Since I pulled a recent dolfinx/dolfinx docker image, the code below - from the tutorial on linear elasticity fails with the error ‘AttributeError: ‘Argument’ object has no attribute ‘geometric_dimension’’. It was working well before. Would you have any idea what might cause this?
Many thanks,
Claire
# Scaled variable
L = 1
W = 0.2
mu = 1
rho = 1
delta = W/L
gamma = 0.4*delta**2
beta = 1.25
lambda_ = beta
g = gamma
from dolfinx import mesh, fem, plot, io
domain = mesh.create_box(MPI.COMM_WORLD, [np.array([0,0,0]), np.array([L, W, W])],
[20,6,6], cell_type=mesh.CellType.hexahedron)
V = fem.VectorFunctionSpace(domain, ("CG", 1))
def clamped_boundary(x):
return np.isclose(x[0], 0)
u_D = np.array([0,0,0], dtype=ScalarType)
bc = fem.dirichletbc(u_D, fem.locate_dofs_topological(V, fdim, boundary_facets), V)
T = fem.Constant(domain, ScalarType((0, 0, 0)))
return ufl.sym(ufl.grad(u)) # Equivalent to 0.5*(ufl.nabla_grad(u) + ufl.nabla_grad(u).T)
def sigma(u):
return lambda_ * ufl.nabla_div(u) * ufl.Identity(u.geometric_dimension()) + 2*mu*epsilon(u)
u = ufl.TrialFunction(V)
f = fem.Constant(domain, ScalarType((0, 0, -rho*g)))
