Extracting mesh regions for gmsh mesh
Hi everyone,
I’m currently trying to read a gmsh-generated mesh for a cuboid channel with 3 different types of boundaries.
$MeshFormat
2.2 0 8
$EndMeshFormat
$PhysicalNames
3
2 1 "ExcitedBoundary"
2 2 "SoundProofBoundary"
2 3 "AdmittanceBoundary"
$EndPhysicalNames
$Nodes
$EndNodes
$Elements
1052
1 2 2 1 1 2 13 3
2 2 2 1 1 3 13 12
3 2 2 1 1 9 6 7
11 2 2 2 2 8 5 49
12 2 2 2 2 49 5 58
13 2 2 2 2 17 6 7
14 2 2 2 2 17 90 6
I can convert it using
pathname = "./DuctMesh/"
msh = meshio.read(pathname + "DuctMesh.msh")
meshio.write(pathname + "DuctMesh_xdmf.xdmf", meshio.Mesh(points=msh.points,
                                                          cells={"triangle": msh.cells["triangle"]}))
meshio.write(pathname + "DuctMesh_xdmf_Boundary.xdmf",
                         cells={"triangle": msh.cells["triangle"]},
                         cell_data={"triangle": {"name_to_read": msh.cell_data["triangle"]["gmsh:physical"]}}))
and import it to Fenics using
mesh = df.Mesh()
with df.XDMFFile(pathname + "DuctMesh_xdmf.xdmf") as infile:
    infile.read(mesh)
mvc = df.MeshValueCollection("size_t", mesh, 2)
print("The MeshValueCollection: ", mvc)
with df.XDMFFile(pathname + "DuctMesh_xdmf_Boundary.xdmf") as infile:
mf = df.cpp.mesh.MeshFunctionSizet(mesh, mvc)
But i don’t know how to mark my boundaries properly or how to acces them from the previous code.
When I’m using
boundary_markers = df.MeshFunction("size_t", mesh(), mesh.topology().dim() - 1)
and
class OnBoundary(df.SubDomain):  # determine whether coordinate is on boundary
        return on_boundary
i am not able to mark my boundries in the right way and accesing them properly.
neumann_excited = Bm.OnBoundary()  # define Neumann boundary
neumann_excited.mark(boundary_markers, 1)  # mark excited neumann boundary as 1
neumann_zero = Bm.OnBoundary()
neumann_zero.mark(boundary_markers, 2)  # mark zero neumann boundary as 2
robin = OnBoundary()  # define Robin boundary
robin.mark(boundary_markers, 3)  # mark robin boundary as 3
When i’m debuggin my boundaries, each point is assigned to each of my boundaries, but i want boundary one to be neumann_excited, etc. …
I am not able to find anythin on how to solve this problem, so i’m asking here and hoping i can get an answer.
Any help is highly appreciated!
Thanks in advance!
Your boundary markers are already loaded into the facet function mf.
The line mf = df.cpp.mesh.MeshFunctionSizet(mesh, mvc) create the meshfunction that can be used in for instance a measure or Dirichlet-condition:
ds_admittance = df.Measure(subdomain=mesh, subdomain_data=mf, subdomain_id=3), or
bc = DirichletBC(FunctionSpace(mesh, "CG", 1), Constant(1), mf, 3)
Wow thank your very much, that was very useful.
Do i even have to use this class definition
        return on_boundary
if i’m defining my integrals to be
ds_excited = df.Measure("ds", domain=mesh, subdomain_data=mf, subdomain_id=1)
ds_sound_proof = df.Measure("ds", domain=mesh, subdomain_data=mf, subdomain_id=2)
ds_admittance = df.Measure("ds", domain=mesh, subdomain_data=mf, subdomain_id=3)
And just for understanding what is going on, if i’m writing
Left = (Lr + Li) * ds_excited
With the above code, do i “say” to Fenics that this expression is only evaluated on the ds_excited boundary?
When i’m trying to plot my solution, the following error occus:
fig1 = plt.figure()
fig11 = df.plot(p_r, title='part', cmap='jet')
fig1.colorbar(orientation="horizontal", mappable=fig11)
RuntimeWarning: invalid value encountered in reduce
  return umr_maximum(a, axis, None, out, keepdims, initial)
RuntimeWarning: invalid value encountered in less
  xa[xa < 0] = -1
  return ufunc.reduce(obj, axis, dtype, out, **passkwargs)
Apart from this my code runs perfectly fine, thank you very much!!
Hi, You don’t need the OnBoundary-class. You are also right that Left = (Lr + Li) * ds_excited is an expression only evaluated on the ds_excited boundary.
