bc])
File /usr/local/dolfinx-real/lib/python3.8/dist-packages/dolfinx/fem/petsc.py:616, in NonlinearProblem.__init__(self, F, u, bcs, J, form_compiler_params, jit_params)
594 def __init__(self, F: ufl.form.Form, u: _Function, bcs: typing.List[DirichletBCMetaClass] = [],
595 J: ufl.form.Form = None, form_compiler_params={}, jit_params={}):
596 """Initialize solver for solving a non-linear problem using Newton's method, :math:`dF/du(u) du = -F(u)`.
597
598 Args:
614
615 """
--> 616 self._L = _create_form(F, form_compiler_params=form_compiler_params,
617 jit_params=jit_params)
619 # Create the Jacobian matrix, dF/du
620 if J is None:
File /usr/local/dolfinx-real/lib/python3.8/dist-packages/dolfinx/fem/forms.py:139, in form(form, dtype, form_compiler_params, jit_params)
136 return list(map(lambda sub_form: _create_form(sub_form), form))
137 return form
--> 139 return _create_form(form)
File /usr/local/dolfinx-real/lib/python3.8/dist-packages/dolfinx/fem/forms.py:134, in form.<locals>._create_form(form)
131 """Recursively convert ufl.Forms to dolfinx.fem.Form, otherwise
132 return form argument"""
133 if isinstance(form, ufl.Form):
--> 134 return _form(form)
135 elif isinstance(form, collections.abc.Iterable):
File /usr/local/dolfinx-real/lib/python3.8/dist-packages/dolfinx/fem/forms.py:108, in form.<locals>._form(form)
105 if mesh is None:
106 raise RuntimeError("Expecting to find a Mesh in the form.")
--> 108 ufcx_form, module, code = jit.ffcx_jit(mesh.comm, form,
109 form_compiler_params=form_compiler_params,
110 jit_params=jit_params)
112 # For each argument in form extract its function space
113 V = [arg.ufl_function_space()._cpp_object for arg in form.arguments()]
File /usr/local/dolfinx-real/lib/python3.8/dist-packages/dolfinx/jit.py:56, in mpi_jit_decorator.<locals>.mpi_jit(comm, *args, **kwargs)
51 @functools.wraps(local_jit)
52 def mpi_jit(comm, *args, **kwargs):
53
54 # Just call JIT compiler when running in serial
55 if comm.size == 1:
---> 56 return local_jit(*args, **kwargs)
58 # Default status (0 == ok, 1 == fail)
59 status = 0
File /usr/local/dolfinx-real/lib/python3.8/dist-packages/dolfinx/jit.py:204, in ffcx_jit(ufl_object, form_compiler_params, jit_params)
202 # Switch on type and compile, returning cffi object
203 if isinstance(ufl_object, ufl.Form):
--> 204 r = ffcx.codegeneration.jit.compile_forms([ufl_object], parameters=p_ffcx, **p_jit)
205 elif isinstance(ufl_object, ufl.FiniteElementBase):
206 r = ffcx.codegeneration.jit.compile_elements([ufl_object], parameters=p_ffcx, **p_jit)
File /usr/local/lib/python3.9/dist-packages/ffcx/codegeneration/jit.py:168, in compile_forms(forms, parameters, cache_dir, timeout, cffi_extra_compile_args, cffi_verbose, cffi_debug, cffi_libraries)
165 for name in form_names:
166 decl += form_template.format(name=name)
--> 168 impl = _compile_objects(decl, forms, form_names, module_name, p, cache_dir,
169 cffi_extra_compile_args, cffi_verbose, cffi_debug, cffi_libraries)
170 except Exception:
171 # remove c file so that it will not timeout next time
172 c_filename = cache_dir.joinpath(module_name + ".c")
File /usr/local/lib/python3.9/dist-packages/ffcx/codegeneration/jit.py:252, in _compile_objects(decl, ufl_objects, object_names, module_name, parameters, cache_dir, cffi_extra_compile_args, cffi_verbose, cffi_debug, cffi_libraries)
250 f = io.StringIO()
251 with redirect_stdout(f):
--> 252 ffibuilder.compile(tmpdir=cache_dir, verbose=True, debug=cffi_debug)
253 s = f.getvalue()
254 if (cffi_verbose):
File /usr/local/lib/python3.9/dist-packages/cffi/api.py:725, in FFI.compile(self, tmpdir, verbose, target, debug)
723 raise ValueError("set_source() must be called before compile()")
724 module_name, source, source_extension, kwds = self._assigned_source
--> 725 return recompile(self, module_name, source, tmpdir=tmpdir,
726 target=target, source_extension=source_extension,
727 compiler_verbose=verbose, debug=debug, **kwds)
File /usr/local/lib/python3.9/dist-packages/cffi/recompiler.py:1564, in recompile(ffi, module_name, preamble, tmpdir, call_c_compiler, c_file, source_extension, extradir, compiler_verbose, target, debug, **kwds)
1562 print('%s %r' % (msg, os.path.abspath(tmpdir)))
1563 os.chdir(tmpdir)
-> 1564 outputfilename = ffiplatform.compile('.', ext,
1565 compiler_verbose, debug)
1566 finally:
1567 os.chdir(cwd)
File /usr/local/lib/python3.9/dist-packages/cffi/ffiplatform.py:22, in compile(tmpdir, ext, compiler_verbose, debug)
20 saved_environ = os.environ.copy()
21 try:
---> 22 outputfilename = _build(tmpdir, ext, compiler_verbose, debug)
23 outputfilename = os.path.abspath(outputfilename)
24 finally:
25 # workaround for a distutils bugs where some env vars can
26 # become longer and longer every time it is used
File /usr/local/lib/python3.9/dist-packages/cffi/ffiplatform.py:58, in _build(tmpdir, ext, compiler_verbose, debug)
55 distutils.log.set_threshold(old_level)
56 except (distutils.errors.CompileError,
57 distutils.errors.LinkError) as e:
---> 58 raise VerificationError('%s: %s' % (e.__class__.__name__, e))
59 #
60 return soname
