Hello!
I am getting an error when trying to calculate the strain of a finite element displacement. The final error message is: ‘Mesh’ object has no attribute ‘geometric_dimension’.
I read others topics in this discourse group about the same issue, but I still could not solve it.
My code is as follows:
# from petsc4py import PETSc
def eps(u):
return ufl.sym(ufl.grad(u))
msh = mesh.create_rectangle(
comm=MPI.COMM_WORLD,
points=((0.0, 0.0), (2.0, 1.0)),
n=(32, 16),
cell_type=mesh.CellType.triangle,
element = ufl.VectorElement("Lagrange","triangle",2)
V = ufl.FunctionSpace(msh, element)
print(eps(v)) # just to see if eps(v) is computed
Any suggestion is welcome.