As you haven’t supplied your full code, I can’t tell why your plot doesn’t work. To debug this, I would first try to plot without a colorbar or save the function to pvd and visualize it with paraview.
Plotting without a colorbar produced the same error.
I think i found my error, my solution variable only contains 0, i think it has to do with my mesh.
Thank your very much anyways, it really helped me out a lot. I just have to figure out how to do my mesh right.
Hi again,
theres one more question and answering this would help me out a lot.
When defining in gmsh
$PhysicalNames
4
3 4 "DuctInside"
$EndPhysicalNames
for the interior domain for the model DuctInside, how do i use this information in my code?
Do I use
left_side = <expression> * df.dx
or
dx_volume = df.Measure("dx", domain=mesh, subdomain_data=mf, subdomain_id=4)
left_side = <expression> * dx_volume
Thanks very much for any help!!
You should use the custom measures, as you sketch out.
Thanks for the quick answer!
My code isn’t running, i always get NaN as a result, maybe you can have a quick view and tell me what i’m doing wrong because i really have no idea.
Gmsh-file:
$MeshFormat
2.2 0 8
$EndMeshFormat
$PhysicalNames
4
3 4 "DuctInside"
$EndPhysicalNames
$Nodes
9
1 1.7 0.02 -0.25
2 -1.7 0.02 -0.25
3 -1.7 -0.02 -0.25
4 1.7 -0.02 -0.25
5 1.7 0.02 0.25
6 -1.7 0.02 0.25
7 -1.7 -0.02 0.25
8 1.7 -0.02 0.25
9 0 0 0
$EndNodes
$Elements
24
1 2 2 1 1 2 7 3
2 2 2 1 1 2 6 7
3 2 2 2 2 8 3 4
4 2 2 2 2 8 7 3
5 2 2 2 3 1 2 6
6 2 2 2 3 1 6 5
7 2 2 2 4 6 7 5
8 2 2 2 4 7 8 5
9 2 2 2 5 1 4 2
10 2 2 2 5 4 3 2
11 2 2 3 6 8 1 4
12 2 2 3 6 8 5 1
13 4 2 4 1 2 7 3 9
14 4 2 4 1 1 4 8 9
15 4 2 4 1 3 8 4 9
16 4 2 4 1 7 8 3 9
17 4 2 4 1 1 2 4 9
18 4 2 4 1 2 3 4 9
19 4 2 4 1 8 5 9 7
20 4 2 4 1 9 5 8 1
21 4 2 4 1 6 2 9 7
22 4 2 4 1 9 2 6 1
23 4 2 4 1 5 6 9 7
24 4 2 4 1 9 6 5 1
$EndElements
Code:
                                                          cell_data={"tetra": {"name_to_read": msh.cell_data["tetra"]["gmsh:physical"]}}))
mesh = df.Mesh()
    infile.read(mesh)
print("The MeshFunctionSizet: ", mf)
# boundary = Bm.OnBoundary()  # define boundary
# Create function space for complex variable
Vr = df.FiniteElement('Lagrange', mesh.ufl_cell(), 1)  # function space for real parts
Vi = df.FiniteElement('Lagrange', mesh.ufl_cell(), 1)  # function space for imag parts
Vc = df.FunctionSpace(mesh, Vr * Vi)  # composed function space for complex variable coefficients
(p_r, p_i) = df.TrialFunction(Vc)
(w_r, w_i) = df.TestFunction(Vc)
v_s = -df.Constant(1.0)  # - sign stems from direction of normal vector on excited boundary
# Define weak form - term by term
# stiffness matrix terms
t1r = df.inner(df.grad(p_r), df.grad(w_r)) - df.inner(df.grad(p_i), df.grad(w_i))
t1i = df.inner(df.grad(p_i), df.grad(w_r)) + df.inner(df.grad(p_r), df.grad(w_i))
# mass matrix terms
t3r = -(df.Constant(k) ** 2 * (df.inner(p_r, w_r) - df.inner(p_i, w_i)))
t3i = -(df.Constant(k) ** 2 * (df.inner(p_i, w_r) + df.inner(p_r, w_i)))
# Summation of matrix terms
ar = t1r + t3r
ai = t1i + t3i
# excitation term - best solution
Lr = omg*rho_f*v_s*w_i  # -omg*rho_f*v_s*w_r
Li = -omg*rho_f*v_s*w_r  # -omg*rho_f*v_s*w_i
a = (ar + ai) * dx_volume
right= (Lr + Li) * ds_excited
p = df.Function(Vc)
df.solve(a == right, p)
(p_r, p_i) = p.split()
p_real = p_r.compute_vertex_values(mesh)
print(p_real)
Output: [nan nan nan nan nan nan nan nan  0.]
