I have imported a step file into gmsh with importshape and am now trying to only extract one surface of the triangular mesh, for example all surface tags that belong in the range (xmin,ymin) and (xmax,ymax) at either zmin or zmax. Note that I am using gmsh to transform the step file into msh and then using meshio to read the msh, create an xdmf, and then I use that xdmf with dolfinx. I am not sure whether what I wish belongs in the meshio workflow or the gmsh workflow. Also this is done in google colab.
Consider the MWE of the workflow. I added a portion after to show what I intend to use this for. As of now my output answer is all NaN, I assume bc of mesh problems.
gmsh.clear()
gmsh.model.add("hbase")
gmsh.model.setCurrent('hbase')
v = gmsh.model.occ.importShapes('/content/drive/MyDrive/Colab Notebooks/hrehbase2.step',highestDimOnly = 'true', format = "step")
xmin, ymin, zmin, xmax, ymax, zmax = gmsh.model.occ.getBoundingBox(
v[0][0], v[0][1])
gmsh.model.occ.removeAllDuplicates()
gmsh.model.occ.synchronize()
testtags = gmsh.model.getEntitiesInBoundingBox(xmin,ymin,zmin,xmax,ymax,zmax,dim=-1)
gmsh.model.mesh.generate(3)
gmsh.write("hbase.msh")
import h5py
hreh = meshio.read('hbase.msh')
out_mesh = meshio.Mesh(points=points, cells={cell_type: cells})
return out_mesh
triangle_mesh = create_mesh(hreh, "triangle", prune_z=True)
meshio.write("hreh.xdmf", triangle_mesh)
# Then I plug these into dolfinx and create an elasticity problem with dirchlet and neumann bc
from dolfinx.io import gmshio
import basix
mesh_comm = MPI.COMM_WORLD
with dolfinx.io.XDMFFile(MPI.COMM_WORLD, "hreh.xdmf", "r") as xdmf:
hmesh = xdmf.read_mesh(name="Grid")
V = dolfinx.fem.functionspace(hmesh, ("Lagrange", 1))
u = ufl.TrialFunction(V)
a = ufl.dot(ufl.grad(u), ufl.grad(v)) * ufl.dx
def u_exact(x):
return 1 + x[0]**2 + 2 * x[1]**2
def boundary_D(x):
return np.logical_or(np.isclose(x[0], 0), np.isclose(x[0], 1))
dofs_D = dolfinx.fem.locate_dofs_geometrical(V, boundary_D)
u_bc = dolfinx.fem.Function(V)
u_bc.interpolate(u_exact)
bc = dolfinx.fem.dirichletbc(u_bc, dofs_D)
