Issue with MPI and UnitSquareMesh in python
I try to use using FEniCS in an MPI environment. the following code gives me errors:
import dolfin as dl
mesh = dl.UnitSquareMesh(MPI.COMM_SELF, 127,  127)
and the error is
  File "/zhome/93/8/155259/Paper-PAT-RTO/applications/pat_2D/MAP_estimate.py", line 38, in run_MAP
    mesh = dl.UnitSquareMesh(MPI.COMM_SELF, N_points, N_points)
TypeError: __init__(): incompatible constructor arguments. The following argument types are supported:
    1. dolfin.cpp.generation.UnitSquareMesh(nx: int, ny: int, diagonal: str = 'right')
    2. dolfin.cpp.generation.UnitSquareMesh(comm: dolfin.cpp.MPICommWrapper, nx: int, ny: int, diagonal: str = 'right')
I don’t know how to wrap the MPI communicator into a FEniCS format? Any ideas?
In legacy DOLFIN, you should use
dolfin.MPI.comm_self
rather than a mpi4py-communicator directly.
Thank you! Solved the issue