I would search by myself but there really is no proper documentation on how to do it or i’m not able to find something like that.
But thank you very much you already helped me out a lot!!
Hi again,
can you maybe help me with my code i postet below? I really don’t know what to do, it just isn’t working.
Sorry to bother you that much.
I’m having an issue converting a .msh file using the code snippets from above:
msh = meshio.read("graded_tri.msh")
line_cells = []
triangle_cells = []
for cell in msh.cells:
    if cell.type == "triangle":
        triangle_cells = cell.data
    elif  cell.type == "line":
        if len(line_cells) == 0:
            line_cells = cell.data
            line_cells = np.vstack([line_cells, cell.data])
line_data = []
triangle_data = []
    if key == "line":
        if len(line_data) == 0:
            line_data = msh.cell_data_dict["gmsh:physical"][key]
            line_data = np.vstack([line_data, msh.cell_data_dict["gmsh:physical"][key]])
    elif key == "triangle":
triangle_mesh = meshio.Mesh(points=msh.points, cells={"triangle": triangle_cells})
line_mesh =meshio.Mesh(points=msh.points,
                           cells=[("line", line_cells)],
                           cell_data={"name_to_read":[line_data]})
meshio.xdmf.write("mf.xdmf", line_mesh)
Gmsh version 4.6 was used to create and convert the following .geo file:
Point(1) = {0, 0, 0, 1.0};
Point(2) = {1, 0, 0, 1.0};
Point(3) = {1, 1, 0, 1.0};
Point(4) = {0, 1, 0, 1.0};
Point(5) = {0.9, 0, 0, 1.0};
Point(6) = {0.9, 0.9, 0, 1.0};
Point(7) = {0.9, 1, 0, 1.0};
Point(8) = {0, 0.9, 0, 1.0};
Point(9) = {1, 0.9, 0, 1.0};
Line(1) = {1, 5};
Line(2) = {5, 2};
Line(3) = {2, 9};
Line(4) = {9, 3};
Line(5) = {3, 7};
Line(6) = {7, 4};
Line(7) = {4, 8};
Line(8) = {8, 1};
Line(9) = {5, 6};
Line(10) = {6, 8};
Line(11) = {9, 6};
Line(12) = {6, 7};
Curve Loop(1) = {8, 1, 9, 10};
Plane Surface(1) = {1};
Curve Loop(2) = {9, -11, -3, -2};
Plane Surface(2) = {2};
Curve Loop(3) = {11, 12, -5, -4};
Plane Surface(3) = {3};
Curve Loop(4) = {7, -10, 12, 6};
Plane Surface(4) = {4};
Physical Curve(4) = {1};
Physical Curve(5) = {2};
Physical Curve(6) = {3};
Physical Curve(7) = {4};
Physical Curve(8) = {5};
Physical Curve(9) = {6};
Physical Curve(10) = {7};
Physical Curve(11) = {8};
Using the version of meshio that was available from the repository about a week ago, I get the error message:
File “conversion.py”, line 31, in
meshio.write(“mesh.xdmf”, triangle_mesh)
File “…/env/lib/python3.6/site-packages/meshio/_helpers.py”, line 136, in write
if value.shape[1] != num_nodes_per_cell[key]:
AttributeError: ‘list’ object has no attribute ‘shape’
Please advise.
You have not added any physical surfaces to your geometry, thus meshio cannot find any.
Everything works if you add:
Physical Surface(1) = {1, 4, 3, 2};
You are a life saver dokken, thank you!
Hello again Dokken,
I have been revisiting this mesh and the conversion works beautifully. However, the actual xdmf files are lacking some information. As you can see in the mesh, I only have a single surface of 2d elements instead of four as expected.
It does not make a whole lot of sense to a gmesh noob.
Thanks,
eiriken
Please either attach a minimal example, or have a look at: Transitioning from mesh.xml to mesh.xdmf, from dolfin-convert to meshio - #104 by dokken which explain how to extract multiple regions. I have also made a tutorial on the subject: Mesh generation and conversion with GMSH and PYGMSH | Jørgen S. Dokken
Certainly,
The following is the .geo file used to create the .msh file which was successfully converted using meshio convert:
Line(1) = {1, 5};
Line(2) = {5, 2};
Line(3) = {2, 9};
Line(4) = {9, 3};
Line(5) = {3, 7};
Line(6) = {7, 4};
Line(7) = {4, 8};
Line(8) = {8, 1};
Line(9) = {5, 6};
Line(10) = {6, 8};
Line(11) = {9, 6};
Line(12) = {6, 7};
The outputs are two .xdmf files, one with the solid portion shown in grey above and the mesh skeleton in colors.
