Spawning independent dolfin processes with mpi4py AND mshr
I’m trying to spawn independent processes using mpi4py AND mshr. Each of these processes solves the same PDE using Dolfin. I tried to generalize the result from this discussion. My actual geometry is more complex than in the example below.
import dolfin
import mshr
comm = PETSc.Comm(MPI.COMM_SELF)
vertics = [dolfin.Point(0,0),dolfin.Point(1,0),dolfin.Point(1,1),dolfin.Point(0,1),dolfin.Point(0,0)]
domain = mshr.Polygon(vertics)
mesh = mshr.generate_mesh(domain, 20)
How do you pass comm to the mesh?
Or how do you avoid mshr from distributing the mesh to different processes? Back in 2015, there was a discussion of how to implement a bool distribute parameter in generate_mesh, but this hasn’t happened. The function mshr._generate is also no longer available in the 2019 version of fenics and mshr.