It seems that only a portion of the physical surface is read to be 2d elements.
As I said in the previous post, follow my newest tutorial.
I copied your geo output and created an msh file (mesh2.msh), which I then converted with the following script from the tutorial:
mesh_from_file = meshio.read("mesh2.msh")
import numpy
    cells = numpy.vstack([cell.data for cell in mesh.cells if cell.type==cell_type])
    cell_data = numpy.hstack([mesh.cell_data_dict["gmsh:physical"][key]
                         for key in mesh.cell_data_dict["gmsh:physical"].keys() if key==cell_type])
    # Remove z-coordinates from mesh if we have a 2D cell and all points have the same third coordinate
    points= mesh.points
    if prune_z:
        points = points[:,:2]
    mesh_new = meshio.Mesh(points=points, cells={cell_type: cells}, cell_data={"name_to_read":[cell_data]})
    return mesh_new
line_mesh = create_mesh(mesh_from_file, "line", prune_z=True)
meshio.write("facet_mesh.xdmf", line_mesh)
triangle_mesh = create_mesh(mesh_from_file, "triangle", prune_z=True)
which gives you the full triangular mesh
Hello. I have a question. After creating mesh, I want to get information from this mesh and write it in .xdmf files. So, this is a code
msh = meshio.read("/home/natalia/mesh/mesh_12.msh")
    elif  cell.type == "tetra":
        tetra_cells = cell.data
    elif key == "tetra":
        tetra_data = msh.cell_data_dict["gmsh:physical"][key]
triangle_mesh =meshio.Mesh(points=msh.points,
meshio.write("mes_20.xdmf", tetra_mesh)
meshio.write("mf_20.xdmf", triangle_mesh)
I’m successfully get these files. After this I’m using Dolfin 2019.2.0.dev0 for creating .xml files which I can use in micromagnetic simulation, but Dolfin can’t recognise cell type. Reason: Unknown value “”. In line 27 of code in infile.read(mvc_tetra, “mes_20_name_to_read”).
# Create mesh from XDMF file
mesh = Mesh()
    infile.read(mesh)
# Create a CellFunction to mark cell types
cell_markers = MeshFunction("size_t", mesh, 3)
# Iterate over cells and mark their types
for cell in cells(mesh):
    if CellType == "tetrahedron":
        cell_markers[cell] = 1  # tetrahedra are marked with value 1
    elif CellType == "triangle":
        cell_markers[cell] = 2  # triangles are marked with value 2
# Save cell information to XML file
with XDMFFile("cell_info.xml") as outfile:
    outfile.write(cell_markers)
# Create subdomain cell function for tetrahedra
mvc_tetra = MeshValueCollection("size_t", mesh, 3)
with XDMFFile("mes_20.xdmf") as infile:
    infile.read(mvc_tetra, "mes_20_name_to_read")
subdomain_marker_tetra = cpp.mesh.MeshFunctionSizet(mesh, mvc_tetra)
# Save subdomain information to XML file
with XDMFFile("subdomain_info_tetra.xml") as outfile:
    outfile.write(subdomain_marker_tetra)
# Create boundary subdomain facet function for triangles
mvc_triangle = MeshValueCollection("size_t", mesh, 2)
with XDMFFile("mf_20.xdmf") as infile:
    infile.read(mvc_triangle, "mf_20_name_to_read")
boundary_marker_triangle = cpp.mesh.MeshFunctionSizet(mesh, mvc_triangle)
# Save boundary information to XML file
with XDMFFile("boundary_info_triangle.xml") as outfile:
    outfile.write(boundary_marker_triangle)
When I open xdmf files I can see, that they contain information about not cell but Topology. This is the whole data which file has.
<Xdmf Version="3.0"><Domain><Grid Name="Grid"><Geometry GeometryType="XYZ"><DataItem DataType="Float" Dimensions="13195 3" Format="HDF" Precision="8">mes_20.h5:/data0</DataItem></Geometry><Topology TopologyType="Tetrahedron" NumberOfElements="63663" NodesPerElement="4"><DataItem DataType="Int" Dimensions="63663 4" Format="HDF" Precision="4">mes_20.h5:/data1</DataItem></Topology></Grid></Domain></Xdmf>
How Dolfin can recognise cell type in my case then?
There is topology information in the file.
However, you should not use the XML extension for xdmf files:
I use XML file for saving (outfile). Is it impossible? For taking information I take file XDMF:
    infile.read(mesh)
What I’m trying to tell you is that you cannot use the xml extension when writing an XDMFFile
should be
with XDMFFile("subdomain_info_tetra.xdmf") as outfile:
and
"mes_20_name_to_read" should just be "name_to_read"
